March 29, 2006, 06:17 |
I succeeded in insta
Thomas Wolfanger
Rep Power: 17 |
I succeeded in installing OpenFOAM to a user's directory. I would prefer to have the installation in an system wide accessible location so that all users on a machine get access to it, for example in /soft/OpenFOAM. Is this possible and what changes, besides changing the installation directory in the bashrc file, are necessary to accomplish this? Thanks for your input, best regards -Thomas |
March 29, 2006, 06:37 |
Thats it. Just make sure all t
Eugene de Villiers
Rep Power: 21 |
Thats it. Just make sure all the users can source the new installation, i.e. the OF directory structure is readable by all or group.
March 29, 2006, 07:45 |
In my experience OpenFOAM tend
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
In my experience OpenFOAM tends to run smoothest (no change of scripts etc) when found at $HOME/OpenFOAM/. For a system wide installation I would recommend (at least that's what I did) emulating this behaviour with symbolic links:
* Set-up a site-wide available NFS-Drive /OpenFoam and mount that on all machines * install the necessary OpenFOAM-versions into that directory (getting something like /OpenFOAM/OpenFOAM-1.2/) * to set up a User for OpenFOAM ** create a symbolic link for him (ln -s /OpenFOAM $HOME/OpenFOAM) ** edit his bashrc as described in the README (of course she can do theses things herself) I have decided to take this opt-in-route (the User has to be set up if he wants to use OF) because we have other software here some of which for instance don't like the cutting-edge g++ that comes with OF. (I remember one problem with my setup with FoamX where one dir/file has to be readwritable for everyone otherwise FoamX won't start, but I can't remember exactly how we fixed it, if you run into it I'll be glad to help)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Installation Fluent 6.3 into Red Hat Linux System | rashid | FLUENT | 1 | March 1, 2008 09:57 |
World wide CFD conferences | B. R. Guirguis | Main CFD Forum | 0 | January 21, 2006 03:04 |
Installation on a cluster running a queueing system PBS | sampaio | OpenFOAM Installation | 12 | June 20, 2005 18:16 |
wide regime flows | AE | FLUENT | 0 | May 18, 2004 19:06 |
New Site-Wide Search Engine | Jonas Larsson | Main CFD Forum | 3 | June 12, 2000 13:55 |
