OpenFOAM FreeBSD port upgraded to 13
Old   April 1, 2006, 17:33
Default See
Thierry Thomas
thierry is on a distinguished road
See <http://www.freshports.org/science/openfoam/>.
If you want to include the required patches in the next release, don't hesitate to contact me.
Regards,
Th. Thomas.
thierry is offline   Reply With Quote
Old   April 1, 2006, 17:57
Default Hi Thierry, I'm in the proc
Hrvoje Jasak
Hi Thierry,
I'm in the process of putting the accumulated bug fixes and the Mac OS X port stuff into the code - can you pack the patches in some compact way or do I need to take and diff the whole thing? The same question applies to the Windows port (thanks Petr).
Hrv
Hrvoje Jasak
Old   April 1, 2006, 18:20
Default Hrv - For the Windows port,
brooksmoses
Hrv -
For the Windows port, is the changelog (http://dpdx.net/software/openfoam/cy...angelog.cygwin) and set of patch files that I put up on http://dpdx.net/openfoam-cygwin/ (see the "Patch Files and Explanation" section, about halfway down) when I packaged up Petr's port something like what you're looking for? If so, I'll gladly do a revised version of that when the 1.3 version of the port is done.
Meanwhile, congrats to Thierry on the quick job of porting to FreeBSD!
- Brooks
Old   April 1, 2006, 18:40
Default Hi Hrvoje, Thanks for your
Thierry Thomas
Hi Hrvoje,
Thanks for your quick reply.
All patches are available at http://www.freebsd.org/cgi/cvsweb.cg...penfoam/files/ (patch-*). Most of them are perhaps too specific to be included upstream: they just fix paths or version numbers.
The interesting ones add FreeBSD support:
- patch-.bashrc
- patch-.cshrc
- patch-applications_ummp..._C++_PatchToolServer_Make_orbO ptions
- patch-applications_ummp..._C++_FoamXServer_Make_orbOptio ns
- patch-applications_ummp..._C++_PatchToolServer_Make_omni Options
- patch-applications_upFC..._FoamXLib_Make_orbOptions
- patch-.OpenFOAM-++VER++_bashrc
- patch-.OpenFOAM-++VER++_cshrc
- patch-applications_utilities_preProcessing_FoamX_C++_All wmake
- patch-bin_foamInstallationTest
- patch-applications_ummp..._C++_FoamXServer_Make_omniOpti ons
- patch-applications_upFC..._FoamXLib_ITypeDescriptorImpl. C
- patch-applications_upFC..._FoamXLib_Make_omniOptions
- patch-applications_upFC..._FoamXLib_ProcessControl.C
- patch-bin_foamSystemCheck
- patch-applications_ummp..._C++_Allwmake
To get wmake/rules/FreeBSD, I copy Linux rules and patch them. These patches are not interesting for you, and I have rolled the resulting files: you can get them at http://people.freebsd.org/~thierry/p...es_FreeBSD.tgz
To Brooks: it's surely easier to port to a Unix system than to Windows!
Regards,
Th. Thomas.
Old   April 1, 2006, 19:25
Default Thanks for that - it will be m
Hrvoje Jasak
Thanks for that - it will be merged in due course (quite a lot of porting and re-porting required). The wmake/rules can go straingt in, as well as the FreeBSD sections in all dot-files; the rest is probably already on ifdefs as appropriate (in which case there's no trouble).
As for the Windows stuff, I want to put in all the file changes that are protable across the platforms, with the exception of renaming the files. The file name and include changes are easily scripted but I'd prefer to leave the scripts to someone who is actually using Windows/Cygwin ('cause I've no patience for it).
Hrv
Hrvoje Jasak
OpenFOAM 15x MinGW Windows Port gocarts OpenFOAM Installation 1 April 17, 2009 11:41
divide by zero FPE issue in OpenFOAM 141 MingW port allenzhao OpenFOAM Installation 9 September 22, 2008 18:13
Port OpenFOAM to IBM Cell BE mgarcia OpenFOAM Installation 2 November 1, 2007 08:33
Port of OpenFOAM14 to FreeBSD thierry OpenFOAM Installation 0 April 28, 2007 10:36
OpenFOAM Cygwin port updated to 13 brooksmoses OpenFOAM Installation 29 November 30, 2006 06:49
