OpenFOAM installation on SUSE92 problems
Old   April 3, 2006, 07:11
Default Hi to all, I'm new user of li
Giuseppe Noviello
derath is on a distinguished road
Hi to all,
I'm new user of linux o.s. and I am trying to install openFOAM on my pc but when i run foamInstallationTest it report me this:
linux:/home/giuseppe/OpenFOAM/OpenFOAM-1.3/bin # bash foamInstallationTest
Executing foamInstallationTest:
Checking basic setup...
Shell: bash
Host: linux
OS: Linux version 2.6.8-24-default
User: giuseppe
User_config: /root/.bashrc
FATAL ERROR: /root/.OpenFOAM-1.3/bashrc does not appear to be sourced from:
/root/.bashrc
You need the following at the end of your /root/.bashrc file:
. /root/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
or equivalent depending on the location of the OpenFOAM installation.
FATAL ERROR Foam install directory not set.
Set correct path to installation 'WM_PROJECT_INST_DIR' in /root/.foam2.3/bashrc
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR --------- env variable not set --------- yes
$WM_PROJECT_USER_DIR --------- env variable not set --------- no
$FOAM_JOB_DIR --------- env variable not set --------- yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR --------- env variable not set --------- yes
$FOAM_USER_APPBIN --------- env variable not set --------- no
$FOAM_APPBIN --------- env variable not set --------- yes
$WM_DIR --------- env variable not set --------- yes
$FOAMX_PATH --------- env variable not set --------- yes
$CEI_HOME --------- env variable not set --------- no
$JAVA_PATH --------- env variable not set --------- no
$MICO_ARCH_PATH --------- env variable not set --------- yes
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN --------- env variable not set --------- yes
$FOAM_USER_LIBBIN --------- env variable not set --------- no
Software versions
Software Version Location
gcc 3.3.4
WARNING: Conflicting installations:
foam settings: /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
java 1.4.2_11
foam settings: /usr/lib/jvm/jre/bin/java
current path : /usr/bin/java
gzip 1.3.5 /bin/gzip
tar 1.3.5 /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_linux Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
The system test has evoked 1 fatal error(s).
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
Someone can help me?
thanks
Giuseppe Noviello
derath is offline   Reply With Quote
Old   April 3, 2006, 07:44
Default Hi Giuseppe, you need to so
Markus Hartinger
hartinger is on a distinguished road
Hi Giuseppe,
you need to source the OpenFOAM bashrc-file form your .bashrc
>You need the following at the end of your >/root/.bashrc file:
Personnally i wouldn't install it as root, i find it more convenient to install in my local accout
$HOME/OpenFOAM
regards
Markus
hartinger is offline   Reply With Quote
Problems with installation of OpenFoam sheyer OpenFOAM Installation 8 July 28, 2008 04:45
OpenFOAM installation Mark Main CFD Forum 2 March 29, 2008 08:45
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 02:40
Installation OpenFoam on SuSe 101 mephisto OpenFOAM Installation 1 November 8, 2006 03:15
OpenFOAM installation on AIX 53 with gnu 40 compiler chauvin OpenFOAM Installation 3 June 15, 2006 14:12
