Compiling OpenFOAM 13 in Debug mode
Old   April 13, 2006, 05:48
Default Hi! Because of problems with
Francesco Del Citto
fra76 is on a distinguished road
Hi!
Because of problems with splitMesh utility, I'm trying to compile OF on a Fedora Core 5 x86_64 linux workstation, with this settings in .OpenFOAM-1.3/bashrc:
export WM_PRECISION_OPTION=SP
export WM_COMPILE_OPTION=Debug
export WM_JAVAC_OPTION=Opt
After a while, the compiling process return this error:
SOURCE_DIR=global
SOURCE=global/global.C ; g++ -m64 -DlinuxAMD64 -DSP -Wall -W -Wno-unused-parameter -Wold-style-cast -O0 -fdefault-inline -ggdb3 -DFULLDEBUG -DNoRepository -ftemplate-depth-30 -DWM_PROJECT_VERSION='"'1.3'"' -I/home/francesco/OpenFOAM/OpenFOAM-1.3/src/zlib-1.2.1 -I/home/francesco/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -c $SOURCE -o Make/linuxAMD64Gcc4SPDebug/global.o
In file included from global/global.C:61:
/home/francesco/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:41:22: error: demangle.h: No such file or directory
/home/francesco/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C: In static member function 'static void Foam::error::printStack(Foam:: Ostream&)':
/home/francesco/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:193: error: 'auto_demangling' was not declared in this scope
/home/francesco/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:194: error: 'cplus_demangle' was not declared in this scope
make: *** [Make/linuxAMD64Gcc4SPDebug/global.o] Error 1
It doesn't stop, and after a while other errors, and it finally stops.
I'm using the gcc 4.1.0 distributed with OpenFOAM, even if it should be exactly the same of Fedora Core 5:
[francesco@donald .OpenFOAM-1.3]$ which gcc
~/OpenFOAM/linuxAMD64/gcc-4.1.0/bin/gcc
[francesco@donald .OpenFOAM-1.3]$ gcc --version
gcc (GCC) 4.1.0
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Any suggestions?
Francesco
fra76 is offline   Reply With Quote
Old   April 13, 2006, 06:13
Default See the discussion about "Suse
Assistant Moderator
Bernhard Gschaider
See the discussion about "Suse 9.1 Port" (Dont know the exact title; you'll find it when you search for demangle.h)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 14, 2006, 04:09
Default Thanks a lot! I've resolved my
Francesco Del Citto
Thanks a lot! I've resolved my problem with this steps:
1)
I've edited error.C and around the include statement re-define the name locally, i.e.
#define typename FraTypeName
#include <demangle>
#undef typename
(Thanks to Hrvoje Jasak)
2)
Then I've installed binutils-debuginfo (yum install binutils-debuginfo )
3)
And then, at the command line, just before ./Allwmake :
export CPLUS_INCLUDE_PATH=/usr/src/debug/binutils-2.15.92.0.2/include/
with the right version of binutils in the path, of course.
(Thanks to Bernhard Gschaider)
This resolved all the problems I was encountering on Fedora Core 5 !
Francesco
Debug mode with UDF ?? Thierry FLUENT 1 October 9, 2018 22:57
Problem when compiling debug version of 141 kar OpenFOAM Installation 0 February 22, 2008 10:59
Compiling errors for OpenFOAM 13 brucejimo OpenFOAM Installation 3 October 5, 2006 01:01
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 09:54
Compiling openfoam zaferleylek OpenFOAM Installation 0 November 7, 2005 08:01
