Windows Installation BugsComments on Petrbs patch
Old   March 28, 2006, 11:41
Default Philippe can you try please to
  #41
Petr Vita
pvita is on a distinguished road
Send a message via MSN to pvita Send a message via Skype™ to pvita
Philippe can you try please to execute command wclean zlib-1.2.1 and then wmake libso zlib-1.2.1 posting here exact output?
pvita is offline   Reply With Quote
Old   March 28, 2006, 17:35
Default Horray!!! Many thanks Petr
  #42
Philippe STRAET
ceradi is on a distinguished road
Horray!!!
Many thanks Petr and Brooks !
The wclean had a magic effect in my case!
Let me know if you still want the exact output for examinations...
The Allwmake is running while writing this message, I'll see and I suppose it will be OK now...
Thanks again... Bye
Philippe
ceradi is offline   Reply With Quote
Old   March 28, 2006, 17:46
Default Great! I don't think there's
  #43
brooksmoses
Great! I don't think there's a need for you to post the exact output, if it worked and produced the right .dll files.
(Speaking of which, it's probably a good idea to delete the erroneous libNULL.dll and libNULL.a files, if you haven't already.)
Let me know when the Allwmake process finishes, and if it seems like everything works, I'll put all the bugfixes in a patch and upload them.
Thanks again for your bug reports and help in debugging this.
Old   March 29, 2006, 05:00
Default Brooks, The Allwmake took a
  #44
Philippe STRAET
Brooks,
The Allwmake took approximately 5 hours to finish his job. I've got now 165 .exe files , 46 .a and 46 .dll.
I tested the installation with the cavity tutorial and it work without any problem...
Thanks again for all ..
Philippe
Old   April 10, 2006, 15:12
Default I have followed the messages h
  #45
ewr
Errol Robinson
ewr is on a distinguished road
I have followed the messages here and have also successfully implemented OpenFOAM on a windows based system (Windows XP). Thanks for all your work.
I was wondering if anyone had attempted to compile the latest OpenFOAM release (version 1.3) for a cygwin/windows installation?
Thanks
Errol
ewr is offline   Reply With Quote
Old   April 10, 2006, 23:54
Default Errol - You're welcome. Th
  #46
brooksmoses
Errol -
You're welcome. Thanks for the report that it works! It's good to know that it's useful and that it's working.
As for OpenFOAM-1.3, you have excellent timing with your question -- I've just finished the port for that and posted it; see the other thread that I started for that.
- Brooks
Old   April 15, 2006, 16:41
Default I am quite new for both cygwin
  #47
Kitchener Wang
kitchener is on a distinguished road
I am quite new for both cygwin and OpenFOAM. I tried to follow the method described in http://dpdx.net/openfoam-cygwin/ provided by Brooks Moses. I met some problems. Here are what I have done.
1) install Cygwin with default packages plus sed, make, flex, bison, xorg-x11-devel in C:\cygwin.
2)Build a directory called OpenFOAM and downloaded and unpack (tar xzf (filenames)) both OpenFOAM-1.3.cygwin-src-0.5.tar.gz and
gcc-4.1.0.cygwin-OpenFOAM.tar.gz from the website into that directory.
3)Type .bashrc under the directory of /home/wang/OpenFOAM/OpenFOAM-1.3
4)Type Allwmake. Then a lot of errors were reported like "Makefile... ...wmake: command not found"
Could anyone please give me some advices how to fix the problem? Many thanks,
Wang
kitchener is offline   Reply With Quote
Old   April 16, 2006, 00:57
Default One problem with step 2: Yo
  #48
brooksmoses
You should not unpack gcc-4.1.0.cygwin-OpenFOAM.tar.gz into the OpenFOAM directory. You should create a directory called "cygwin" inside the OpenFOAM directory, and unpack the gcc-... file into it.
Two problems with step 3:
First, that's the wrong bashrc file; you should use the one under /home/wang/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc. (Probably I should make that more clear in the directions.)
Second, just running it as a normal script doesn't do anything -- all the environment variables that it sets go away once the script finishes running. Instead you need to run it with the command "source bashrc".
That should be sufficient to get things working, I hope. Apologies that the installation instructions didn't make this sufficiently clear.
Old   April 16, 2006, 01:20
Default Hi Brooks, thanks for your hel
  #49
Kitchener Wang
Hi Brooks, thanks for your help very much. It seems now that things go toward to a right direction in my computer. Thanks,
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 10:42
INSTALLATION OF 141 naveen OpenFOAM Installation 3 January 30, 2009 05:19
Regarding installation vidyaprakash Siemens 0 December 22, 2006 00:03
Installation of 13 grtabor OpenFOAM Installation 14 August 24, 2006 13:43
Windows Installation Petrbs Port Redux Patches and Binary Distribution brooksmoses OpenFOAM Installation 0 February 10, 2006 18:35
