April 15, 2006, 16:51 |
Thanks for the hard work by Pe
Kitchener Wang
Rep Power: 17 |
Thanks for the hard work by Petr,Brooks,
Niklas,Cresswell,etc on making OpenFOAM work in Cygwin. I try to follow the method described in the web: http://files.dpdx.net/openfoam/cygwi...M-Cygwin-HOWTO . However I have some troubles to locate the followings files 1) OpenFOAM-1.2.General.gtgz 2) Patch file: OpenFOAM-1.2.Cygwin.patch.gz 3) Compilation and pre-install scripts: gccCompile.sh preInstall.sh If you have these files, would you please kindly send me a copy or let me know where to download those files. My email is wang3400@wlu.ca Many thanks, Wang |
April 16, 2006, 00:47 |
Wang -
The document that yo
Wang -
The document that you reference is Petr's original description of a very early version of the Cygwin port; at this point it's quite out of date. The current version of the installation process is described on http://dpdx.net/openfoam-cygwin/. Simply download the four .tar.gz files from that page that are listed under "Current Distribution" (or the ones under "Past Distribution", if you prefer to use OpenFOAM-1.2 rather than OpenFOAM-1.3), and install them with the following set of commands, or something similar: cd $HOME mkdir OpenFOAM cd OpenFOAM tar -xzf ../OpenFOAM-1.3.cygwin-src-0.5.tar.gz tar -xzf ../OpenFOAM-1.3.cygwin-bin-0.5.tar.gz tar -xzf ../OpenFOAM-1.3.Docs.tar.gz mkdir cygwin cd cygwin tar -xzf ../../gcc-4.1.0.cygwin-OpenFOAM.tar.gz (This assumes that you downloaded the four files to your $HOME directory. If not, change the file references accordingly....) Once you've done that, you should set up your .bashrc file or .cshrc file as described in the installation directions for the Linux distribution on the main OpenFOAM website. That should be all that you need to do. Hope this helps, - Brooks |
April 24, 2006, 11:55 |
Now I am trying to port your O
Qiang Li
Rep Power: 17 |
Now I am trying to port your OpenFOAM-1.3 with cygwin to win-XP , I follows your instructions above and it works fine. But when I wanted to recompile OpenFOAM directory for obtaining OpenFOAM.dll, I have got the error as following:
"chFields.o slipPointPatchFields.o symmetryPointPatchFields.o processorPointPatchFields.o globalProcessorPointPatchFields .o pointFields.o bandCompression.o preservePatchTypes.o PatchToPatchInterpolationName.o meshWaveName.o curve.o graph.o r awGraph.o gnuplotGraph.o xmgrGraph.o jplotGraph.o \ Pstream_import.o IPread_import.o OPwrite_import.o -Wl,--no-whole-archive -L/home/Liqiang/OpenFOAM/OpenFOAM-1.3/lib/ cygwinGcc4DPOpt \ -lfoamUser -lz -o /home/Liqiang/OpenFOAM/OpenFOAM-1.3/lib/cygwinGcc4DPOpt/libOpenFOAM.dll /usr/bin/ld: cannot find -luser32 collect2: ld returned 1 exit status make: *** [/home/Liqiang/OpenFOAM/OpenFOAM-1.3/lib/cygwinGcc4DPOpt/libOpenFOAM.dll] Error 1" I think it maybe is the LD_LIBRARY_PATH's bug, so I tried to add "export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/cygdrive/c/WINDOWS/system32", However it doesn't work yet. Please help me. Thanks in advance! Best regards Q.Li |
April 24, 2006, 13:28 |
The "user32" library is a Cygw
The "user32" library is a Cygwin system library, which should be in /usr/lib/w32api/lib as the file libuser32.a. If that's not there, then you need to install the "w32api" Cygwin package.
I've added this to the list of dependencies on the webpage. |
April 24, 2006, 23:33 |
I have just installed the "w32
Qiang Li
Rep Power: 17 |
I have just installed the "w32api" Cygwin package, It has been in my /lib/w32api/lib dirctory. But when I tried to recompiled foamToGMV again, instead of OpenFOAM for saving-time. I have got:
"$ wmake Making dependency list for source file foamToGMV.C Making dependency list for source file itoa.C Dropping import dependency files SOURCE_DIR=. SOURCE=foamToGMV.C ; g++ -m32 -Dcygwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepos late-depth-30 -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/Liqiang/OpenFOAM/Open /sampling/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/turbulenceModels/incompressible/lnIncl ude -I/h OpenFOAM/OpenFOAM-1.3/src/transportModels/incompressible/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/thermophysicalModels/liquids/lnInclude -I/home/Liqiang/O FOAM-1.3/src/thermophysicalModels/specie/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/thermophysicalM physicalFunctions/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/browser/lnInclude -I/home/Liqiang/Open M-1.3/src/foam/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/lagrangian/basic/lnInclude -I/home/Liqian penFOAM-1.3/src/lagrangian/dieselSpray/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclud e -I. -c $SOURCE -o Make/cygwinGcc4DPOpt/foamToGMV.o SOURCE_DIR=. SOURCE=itoa.C ; g++ -m32 -Dcygwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository depth-30 -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM- ling/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/turbulenceModels/incompressible/lnIncl ude -I/home/L OAM/OpenFOAM-1.3/src/transportModels/incompressible/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/lagr lude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/thermophysicalModels/liquids/lnInclude -I/home/Liqiang/OpenFO 1.3/src/thermophysicalModels/specie/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/thermophysicalModels calFunctions/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/browser/lnInclude -I/home/Liqiang/OpenFOAM/ /src/foam/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/lagrangian/basic/lnInclude -I/home/Liqiang/Ope AM-1.3/src/lagrangian/dieselSpray/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -Il -c $SOURCE -o Make/cygwinGcc4DPOpt/itoa.o /home/Liqiang/OpenFOAM/OpenFOAM-1.3/wmake/bashScripts/mkObjectDir /home/Liqiang/OpenFOAM/OpenFOAM-1.3/applic ygwinGcc4DPOpt/foamToGMV g++ -m32 -Dcygwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth Liqiang/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/sampling/ /home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/turbulenceModels/incompressible/lnInclud e -I/home/Liqiang/OpenFOAM/O src/transportModels/incompressible/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/lagrangian/lnInclude ang/OpenFOAM/OpenFOAM-1.3/src/thermophysicalModels/liquids/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/s sicalModels/specie/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/thermophysicalModels/thermophysicalFu clude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/browser/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/ de -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/lagrangian/basic/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1. gian/dieselSpray/lnInclude -I/home/Liqiang/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. M c4DPOpt/foamToGMV.o Make/cygwinGcc4DPOpt/itoa.o -L/home/Liqiang/OpenFOAM/OpenFOAM-1.3/lib/cygwinGcc4DPOpt \ -lfiniteVolume -llagrangian -lOpenFOAM -liberty -o /home/Liqiang/OpenFOAM/OpenFOAM-1.3/applications/b 4DPOpt/foamToGMV Info: resolving Foam::IOobject::typeName by linking to __imp___ZN4Foam8IOobject8typeNameE (auto-import) Info: resolving Foam::cloud::typeName by linking to __imp___ZN4Foam5cloud8typeNameE (auto-import) Info: resolving Foam::fvPatchField<foam::vector<double> >::typeNameby linking to __imp___ZN4Foam12fvPatchFie rIdEEE8typeNameE (auto-import) Info: resolving Foam::IOField<double>::typeNameby linking to __imp___ZN4Foam7IOFieldIdE8typeNameE (auto-impo Info: resolving Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>::typeNameby li mp___ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fv PatchFieldENS_7volMeshEE8typeN ameE (auto-import) Info: resolving Foam::particle<foam::passiveparticle>::typeName by linking to __imp___ZN4Foam8particleIN articleEE8typeNameE (auto-import) Info: resolving Foam::GeometricField<double,>::typeNameby linking to __imp GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE8ty peNameE (auto-import) Info: resolving Foam::fvPatchField<double>::typeName by linking to __imp___ZN4Foam12fvPatchFieldIdE8typeName rt) Info: resolving Foam::IOField<foam::vector<double> >::typeNameby linking to __imp___ZN4Foam7IOFieldINS_6Vect NameE (auto-import) Info: resolving vtable for Foam::lduCoupledInterfaceby linking to __imp___ZTVN4Foam19lduCoupledInterfaceE (a Info: resolving Foam::word::debug by linking to __imp___ZN4Foam4word5debugE (auto-import) Info: resolving Foam::FatalError by linking to __imp___ZN4Foam10FatalErrorE (auto-import) Info: resolving Foam::DLListBase::endConstIter by linking to __imp___ZN4Foam10DLListBase12endConstIter rt) Info: resolving Foam::SLListBase::endConstIter by linking to __imp___ZN4Foam10SLListBase12endConstIter rt) Info: resolving Foam::Vector<double>::zeroby linking to __imp___ZN4Foam6VectorIdE4zeroE (auto-import) Info: resolving Foam::GeometricField<double,>::debugby linking to __imp___ metricFieldIdNS_12fvPatchFieldENS_7volMeshEE5debug E (auto-import) Info: resolving Foam::Info by linking to __imp___ZN4Foam4InfoE (auto-import) Info: resolving Foam::pTraits<double>::zeroby linking to __imp___ZN4Foam7pTraitsIdE4zeroE (auto-import) Info: resolving Foam::cyclicPolyPatch::typeName by linking to __imp___ZN4Foam15cyclicPolyPatch8typeName rt) Info: resolving Foam::cloud::debug by linking to __imp___ZN4Foam5cloud5debugE (auto-import) Info: resolving Foam::DLListBase::endIter by linking to __imp___ZN4Foam10DLListBase7endIterE (auto-impo Info: resolving Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>::debugby linki __ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPat chFieldENS_7volMeshEE5debugE (auto-import) Info: resolving Foam::FatalIOError by linking to __imp___ZN4Foam12FatalIOErrorE (auto-import) Info: resolving Foam::Warning by linking to __imp___ZN4Foam7WarningE (auto-import) Info: resolving Foam::Vector<double>::typeNameby linking to __imp___ZN4Foam6VectorIdE8typeNameE (auto-import Info: resolving Foam::pTraits<double>::typeNameby linking to __imp___ZN4Foam7pTraitsIdE8typeNameE (auto-impo Info: resolving Foam::fvPatchField<foam::vector<double> >::debugby linking to __imp___ZN4Foam12fvPatchFieldI EEE5debugE (auto-import) Info: resolving Foam::fvPatchField<foam::vector<double> >::patchConstructorTablePtr_by linking to __imp___ZN chFieldINS_6VectorIdEEE25patchConstructorTablePtr_ E (auto-import) Info: resolving Foam::fvPatchField<double>::debug by linking to __imp___ZN4Foam12fvPatchFieldIdE5debugE (aut Info: resolving Foam::fvPatchField<double>::patchConstructorTableP tr_ by linking to __imp___ZN4Foam12fvPatc atchConstructorTablePtr_E (auto-import) Info: resolving Foam::fvPatchField<double>::dictionaryConstructorT ablePtr_ by linking to __imp___ZN4Foam12f dE30dictionaryConstructorTablePtr_E (auto-import) Info: resolving Foam::fvPatchField<double>::disallowDefaultFvPatch Field by linking to __imp___ZN4Foam12fvPa 7disallowDefaultFvPatchFieldE (auto-import) Info: resolving Foam::emptyPolyPatch::typeName by linking to __imp___ZN4Foam14emptyPolyPatch8typeNameE ) Info: resolving Foam::word::null by linking to __imp___ZN4Foam4word4nullE (auto-import) Info: resolving Foam::dimless by linking to __imp___ZN4Foam7dimlessE (auto-import) Info: resolving Foam::fvPatchField<foam::vector<double> >::dictionaryConstructorTablePtr_by linking to __imp fvPatchFieldINS_6VectorIdEEE30dictionaryConstructo rTablePtr_E (auto-import) Info: resolving Foam::fvPatchField<foam::vector<double> >::disallowDefaultFvPatchFieldby linking to __imp___ atchFieldINS_6VectorIdEEE27disallowDefaultFvPatchF ieldE (auto-import) Info: resolving Foam::Time::controlDictName by linking to __imp___ZN4Foam4Time15controlDictNameE (auto- Info: resolving Foam::polyMesh::defaultRegion by linking to __imp___ZN4Foam8polyMesh13defaultRegionE (a Info: resolving Foam::fileName::debug by linking to __imp___ZN4Foam8fileName5debugE (auto-import) Info: resolving Foam::IOstream::currentVersion by linking to __imp___ZN4Foam8IOstream14currentVersionE ) Info: resolving vtable for Foam::IOdictionaryby linking to __imp___ZTVN4Foam12IOdictionaryE (auto-import)" Would you given me any further information. Thanks for above suggestions! regards Q.Li |
April 24, 2006, 23:48 |
Is there some reason that you
Is there some reason that you think there's still something wrong? Those are all "Info" messages, not error messages, and are perfectly normal.
Did you check to see if a new foamToGMV.exe file got created? (If you are still having errors as well as the info messages that you posted, the reason is probably because your previous compilation attempts deleted the original libOpenFOAM.dll file, and you haven't replaced it by recompiling it. But you need to post the error messages, not the info messages, for me to tell. If there are a lot of them, just post the first few.) |
April 25, 2006, 00:09 |
haha! you are right. Just as w
Qiang Li
Rep Power: 17 |
haha! you are right. Just as what you said, libOpenFOAM.dll file had been deleted. Now I re-construct it and all package have worked perfectly.
Thank you for your contributions to OpenFOAM community. Good luck to you! Q.Li |
How can I build OpenFOAM in cygwin | joywe | OpenFOAM Installation | 10 | September 12, 2008 10:39 |
OpenFoam under Cygwin | NeaZen | Main CFD Forum | 3 | January 21, 2007 13:32 |
OpenFOAM Cygwin port updated to 13 | brooksmoses | OpenFOAM Installation | 29 | November 30, 2006 06:49 |
cygwin | Adam M | FLUENT | 1 | July 16, 2006 12:54 |
Cygwin B20 /tmp | sean | CFX | 0 | October 22, 2000 01:22 |
