April 28, 2006, 05:49 |
i'm obviously doing something
Jonathan Gerald Pelham
Rep Power: 17 |
i'm obviously doing something wrong but i'm to much of a newbie to know how to fix it
it looks like the bashrc but i have no idea how to edit that over ssh Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: comp26 OS: Linux version 2.6.9-22.0.1.ELsmp User: mea02jgp User_config: /home1/me/mea02jgp/.bashrc FATAL ERROR: /home1/me/mea02jgp/.OpenFOAM-1.3/bashrc does not appear to be sourced from: /home1/me/mea02jgp/.bashrc You need the following at the end of your /home1/me/mea02jgp/.bashrc file: . /home1/me/mea02jgp/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc or equivalent depending on the location of the OpenFOAM installation. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /home1/me/mea02jgp/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 3.4.3 WARNING: Conflicting installations: foam settings: /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.5.0_05 WARNING: Conflicting installations: foam settings: /usr/local/packages/java/jdk1.5.0_05/bin/java current path : /usr/local/packages/java/jdk1.5.0_05/bin//java gzip 1.3.3 /bin/gzip tar 1.3.3 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_comp26 Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- The system test has evoked 1 fatal error(s). The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. |
April 28, 2006, 07:14 |
look at that part:
FATAL ER
Markus Hartinger
Rep Power: 17 |
look at that part:
FATAL ERROR: /home1/me/mea02jgp/.OpenFOAM-1.3/bashrc does not appear to be sourced from: /home1/me/mea02jgp/.bashrc You need the following at the end of your /home1/me/mea02jgp/.bashrc file: . /home1/me/mea02jgp/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc or equivalent depending on the location of the OpenFOAM installation. |
April 28, 2006, 08:07 |
Markus Hartinger
Rep Power: 17 |
use vi, not my favourite, but it is installed on any system |
April 28, 2006, 12:32 |
cool i've nailed the bashrc pr
Rep Power: 17 |
cool i've nailed the bashrc problem but it still isn't recognising commands such as blockMesh
i think its because the gcc compiler is out of date or something like that |
April 28, 2006, 13:14 |
If you make sure your director
Mattijs Janssens
Rep Power: 26 |
If you make sure your directory structure is exactly like
http://www.opencfd.co.uk/openfoam/linux.html and then unpack (tar xzf ...) all, the whole setup should work once you do that . /home1/me/mea02jgp/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc |
May 12, 2006, 18:42 |
is there any way to change the
Rep Power: 17 |
is there any way to change the install path?
i tried messing with the bashrc file in .openfoam-1.2 but that dosen't seem to have worked |
Problem in installing OpenFoam15x | mmjhuang | OpenFOAM Installation | 3 | March 24, 2009 04:25 |
Problem installing OpenFOAM 141 | sachin | OpenFOAM Installation | 2 | February 22, 2008 10:20 |
Problems installing OpenFoam on a 64bit machine | jango | OpenFOAM Installation | 1 | June 4, 2007 14:53 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 0 | April 28, 2006 05:45 |
problem about installing FOAM | linux freshman | Main CFD Forum | 6 | November 4, 2004 10:59 |
