June 1, 2006, 20:51 |
I am having some troubl
I am having some trouble with my OF installation. I got the systems admin to install OF in the usr/local/ directories because it won't fit in my $HOME directory (not enough allocated space). But the problem with this is that when i try to run FoamX it gives me this error: tera35:~> Starting NameServer with inet:tera35:1234 ... error: cannot open output file /usr/local/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/apps/FoamX/ns.ref and it just hangs. Would i be right to say that its because as a user i can't write to the usr/local/ directories that this is why i'm getting the error?? Or am i way off and it is some other problem? Any help would be great Thanks Simon |
June 2, 2006, 05:49 |
If you are running a 'central'
Mattijs Janssens
Rep Power: 26 |
If you are running a 'central' installation (i.e. not under your home directory) copy the .OpenFOAM-1.3 directory to your home directory and 'source' the ~/.OpenFOAM-1.3/bashrc instead.
Having a local setup directory instructs FoamX to use that space for writing any files. |
Problem with starting FoamX | laker | OpenFOAM Installation | 2 | May 13, 2008 10:34 |
Problem about FoamX | williamscn | OpenFOAM Installation | 8 | September 18, 2007 00:18 |
FoamX problem | richardhsieh | OpenFOAM Installation | 4 | September 17, 2007 23:41 |
Problem running FoamX | ianz8802 | OpenFOAM Installation | 11 | March 23, 2007 12:22 |
FoamX problem | joegi | OpenFOAM Installation | 8 | November 5, 2006 07:06 |
