Error while loading shared libraries libstdcso6
Old   August 9, 2006, 14:07
Default I installed V1.3 succesfully f
Maka Mohu
maka is on a distinguished road
I installed V1.3 succesfully from binary on my workstation Fedora 2 but when I install on our linux cluster (gentoo), I get the following error message:
blockMesh: error while loading shared libraries: libstdc++.so.6: cannot handle TLS data.
I passed both foamSystemCheck and foamInstallationCheck tests.
I installed previously V1.1 and 1.2 on this cluster with no problem.
I tried to compile OpenFOAM V1.3 using ./Allwmake but I got some errors and the executables was not generated. Previously, I compiled V1.1 and V1.2 with no problems.
Some of the Errors while compiling:
SOURCE_DIR=chemistryReaders/chemkinReader
SOURCE=chemistryReaders/chemkinReader/chemkinLexer.L ; foamFlex++ -f $SOURCE ; mv lex.yy.cc Make/linuxGcc4DPOpt/chemkinLexer.C ; g++ -m32 -Dlinux -DDP -Wa
ll -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/maka/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/ho
me/maka/OpenFOAM/OpenFOAM-1.3/src/thermophysicalModels/basic/lnInclude -I/home/maka/OpenFOAM/OpenFOAM-1.3/src/thermophysicalModels/specie/lnInclude -
I/home/maka/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c Make/linuxGcc4DPOpt/chemkinLexer.C -o Make/linuxGcc4DPOpt/
chemkinLexer.o
/bin/sh: foamFlex++: command not found
mv: cannot stat `lex.yy.cc': No such file or directory
g++: Make/linuxGcc4DPOpt/chemkinLexer.C: No such file or directory
g++: no input files
make: *** [Make/linuxGcc4DPOpt/chemkinLexer.o] Error 1
SOURCE_DIR=.
SOURCE=laplacianFoam.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/maka/Op
enFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/maka/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o
Make/linuxGcc4DPOpt/laplacianFoam.o
/home/maka/OpenFOAM/OpenFOAM-1.3/wmake/bashScripts/mkObjectDir /home/maka/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/laplacianFoam
g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/maka/OpenFOAM/OpenFOAM-1.3/src/fi
niteVolume/lnInclude -I/home/maka/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread Make/linuxGcc4DPOpt/laplacianFoam.o -L/
home/maka/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt \
-lfiniteVolume -lOpenFOAM -liberty -o /home/maka/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/laplacianFoam
/home/maka/OpenFOAM/linux/gcc-4.1.0/bin/../lib/gcc/i686-pc-linux-gnu/4.1.0/../.. /../libstdc++.so: undefined reference to `___tls_get_addr'
collect2: ld returned 1 exit status
make: *** [/home/maka/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/laplacianFoam] Error 1
Can anybody help spot the error.
best regards,
Maka
maka is offline   Reply With Quote
Old   August 10, 2006, 14:15
Default I attach here the result of fo
Maka Mohu
I attach here the result of foamInstallationTest, see the following:
Executing /home/maka/OpenFOAM/OpenFOAM-1.3/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: troma
OS: Linux version 2.4.25
User: maka
User_config: /home/maka/.bashrc
Foam_config: /home/maka/.OpenFOAM-1.3/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/maka/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/maka/OpenFOAM/maka-1.3 yes no
$FOAM_JOB_DIR /home/maka/OpenFOAM/jobControl yes yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/maka/OpenFOAM/OpenFOAM-1.3 yes yes yes
$FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes no
$FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes yes
$WM_DIR .../maka/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH ...maka/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...nFOAM/maka-1.3/lib/linuxGcc4DPOpt yes yes no
Software versions
Software Version Location
gcc 4.1.0 /home/maka/OpenFOAM/linux/gcc-4.1.0/bin/gcc
java 1.4.2_05 /home/maka/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
head: `-1' option is obsolete; use `-n 1' since this will be removed in the future
gzip 1.3.5 /bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...M/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_troma Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
Old   August 11, 2006, 05:24
Default Looks like your C++ compiler d
Mattijs Janssens
mattijs is on a distinguished road
Looks like your C++ compiler does not compile correctly (undefined reference to `___tls_get_addr' )
Try recompiling gcc from sources and see if you can compile&/link any (non-Foam) c++ program.
mattijs is offline   Reply With Quote
error while loading shared libraries: libXm.so.3 Renato Pacheco FLUENT 3 July 3, 2008 13:48
gambit "error while loading shared libraries" ggrant FLUENT 1 June 25, 2008 11:37
FoamXHostBrowser error while loading shared libraries libFoamXso cannot restore segment prot after reloc Permission denied mdmk OpenFOAM Pre-Processing 0 June 25, 2008 01:50
error while loading shared libraries: libXm.so.3 Emiliano FLUENT 1 September 5, 2007 21:03
Error when loading a shared library rid FLUENT 4 May 29, 2006 15:51
