ERROR IN RUNNING THE FIRST EXAMPLE
Old   August 16, 2006, 05:21
Default Hi I installed openfoam acco
Marhamat Zeinali
marhamat is on a distinguished road
Hi
I installed openfoam according to the readme.
but when i want to run the firs example,i can't find icFoam blockMesh.cavity according to step 6.
Please help me .
Thanks.
marhamat is offline   Reply With Quote
Old   August 16, 2006, 07:24
Default Did you run foaminstlationchec
futoshi tanaka
ftanaka is on a distinguished road
Did you run foaminstlationcheck?
How about that result?
ftanaka is offline   Reply With Quote
Old   August 16, 2006, 07:59
Default Dear Marhamat, What error did
David Palko
davidpalko is on a distinguished road
Dear Marhamat,
What error did you get? can you copy and paste it here?
davidpalko is offline   Reply With Quote
Old   August 16, 2006, 16:49
Default Hi everybody. I correct the t
Marhamat Zeinali
Hi everybody.
I correct the topic in this page.There is no error, but i can't run the first example.
After installation test,i don't receive any message.
I add that there is firs time of linux installation in my pc.
Thank you very much.
Old   August 17, 2006, 05:41
Default Hi Marhamat, First of all,
David Palko
Hi Marhamat,
First of all, it's a bit strange you did not get any message after running foamInstalationTest. In a case you installed it correctly, you have to have at least positive response
(at the end it's written:
Base configuration ok.
Critical systems ok.
Did you get that? If yes, type to terminal:
cd $HOME/OpenFOAM/${LOGNAME}-1.3/run/tutorials/icoFoam
and type: blockMesh . cavity (please note that there are spaces before and after dot.) When you do that, what response do you get?
Another question: What linux distribution you use?
Old   August 17, 2006, 07:51
Default Hi David, I try to install Op
Marhamat Zeinali
Hi David,
I try to install OpenFoam again .
I use Redhat 9.0.
Thank you.
Old   August 19, 2006, 03:52
Default Hi After running foaminstala
Marhamat Zeinali
Hi
After running foaminstalation Test the realated page was closed.
If that is strange where is the problem.
Thank you.
Old   August 20, 2006, 07:59
Default Just copy/paste the problem he
unoder
Just copy/paste the problem here...
Old   August 27, 2006, 05:13
Default Hi After running foaminstall
Marhamat Zeinali
Hi
After running foaminstallationTest i get error message.
WARNING: Conflicting installations:
foam settings: /home/OpenFOAM/OpenFOAM//gcc-4.0.1/bin/gcc
current path : /usr/local/bin/gcc
CRITICAL ERROR
java *** not installed ***
gzip 1.3.3 /bin/gzip
tar 1.3.3 /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Thank you.
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 15:41
Error running Ansys 11.1 Prash Valluri Main CFD Forum 0 September 29, 2008 10:53
FIDAP RUNNING ERROR "ERROR-DIR-NOT-EMPTY=145" BAOYU FLUENT 0 January 26, 2006 19:32
DPM running error! x.p.lee FLUENT 0 July 3, 2003 06:44
error while running UDF murthy FLUENT 1 October 22, 2001 06:02
