September 9, 2006, 22:29 |
hi~~~~~
my os is fc5~
Bobby
Rep Power: 17 |
hi~~~~~
my os is fc5~~~ When I am installing openfoam follow the document "how to compile > openfoam",I meet a problem. When I use "make" to compile paraview in > "paraview-2.4",the terminal is showed as below: > > [wab@localhost paraview-2.4]$ make > running /bin/sh > "/home/wab/OpenFOAM/linux/paraview-2.4.3/lib/paraview-2.4/Utilities/TclTk/c >onfigure_tcltk.sh" 2>&1 checking whether to use symlinks for manpages... no > checking compression for manpages... no > checking for gcc... gcc > checking for C compiler default output file name... a.out > checking whether the C compiler works... yes > checking whether we are cross compiling... no > checking for suffix of executables... > checking for suffix of object files... o > checking whether we are using the GNU C compiler... yes > checking whether gcc accepts -g... yes > checking for gcc option to accept ANSI C... none needed > checking how to run the C preprocessor... gcc -E > checking for egrep... grep -E > checking for ANSI C header files... yes > checking for sys/types.h... yes > checking for sys/stat.h... yes > checking for stdlib.h... yes > checking for string.h... yes > checking for memory.h... yes > checking for strings.h... yes > checking for inttypes.h... yes > checking for stdint.h... yes > checking for unistd.h... yes > checking for unistd.h... (cached) yes > checking limits.h usability... yes > checking limits.h presence... yes > checking for limits.h... yes > checking for building with threads... no (default) > checking if the compiler understands -pipe... yes > checking for required early compiler flags... _LARGEFILE64_SOURCE > checking for 64-bit integer type... long long > checking for struct dirent64... no > checking for struct stat64... yes > checking for off64_t... yes > checking whether byte ordering is bigendian... no > checking for getcwd... yes > checking for opendir... yes > checking for strstr... yes > checking for strtol... yes > checking for strtoll... yes > checking for strtoull... yes > checking for tmpnam... yes > checking for waitpid... yes > checking for strerror... yes > checking for getwd... yes > checking for wait3... yes > checking for uname... yes > checking for realpath... yes > checking dirent.h... yes > checking errno.h usability... yes > checking errno.h presence... yes > checking for errno.h... yes > checking float.h usability... yes > checking float.h presence... yes > checking for float.h... yes > checking values.h usability... yes > checking values.h presence... yes > checking for values.h... yes > checking for limits.h... (cached) yes > checking for stdlib.h... (cached) yes > checking for string.h... (cached) yes > checking sys/wait.h usability... yes > checking sys/wait.h presence... yes > checking for sys/wait.h... yes > checking dlfcn.h usability... yes > checking dlfcn.h presence... yes > checking for dlfcn.h... yes > checking for unistd.h... (cached) yes > checking sys/param.h usability... yes > checking sys/param.h presence... yes > checking for sys/param.h... yes > checking sys/modem.h usability... no > checking sys/modem.h presence... no > checking for sys/modem.h... no > checking termios vs. termio vs. sgtty... termios > checking for fd_set in sys/types... yes > checking whether struct tm is in sys/time.h or time.h... time.h > checking sys/time.h usability... yes > checking sys/time.h presence... yes > checking for sys/time.h... yes > checking whether time.h and sys/time.h may both be included... yes > checking for struct tm.tm_zone... yes > checking for gmtime_r... yes > checking for localtime_r... yes > checking tm_tzadj in struct tm... no > checking tm_gmtoff in struct tm... yes > checking long timezone variable... yes > checking for struct stat.st_blksize... yes > checking for fstatfs... yes > checking for working memcmp... yes > checking for memmove... yes > checking proper strstr implementation... yes > checking for strtoul... yes > checking for strtod... yes > checking for strtod... (cached) yes > checking for Solaris2.4/Tru64 strtod bugs... ok > checking for mode_t... yes > checking for pid_t... yes > checking for size_t... yes > checking for uid_t in sys/types.h... yes > checking for socklen_t... yes > checking for opendir... (cached) yes > checking union wait... yes > checking for strncasecmp... yes > checking for BSDgettimeofday... no > checking for gettimeofday... yes > checking for gettimeofday declaration... present > checking whether char is unsigned... no > checking signed char declarations... yes > checking for a putenv() that copies the buffer... no > checking langinfo.h usability... yes > checking langinfo.h presence... yes > checking for langinfo.h... yes > checking whether to use nl_langinfo... yes > checking for sin... no > checking for main in -lieee... yes > checking for main in -linet... no > checking net/errno.h usability... no > checking net/errno.h presence... no > checking for net/errno.h... no > checking for connect... yes > checking for gethostbyname... yes > checking how to build libraries... static > checking for ranlib... ranlib > checking if 64bit support is requested... no > checking if 64bit Sparc VIS support is requested... no > checking system version (for dynamic loading)... > /home/wab/OpenFOAM/linux/paraview-2.4.3/Utilities/TclTk/tcl8.4.5/unix/confi >gure: line 13936: syntax error near unexpected token `)' > /home/wab/OpenFOAM/linux/paraview-2.4.3/Utilities/TclTk/tcl8.4.5/unix/confi >gure: line 13936: ` OSF*)' -- Checking old streams end-of-file bug level > -- Checking old streams end-of-file bug level - failed to compile test > -- Finding Atomic Data Sizes > -- Finding a 64 Bit Integer > -- Configuring done > -- Generating done > -- Build files have been written to: > /home/wab/OpenFOAM/linux/paraview-2.4.3/lib/paraview-2.4 gmake: *** can not > found makefile。 stop。 > make[2]: *** [maketcltk] error 1 > make[1]: *** [Utilities/TclTk/CMakeFiles/maketcltk.dir/all] error 2 > make: *** [all] error 2 > [wab@localhost paraview-2.4]$ > > > so, please help me ~~~thank you again~~! |
September 11, 2006, 04:53 |
Excuse my ignorance: fc5 is Fe
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Excuse my ignorance: fc5 is Fedora Core 5? I'm just confused because it fails at a part completely unrelated to that OS.
Just a wild guess (but you havn't given us too much information to work with): it might be an issue with the shell (/bin/sh should be bash). I had problems with a Fedora Core 5 installation where suddently third-party shell-scripts that used to work started failing. You've always got to keep in mind that Fedora is bleeding edge.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
September 11, 2006, 08:24 |
Take a look at this document:
Martin Beaudoin
Rep Power: 22 |
http://www.cdlact.unileoben.ac.at/non_cdl/OpenFOAMWiki/index.php/Howto_compile_O penFOAM#Patching_Tcl.2FTK_.28optional.29 It is a bug in the Tcl/Tk config files affecting systems running bash version 3.1 or later. Cheers. Martin |
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 06:06 |
Differences OpenFOAM12 and OpenFOAM13 | lr103476 | OpenFOAM Running, Solving & CFD | 43 | July 22, 2008 17:46 |
Problems in OpenFOAM13 srcthermophysicalmodelsliquid | aderliner | OpenFOAM Running, Solving & CFD | 1 | March 18, 2007 02:33 |
What is wrong with the OpenFOAM13 on Cygwin151 | waynezw0618 | OpenFOAM Installation | 0 | November 6, 2006 21:31 |
Problem with LinuxIA64 installation of OpenFOAM13 | antares | OpenFOAM Installation | 0 | May 25, 2006 13:19 |
