Help with Solving Critical Errors
Old   October 7, 2006, 20:58
Default Hello again. I have finally
Andrew Lindsay
andrewlindsay is on a distinguished road
Hello again.
I have finally managed to get the files to download correctly and hopefully I have installed all the files.
Now I am getting the following when I run the check installation.
Hoe do I resolve these critical errors?
Checking basic setup...
Shell: bash
Host: Linux-Lindsay
OS: Linux version 2.6.16.21-0.25-default
User: andrew.lindsay
User_config: /home/andrew.lindsay/.bashrc
Foam_config: /home/andrew.lindsay/.OpenFOAM-1.3/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/andrew.lindsay/OpenFOAM yes yes
$WM_PROJECT_USER_DIR ....lindsay/OpenFOAM/andrew.lindsay-1.3 yes no
$FOAM_JOB_DIR /home/andrew.lindsay/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR ...andrew.lindsay/OpenFOAM/OpenFOAM-1.3 yes no yes
$FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes no no
$FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes no yes
$WM_DIR ....lindsay/OpenFOAM/OpenFOAM-1.3/wmake yes no yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH ...lindsay/OpenFOAM/linux/j2sdk1.4.2_05 no no
$MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes no yes
$LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes no yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes no yes
$FOAM_USER_LIBBIN ...ndrew.lindsay-1.3/lib/linuxGcc4DPOpt yes no no
Software versions
Software Version Location
gcc 4.1.0
WARNING: Conflicting installations:
foam settings: /home/andrew.lindsay/OpenFOAM/linux/gcc-4.1.0/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
java 1.4.2_11
foam settings: /home/andrew.lindsay/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
current path : /usr/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_Linux-Lindsay Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
andrewlindsay is offline   Reply With Quote
Critical errors gcc and icoFoam during installation of 15 quartzian OpenFOAM Installation 3 December 12, 2008 13:42
2 critical errors shuo OpenFOAM Installation 1 November 11, 2008 05:32
Critical errors on gcc and icofoam giuliano OpenFOAM Installation 4 June 25, 2008 14:31
critical re jj Main CFD Forum 5 July 29, 2006 00:06
Critical Re value Asok Main CFD Forum 0 October 18, 2002 01:29
