FoamX Java problem
Old   March 31, 2005, 16:57
Default Hi all, First of all thanks
Kristoffer Grande
kris is on a distinguished road
Hi all,
First of all thanks for a lot of useful messages here, they helped me through the installation.
Now,
My installation is working, except I cannot run FoamX. I get the following message:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/kgrande/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1503)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at sun.security.action.LoadLibraryAction.run(LoadLibr aryAction.java:50)
at java.security.AccessController.doPrivileged(Native Method)
at sun.awt.NativeLibLoader.loadLibraries(NativeLibLoa der.java:38)
at sun.awt.DebugHelper.<clinit>(DebugHelper.java:29)
at java.awt.Component.<clinit>(Component.java:506)
/home/kgrande/OpenFOAM/OpenFOAM-1.1/bin/runFoamXHB: line 131: 7295 Killed FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 7291
libawt.so is where it should be, but I can't find libXp.so.6 . Is that supposed to be inside libawt.so, or somewhere else?
I have tried to install Java again, even a newer version from the java website. But I still get the same problem.
does anyone have any hints on what to do next? I am running Fedora 3.
Sorry to say I am not a linux expert...
Thanks,
Kris
kris is offline   Reply With Quote
Old   April 1, 2005, 05:23
Default Try installing libXp.so.6.
Mattijs Janssens
mattijs is on a distinguished road
This is a system library (my man page says: libXp - X Print Client Library). Java seems to require this library.
mattijs is offline   Reply With Quote
Old   April 15, 2005, 07:15
Default Hi, I have a similiar probl
Billy
billy is on a distinguished road
I have a similiar problem running FoamX. When I run it, an error occurs also at line 131 like yours. See "Segmentation fault" topic. What system are you using. I had this problem on a laptop.
billy is offline   Reply With Quote
Old   November 1, 2005, 17:14
Default Possibly somewhat belated, but
jaelwyn
Possibly somewhat belated, but in case anyone else is running into this:
For current Debian systems this lives in the libxp6 package (and should be installed automatically if you use the existing tools to generate a Debian package based on the Sun J2SDK 1.4.2_05, and install that via the packaging system).
It appears to come from the standard X builds, so I suspect that using the auto-searching RPM tools (up2date? I haven't used RH much recently) to look for one providing the file /usr/lib/libXp.so.6, or for the X Windows / xprint packages, should produce something useful.
Old   February 26, 2006, 19:48
Default Hi, I am also not a linux expe
nfoxley
Hi, I am also not a linux expert and all the help given is far too technical for me to understand. When I search online for the packages suggested, I am left even more baffled. I am having the exact same problem as the very 1st message in this thread. I would really appreciate it if someone could explain in really plain English what I should do, how I should do this and where I can go for whatever they suggest! Many Thanks.
Old   October 31, 2006, 10:50
Default Hej, I have problem with libX
mss
Hej,
I have problem with libXp.so.6
It is located /usr/X11R6/lib/libXp.so.6
When i type FoamX, it gives an error ... libXp.so.6: cannot open shared object file: No such file or directory
What I should do?
thank u,
Rita
Old   October 31, 2006, 13:18
Default Hello, I could probably hel
Philippose Rajan
philippose will become famous soon enough
I could probably help you if I knew what distribution of Linux you are using...
For example, if you are using the Fedora Core, there are two RPMs you need to install:
libXp
libXp-devel
And Rita, It looks like the location of your libXp.so.6 is not right... usually this file is found in
/usr/lib/
As long as it is in one of the locations which are looked into when a program tries to load libraries at run time, its ok... but from the error message, I dont think
/usr/X11R6/lib/
is one of those locations in the path.
It should work if you either copy that file to /usr/lib, or make a symbolic link:
ln -s /usr/X11R6/lib/libXp.so.6 /usr/lib/libXp.so.6
Try that out.
Usually the libXp installation package should be present in your Linux install CDs... it may not be installed by default.
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   October 31, 2006, 14:09
Default Thank you very much Philippose
mss
Thank you very much Philippose.
I made a link, as u said and now it is working.
THANK YOU!!!!
Rita
Old   October 31, 2006, 15:34
Default Hej, Now I faced with anothe
mss
Hej,
Now I faced with another problem:
HostBrowser running.....
Using jar /home/Administrator/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/F oamX/lib/FoamX.jar
Using jar /home/Administrator/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/F oamX/lib/jlfgr-1_0.jar
FoamX.Exceptions.FoamXException: Default name service could not be contacted.
at FoamX.App.initialiseHostBrowser(App.java:512)
at FoamX.App.initialise(App.java:343)
at FoamX.App.main(App.java:186)
Do you know how to fix it?
thanks again for your kind help!
Rita
Old   October 31, 2006, 17:01
Default Hi again, Ok... this is an
Philippose Rajan
Hi again,
Ok... this is an error I had a few days ago, and I hope I can generalise the reason to your case too :-)!
The FoamX and runFoamXHB scripts wont work if the hostname of your linux installation is "localhost" or "localhost.localdomain"
So basically, to get past this error, you need to give your machine a name other than the default "localhost" that Linux puts in.
One way to change the hostname is to use the command at the command-line:
hostname the_new_hostname
In my case, this did not work after a reboot, and to make it a permanent change, I had to change the network settings through the "KDE->Administration->Network" interface (I use KDE).
If you are also using KDE... you need to enter a host name in the "DNS" tab of the network settings, and in the "Hosts" tab you need to add a new line with:
127.0.0.1 the_new_hostname localhost
for the "IP", the "Name" and "Aliases" respectively.
And...dont forget to save at the end, and either restart your network layer with:
/sbin/service network restart
at the command line, or restart the computer.
If you are using Gnome, I am sure there is an equivalent method of varying the network settings.
Once you are done with the restart...try:
ping the_new_hostname
and
ping localhost
and
ping 127.0.0.1
If all those three work...then I am fairly sure FoamX will work.
Philippose
Old   November 6, 2006, 08:59
Default Hej Philippose, I did what yo
  #11
mss
Hej Philippose,
I did what you said and I did some changes.
I have add the IP address in two files:
/etc/hosts
and in
/etc/resolve.conf
and made the link:
ln -s hosts /etc/sysconfig/networking/profile/default/hosts
but I still recive the same error message.
Do you have any idea what I am doing wrong?
Thank you for help,
Rita
Old   November 6, 2006, 09:56
Default I am new openfoam-user. I have
  #12
Faroque Hossain
faroque is on a distinguished road
I am new openfoam-user. I have just installed Openfoam in my system. While I type FoamX in the console I am getting following message--
Cannot find JDK at /usr/java/jdk1.4. Please set JAVA_PATH to the JDK installation directory.
I don't have any idea how to set the JAVA_PATH to the JDK installation directory. It would be great if I get suggestions from you.
Thanks in Advance.
Faroque
faroque is offline   Reply With Quote
Old   November 6, 2006, 10:11
  #13
mss
Hej Philippose,
/etc/hosts
and in
/etc/resolve.conf
and made the link:
Thank you for help,
Rita
Old   November 13, 2006, 09:15
Default sous bash (+linux) export J
  #14
darthnico
sous bash (+linux)
export JAVA_PATH=/usr/local/... en fait l'endroit ou tu as detarre le java disponible sur le site d'openfoam...
Sinon consulte un ingenieur systeme...
bonne chance...
Old   November 13, 2006, 09:46
Default excuse for the french... I am
  #15
darthnico
excuse for the french... I am a little tired I think...
export JAVA_PATH=/usr/local/... more exactly where you have unpacked j2sdk1.4.2_05.linux.tgz
you also seem to be a new linux user...
(try to find a introduction to linux somewhere to learn what environnement variable are...etc...)
Sincerely...
Old   February 5, 2012, 15:04
Default Erroe in JAVA_PATH to the JDK installation directory
  #16
hhh
kunar
hhh is on a distinguished road
Dear foamers,
i try to run Foamx but its shows error like Please set JAVA_PATH to the JDK installation directory, i download and extract this j2sdk1.4.2_05.linux.tgz, please give me idea about this problem.
Warm Regards,
hhh
hhh is offline   Reply With Quote
Old   February 5, 2012, 15:08
  #17
hhh
kunar
Dear foamers,
i try to run Foamx but its shows error like Cannot find JDK at /home/toshiba/OpenFOAM/linux/j2sdk1.4.2_05. Please set JAVA_PATH to the JDK installation directory, i already download and extract this j2sdk1.4.2_05.linux.tgz, please give me idea about this problem.
Warm Regards,
hhh
Old   February 6, 2012, 18:24
Retired Super Moderator
Bruno Santos
Greetings hhh,
Before continuing, please read the following section: The FoamX case manager @ openfoamwiki.net
If you truly want revive/resurrect FoamX, please start a new thread here: http://www.cfd-online.com/Forums/openfoam-installation/
If you want to work with or help develop more modern GUIs for OpenFOAM, search for Discretizer and enGrid: http://openfoamwiki.net/index.php/GUI
Best regards,
Bruno
FoamX and Java Issues olih OpenFOAM Installation 5 March 30, 2008 18:22
FoamX problem richardhsieh OpenFOAM Installation 4 September 17, 2007 23:41
Java error while starting FoamX erydj OpenFOAM Pre-Processing 2 May 4, 2007 09:53
FoamX problems with Java and Locale setting AMD64 geimerma OpenFOAM Installation 5 July 7, 2006 17:21
Java error while starting FoamX cfdengineering OpenFOAM Pre-Processing 16 June 28, 2006 21:02
