Please report this bug
Old   December 7, 2006, 14:20
Default I moved OpenFOAM to our new cl
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
I moved OpenFOAM to our new cluster. Everything runs fine when using the AMD64 precompiled binaries. However, if I try to compile something, I get an error, including a statement, "Please report this bug," (see example below when compiling foamToTecplot). Questions:
1. Is this statement coming from wmake/OF, or from the g++ compiler?
2. Is this really a bug?
3. Has anyone seen this before? What is the solution?
Thanks, Eric
Making dependency list for source file foamToTecplot.C
SOURCE_DIR=.
SOURCE=foamToTecplot.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/egp11/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/egp11/OpenFOAM/OpenFOAM-1.3/src/cfdTools/lnInclude -I/home/egp11/OpenFOAM/OpenFOAM-1.3/src/meshTools/lnInclude -I/home/egp11/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/foamToTecplot.o
/tmp/ccG3f0di.s: Assembler messages:
/tmp/ccG3f0di.s:13: Internal error, aborting at ../../gas/config/tc-i386.c line 3500 in output_imm
Please report this bug.
make: *** [Make/linuxGcc4DPOpt/foamToTecplot.o] Error 1
egp is offline   Reply With Quote
Old   December 7, 2006, 14:32
Default You have broken the assembler,
Hrvoje Jasak
You have broken the assembler, which is very interesting indeed. Is it reproducable, have you compiled gcc locally, what do:
which as
and
which ld
say?
Hrv
Hrvoje Jasak
Old   December 7, 2006, 14:44
Default Hi Hrv, It is reproducable
egp
egp's Avatar
Eric Paterson
Hi Hrv,
It is reproducable in that I get a similar message when trying to compile anything.
No, I have not compiled gcc locally.
The which commands give:
[egp11@uwe-eb foamToTecplot]$ which as
/usr/bin/as
[egp11@uwe-eb foamToTecplot]$ which ld
/usr/bin/ld
Eric
Old   December 8, 2006, 03:06
Default Eric For me it is strange t
Jens Klostermann
jens_klostermann is on a distinguished road
Eric
For me it is strange that your compiler is compiling in 32 bit when you are using a 64 bit cluster?
Did you put export WM_64=1 in your ~/.bashrc?
What gives gcc -v?
Jens
jens_klostermann is offline   Reply With Quote
Old   December 8, 2006, 13:48
Default Jens, Thanks for the hint!
egp
egp's Avatar
Eric Paterson
Jens,
Thanks for the hint! Someone else installed the binaries, and by mistake used the 32-bit version. I copied their OpenFOAM directory without looking and got burned...
I installed the 64-bit versions, and everything now works fine (and my first utlity and solver mods compile and link just fine!).
Eric
Old   December 8, 2006, 13:56
egp
egp's Avatar
Eric Paterson
Jens,
Anyway, I've installed the 64-bit versions, and everything now works fine (and my first utlity and solver mods compile and link just fine!).
Eric
CFD report Sami FLUENT 0 April 15, 2008 12:09
Report > Discrete Phase > Report > How to commands Francesco Micchetti FLUENT 1 January 23, 2008 07:10
need a report... CFD Student Main CFD Forum 0 April 3, 2006 16:33
BÚG REPORT for CD Piet Siemens 2 September 20, 2004 03:45
Report Gabry FLUENT 2 December 5, 2003 10:38
