How to compile OpenFOAM from scratch bashrc and cshrc
Old   December 7, 2006, 10:58
Default Hello, I would like to comp
Daniel Tourde - Caelae.se
danieltourde is on a distinguished road
I would like to compile OpenFOAM on my Gentoo x86 linux box from scratch.
The machine has gcc-4.1.1, paraview and java already installed. I am NOT willing to install them again within OpenFOAM (as the wiki page recommends).
I am fighting with the bashrc and cshrc files in OpenFOAM-1.3 and OpenFOAM-1.3/.OpenFOAM-1.3 directories, where PATHS and other environment variables are defined.
Does anyone know how to modify these files in a clean, simple and efficient way in order to use the gcc, binutils, java etc. already installed on a Linux system?
Daniel
danieltourde is offline   Reply With Quote
Old   December 11, 2006, 05:57
Default Hi Daniel! I think the easi
Assistant Moderator
Bernhard Gschaider
Hi Daniel!
I think the easiest way to use the system-installed gcc etc is to just not install the OpenFOAM-supplied gcc (or move it to a location not in the paths). Then there are some unused entries in the PATH-variables, but that doesn't hurt anyone.
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 15, 2006, 10:30
Default Hello Daniel, Regarding gcc
Tomohiro Bessho
tomohiro is on a distinguished road
Hello Daniel,
Regarding gcc, you can use system gcc by defining as follows in ${WM_PROJECT_INST_DIR}/OpenFOAM-1.3/.bashrc
WM_COMPILER_DIR=/usr
it will be valid if your system gcc is in /usr/bin
As for binutils, it will depend on your distribution. All you need to take cake seems to be "demangle.h"
Anyway, please study OpenFOAMWiki well.
tomohiro is offline   Reply With Quote
Trouble sourcing the bashrc for 15x sripplinger OpenFOAM Installation 5 April 7, 2009 15:06
Compile OpenFOAM on Fedora 8 asaha OpenFOAM Installation 1 August 25, 2008 12:41
Bashrc for PS3 Fedora 6 and IBM sdk 21 mgarcia OpenFOAM Installation 0 November 2, 2007 14:24
Max Scratch Space Ravi Siemens 2 May 18, 2007 02:54
What flags to set in cshrc kupiainen OpenFOAM Installation 2 June 8, 2005 08:56
