CORBABAD_OPERATION in compound editor
Old   October 2, 2006, 19:07
Default Hello, I compiled OpenFOAM-1.3
Tomohiro Bessho
tomohiro is on a distinguished road
Hello, I compiled OpenFOAM-1.3 and succeeded in finishing it without error.
But when I edit the parameters with compound editor of Edit Dictionary in blockMesh, error window 'org.omg.CORBA.BAD_OPERATION' appears and following error messages are written in the terminal window.
This error does not occur in all compound editors. (They seems to work correctly in most other compound editors.)
My enviroment is as follows
gcc 4.1.1
JDK j2sdk1.4.2_05(download from OF site)
Where should I correct to work them properly?
Tomohiro
----- Error messages -----
org.omg.CORBA.BAD_OPERATION: vmcid: 0x0 minor code: 0 completed: No
at com.sun.corba.se.internal.corba.AnyImpl.extract_do uble(AnyImpl.java:759)
at FoamX.Util.FoamXAny.anyToString(FoamXAny.java:298)
at FoamX.Util.FoamXAny.toString(FoamXAny.java:68)
at FoamX.Editors.DictionaryEntryEditor.EntryCache.Dic tionaryEntryCache.toString(Dic tionaryEntryCache.java:418)
at javax.swing.table.DefaultTableCellRenderer.setValu e(DefaultTableCellRenderer.jav a:249)
at javax.swing.table.DefaultTableCellRenderer.getTabl eCellRendererComponent(Default TableCellRenderer.java:160)
at FoamX.Editors.DictionaryEntryEditor.DictionaryEntr yCellRenderer.getTableCellRend ererComponent(DictionaryEntryCellRenderer.java:88)
at javax.swing.JTable.prepareRenderer(JTable.java:373 1)
at javax.swing.plaf.basic.BasicTableUI.paintCell(Basi cTableUI.java:1149)
at javax.swing.plaf.basic.BasicTableUI.paintCells(Bas icTableUI.java:1051)
at javax.swing.plaf.basic.BasicTableUI.paint(BasicTab leUI.java:974)
at javax.swing.plaf.ComponentUI.update(ComponentUI.ja va:142)
at javax.swing.JComponent.paintComponent(JComponent.j ava:541)
at javax.swing.JComponent.paint(JComponent.java:808)
at javax.swing.JComponent.paintChildren(JComponent.ja va:647)
at javax.swing.JComponent.paint(JComponent.java:817)
at javax.swing.JViewport.paint(JViewport.java:722)
at javax.swing.JLayeredPane.paint(JLayeredPane.java:5 57)
at javax.swing.JComponent.paintWithOffscreenBuffer(JC omponent.java:4794)
at javax.swing.JComponent.paintDoubleBuffered(JCompon ent.java:4740)
at javax.swing.JComponent.paint(JComponent.java:798)
at java.awt.GraphicsCallback$PaintCallback.run(Graphi csCallback.java:21)
at sun.awt.SunGraphicsCallback.runOneComponent(SunGra phicsCallback.java:60)
at sun.awt.SunGraphicsCallback.runComponents(SunGraph icsCallback.java:97)
at java.awt.Container.paint(Container.java:1312)
at sun.awt.RepaintArea.paint(RepaintArea.java:177)
at sun.awt.motif.MComponentPeer.handleEvent(MComponen tPeer.java:405)
at java.awt.Component.dispatchEventImpl(Component.jav a:3678)
at java.awt.Container.dispatchEventImpl(Container.jav a:1627)
at java.awt.Window.dispatchEventImpl(Window.java:1606 )
at java.awt.Component.dispatchEvent(Component.java:34 77)
at java.awt.EventQueue.dispatchEvent(EventQueue.java: 456)
at java.awt.EventDispatchThread.pumpOneEventForHierar chy(EventDispatchThread.java:2 01)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:151 )
at java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:141 )
at java.awt.Dialog$1.run(Dialog.java:540)
at java.awt.Dialog.show(Dialog.java:561)
at FoamX.Util.RunPanel.editDictButton_ActionPerformed (RunPanel.java:794)
at FoamX.Util.RunPanel.access$100(RunPanel.java:55)
at FoamX.Util.RunPanel$2.actionPerformed(RunPanel.jav a:416)
at javax.swing.AbstractButton.fireActionPerformed(Abs tractButton.java:1786)
at javax.swing.AbstractButton$ForwardActionEvents.act ionPerformed(AbstractButton.ja va:1839)
at javax.swing.DefaultButtonModel.fireActionPerformed (DefaultButtonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultB uttonModel.java:258)
at javax.swing.plaf.basic.BasicButtonListener.mouseRe leased(BasicButtonListener.jav a:245)
at java.awt.Component.processMouseEvent(Component.jav a:5100)
at java.awt.Component.processEvent(Component.java:489 7)
at java.awt.Container.processEvent(Container.java:156 9)
at java.awt.Component.dispatchEventImpl(Component.jav a:3615)
at java.awt.LightweightDispatcher.retargetMouseEvent( Container.java:3483)
at java.awt.LightweightDispatcher.processMouseEvent(C ontainer.java:3198)
at java.awt.LightweightDispatcher.dispatchEvent(Conta iner.java:3128)
at java.awt.Container.dispatchEventImpl(Container.jav a:1613)
at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:145)
at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:137)
at java.awt.EventDispatchThread.run(EventDispatchThre ad.java:100)
tomohiro is offline   Reply With Quote
Old   October 4, 2006, 04:26
Default Can you specify exactly what y
Mattijs Janssens
mattijs is on a distinguished road
Can you specify exactly what you were editing? So case, dictionary (blockMeshDict?) and which field, what value etc. Could be some editing operation is not implemented or the FoamX setup is not correct for the dictionary.
mattijs is offline   Reply With Quote
Old   October 11, 2006, 13:12
Default I'm sorry for the late reply.
Tomohiro Bessho
As long as I checked, this error occurs in blockMesh of any case (including icoFoam). but when I click the 'Edit Dictionary' buttom in the other Foam utilities, compound editor opens properly and works without any problem.
As for editing data, I don't edit any values, which are just copied form the OpenFOAM's source directory. And the result of excuting the blockMesh itself has no problem. (unless clicking the 'Edit dictionary' button, it breaks the data file)
Ayway, what the meaning of the top line of the error log?
Old   October 12, 2006, 13:24
Default I can edit blockMeshDict fine.
Mattijs Janssens
I can edit blockMeshDict fine. Can you check the blockMeshDict with an editor? Remove the 'arguments' entry and try again.
Old   October 13, 2006, 10:52
Default Thank you for your reply. I c
Tomohiro Bessho
I can edit blockMeshDict fine as well.
Comparing to the pre-compiled version, if the case works properly in the precompiled FoamX, the above error occurs in my self-compiled FoamX.
And, as I wrote previously, the result of excuting the blockMesh itself has no problem even in my self-compiled version. the produced mesh data works properly.
My problem seems to be related just to the GUI.
Old   December 15, 2006, 09:22
Default : Finally, I have succeeded
Tomohiro Bessho
[Self-reply]:
Finally, I have succeeded in making FoamX work correctly. In my environment, the following command at L298 in FoamXAnyjava cause the error.
test = format(fxAny_.value.extract_double());
By changing the precision from SP to DP. FoamX works without problem.
Though I don't know whether it is the bug or the special issue which happens only in my case, I submit this result and my environment, since this may help others...
My environment:
CPU: AthlonXP-1800
Mem: 1GB
Distribution: Gentoo
kernel:2.6.19
gcc: 4.1.1(4.1.1-r3)
glibc:2.5
flex:2.5.4a
zlib:1.2.3
Old   December 15, 2006, 09:25
Tomohiro Bessho
[Self-reply]:
By changing the precision from SP to DP, FoamX works without problem.
My environment:
CPU: AthlonXP-1800
Mem: 1GB
kernel:2.6.19
glibc:2.5
flex:2.5.4a
zlib:1.2.3
Old   December 15, 2006, 14:08
Default I do not understand. What did
Mattijs Janssens
I do not understand. What did you change? Any Java?
Or were you using the single precision OpenFOAM version and inputting a number which does not fit into single precision?
Old   December 16, 2006, 21:44
Default I did not change any setting a
Tomohiro Bessho
I did not change any setting about Java, at least after I succeed in making FoamX work properly.
And what I use to test is a tutorial case without any change.
I confirmed the effect of DP <-> SP setting as shown below:
0. (some modifications to avoid compile errors...)
1. compile in DP : O.K.
2. wcleanAll
3. change WM_PRECISION_OPTION from DP to SP
4. source XXX/.OpenFOAM-1.3/bashrc
5. ./Allwmake
6. compile
7. cp XXX/OpenFOAM-1.3/tutorials/* ${HOME}/OpenFOAM /root-1.3/run/tutorials/ -rf
8. TEST : N.G.(org.omg.CORBA.BAD_OPERATION)
9. wcleanAll
10. change WM_PRECISION_OPTION from SP to DP
11. source XXX/.OpenFOAM-1.3/bashrc
12. ./Allwmake
13. compile
14. cp XXX/OpenFOAM-1.3/tutorials/* ${HOME}/OpenFOAM /root-1.3/run/tutorials/ -rf
15. TEST : O.K.
Wiki Editor Harish CFD-Wiki 3 April 14, 2008 18:26
CFX pre command editor error Neser25 CFX 2 October 25, 2005 11:40
Expression Editor Meri CFX 1 June 9, 2004 17:35
Command editor Andrea CFX 2 May 23, 2004 02:00
command editor Atit Koonsrisuk CFX 2 January 13, 2004 04:44
