February 15, 2007, 03:14 |
I have installed openfoam on o
Andreas
Rep Power: 17 |
I have installed openfoam on openSuse 10.2. 32-bit, console tools run fine too, but if I try to start FoamX I get the following error messages:
Starting NameServer with inet:linux-onb5:1234 ... nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory |
February 15, 2007, 04:53 |
nsd is under the Mico tree. Tr
Mattijs Janssens
Rep Power: 26 |
nsd is under the Mico tree. Try to reconfigure and recompile Mico (see the Mico section in $FOAM_SRC/Allwmake)
February 15, 2007, 12:10 |
Hi, Andreas,
Go to YaST in SU
JZ
Rep Power: 17 |
Hi, Andreas,
Go to YaST in SUSE, search and insatll libelf. It works. YaST -> Software -> Software Management I use SUSE 10.1 and have simialr problem, This method can successfully solve the probelm. Good luck! Jack |
How to start FoamX in OF15 | hsieh | OpenFOAM Pre-Processing | 7 | December 29, 2008 02:27 |
CFX Pre don't Start | Pascal | CFX | 1 | February 22, 2007 07:41 |
A new RunFoamXHB problem canbt start FoamX | alondono | OpenFOAM Pre-Processing | 0 | January 26, 2007 23:14 |
Where do I start | Akin | Siemens | 1 | June 16, 2005 18:15 |
Cannot start using CFX-5.7.1 | Atit | CFX | 8 | February 16, 2005 07:40 |
