Installation on an SGI Altix
Old   March 31, 2007, 05:34
Default Hi all, I have a script tha
Edwin Lim
eviled is on a distinguished road
Hi all,
I have a script that builds OpenFOAM 1.3 for the SGI Altix 300 running SGI ProPack 2.3 for Linux.
As ProPack 2.3 is very old, many things have to be recompiled, including gcc4, binutils, Mesa3d (for OpenGL), java3d, ParaView, cmake, and Apache Ant. It compiles MPICH by default but the line can be commented out to use the default LAM MPI.
The Wiki page at http://openfoamwiki.net/index.php/Ho...mpile_OpenFOAM has been most helpful, and so has the this forum. I am glad to be able to finally compile it and would be happy if my effort can help someone else.
The script is here:
http://jaws.eng.hawaii.edu/~elim/install-OpenFOAM.sh
It is almost completely automated and will download everything except for the Java SDK. Run the script and download the SDK when prompted to. Everything will be built in $HOME/OpenFOAM directory.
It needs a recent enough C compiler (gcc 2.96 on my build machine) for bootstrapping gcc4; wget and cvs to automatically download the source.
Also, by default it will parallel make with 8 processes (since my built machine has 8 CPUs ;-), so edit the file if you want more or less parallel make processes (just three lines in the beginning of the file). For an estimate, on the 8 CPU 900MHz Itanium2 machine, the whole build process takes about 5.5 hours real time, and almost 13 hours user time. It takes about 3GB to build, and will occupy 2.5GB if the downloaded sources are deleted after the build.
As I have just compiled it, I have no extensive experience how robust the build is. It does seem to run blockMesh and icoFoam on the cavity tutorial, and FoamX also appears to be functioning. So, good luck! ;-)
HTH
Cheers,
e.
eviled is offline   Reply With Quote
Installation of OpenFOAM15 on the SGI Altix 4700 LinuxIA64I64DP0pt rhee OpenFOAM Installation 0 November 20, 2008 17:10
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 11:54
Running Fluent on an SGI Altix machine Jonathan Vogt FLUENT 1 March 19, 2008 02:35
OF on Altix Itanium2 machine skabilan OpenFOAM Installation 0 December 14, 2007 05:04
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 10:27
