OpenFOAM installation problem on Linux 32bit
Old   April 27, 2007, 06:41
Default Iam trying to install OpenFOAM
Suresh kumar Kannan
kumar is on a distinguished road
Iam trying to install OpenFOAM-1.4 on my linux machine. The OS is redHat linux 4. I have installed the files as given in README file. I have installed gcc-4.1.2, ParaView and JAVA files also from the OpenFoam side. After installing the SW executed the command "Allwmake" command. This give me the following errors and the installation is incomplete. What Iam doing wrong? The error I get during the installation :
*** SSI boot tm-specific setup
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking tm.h usability... no
checking tm.h presence... no
checking for tm.h... no
configure: error: *** Cannot find working tm.h.
*** SSI rpi ib-schecking for stdlib.h... yes
checking for VAPI_open_hca in -lvapi... no
configure: error: *** Cannot find working libvapi.
configure: /bin/sh './configure' *failed* for share/ssi/rpi/ib
configure: --- SSI module rpi:ib compile: no
*** SSI crlam blcr-specific setup
checking if C compiler and POSIX threads work as is... yes
checking for working POSIX threads package... yes
checking if C compiler and Solaris threads work... no
checking for working Solaris threads package... no
checking for type of thread support... posix
checking if threads have different pids (pthreads on linux)... no
checking for cr_register_callback in -lcr... no
checking if want LBNL checkpoint support... no
configure: error: cannot continue
configure: /bin/sh './configure' *failed* for share/ssi/crlam/blcr
configure: --- SSI module crlam:blcr compile: no
*** SSI crmpi blcr-specific setup
configure: /bin/sh './configure' *failed* for share/ssi/crmpi/blcr
configure: --- SSI module crmpi:blcr compile: no
*** SSI rpi gm-specific setup
checking for main in -lgm... no
configure: error: *** Cannot find working libgm.
configure: /bin/sh './configure' *failed* for share/ssi/rpi/gm
configure: --- SSI module rpi:gm compile: no
*** SSI rpi ib-specific setup
fvMeshDistribute/fvMeshDistributeTemplates.C:311: error: expected primary-expression before '>' token
make: *** [Make/linuxGcc4DPOpt/fvMeshDistribute.o] Error 1
+ wmake libso dynamicFvMesh
/usr/bin/ld: cannot find -ldynamicMesh
collect2: ld returned 1 exit status
make: *** [/home/l_kumar/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libdynamicFvMesh.so] Error 1
/usr/bin/ld: cannot find -ldynamicFvMesh
make: *** [/home/l_kumar/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libtopoChangerFvMesh.so] Error 1
+ wmake libso fvMotionSolver
make: *** [/home/l_kumar/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libfvMotionSolvers.so] Error 1
+ wmake libso engine
make: *** [/home/l_kumar/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libengine.so] Error 1
+ wmake libso ODE
Opt/financialFoam
/usr/bin/ld: cannot find -lOpenFOAM
make[2]: *** [/home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/financialFo am] Error 1
make[2]: Leaving directory `/home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/solvers/financial/financialFo
am'
make[1]: *** [financialFoam] Error 2
make[1]: Leaving directory `/home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/solvers/financial'
make: *** [financial] Error 2
SOURCE=netgenNeutralToFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-param
eter -Wold-style-cas
t -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/l_kumar/OpenFOAM/OpenFOAM-1.4/src/OpenF
OAM/lnInclude -fPI
C -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/netgenNeutralToFoam.o
g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoR
-depth-40 -IlnInclude -I. -I/home/l_kumar/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread M
etgenNeutralToFoam.o -L/home/l_kumar/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt \
-lOpenFOAM -liberty -ldl -lm -o /home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOp
m
make[3]: *** [/home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/netgenNeutr alToFoam] Err
or 1
make[3]: Leaving directory `/home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/conversion/net
genNeutralToFoam'
make[2]: *** [netgenNeutralToFoam] Error 2
make[2]: Leaving directory `/home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/conversion'
make[1]: *** [conversion] Error 2
make[1]: Leaving directory `/home/l_kumar/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh'
make: *** [mesh] Error 2
+ '[' 0 = 1 -a '' = doc ']'
I will appreciate very much your make. My INSTALLATION is incomplete.
Regards,
Kumar
kumar is offline   Reply With Quote
My experiences about Installing OpenFOAM on OPENSUSE103 32bit coompressor OpenFOAM Installation 9 February 19, 2010 00:00
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 20:53
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 02:40
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 14:38
Help with new installation on AMD linux 64 bit mattijs OpenFOAM Installation 7 September 29, 2005 16:53
