May 7, 2007, 04:39 |
hi !
i advice you to work
#21 |
hamdi
Rep Power: 17 |
hi !
i advice you to work under suse linux, it is very compatible with openfoam |
May 7, 2007, 12:15 |
Hi ranjan!
Have you already
#22 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi ranjan!
Have you already looked at the advice that was given to Andrei at the start of this thread? (Because it seems he had the same problem and it was solved) BTW: what command produced the error message you gave us?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Installation Problem | velan | OpenFOAM Installation | 3 | December 16, 2008 05:17 |
installation problem | Dr C.Bhasker | Siemens | 1 | September 13, 2006 08:01 |
Installation Problem | Sundar.M | Siemens | 0 | June 28, 2006 00:42 |
Installation Problem | Meenu | FLUENT | 2 | April 22, 2006 15:29 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
