OpenFOAM 141 gccicoFoamnsd problems
Old   August 14, 2007, 11:35
Default I thought that I successfully
Eric Moore
sippycup is on a distinguished road
I thought that I successfully posted this earlier today so I hope it doesn´t end up being a double post.
I´ve installed OpenFOAM 1.4 i386 on two machines successfully, but I´m having issues installing 1.4.1 i86-64. foamInstallationTest is complaining that there are two paths for gcc (I don´t know where to tell it to simply use the OpenFOAM/linux copy, or if it is that simple) and that icoFoam is not present. FoamX complains that nsd is not present (I did find nsd, but I don´t know what config file controls where FoamX looks for it).
Would I be better off compiling myself or is this stuff fixable? I´m a linux novice but definitely willing to learn more to get this running. I´m doing this for work and really just want to start using OpenFOAM and finish configuring it.
sippycup is offline   Reply With Quote
Old   August 29, 2007, 09:59
Default Eric, Could you please post t
David P. Schmidt
schmidt_d is on a distinguished road
Eric,
Could you please post the explicit output of foamInstallationTest ? I don't think that you want to recompile...it can be very time consuming.
Check that the correct lines have been added to your .cshrc or .bashrc and that WM_64 is on.
DPS
schmidt_d is offline   Reply With Quote
Problems with installation of OpenFoam sheyer OpenFOAM Installation 8 July 28, 2008 04:45
[General] OpenFoam - problems MateuszZb ParaView 8 July 21, 2008 17:16
Confused by Problems when reinstalling OPenFoam 13 jin_xu OpenFOAM Installation 2 June 2, 2008 21:53
Ld problems with openfoam srinath OpenFOAM Installation 1 May 2, 2008 08:49
Problems in Compiling OpenFOAM in IRIX lakeat OpenFOAM Installation 0 June 7, 2007 22:44
