November 2, 2007, 14:38 |
Hello Gianfilippo,
which co
#21 |
Oliver Borm
Rep Power: 17 |
Hello Gianfilippo,
which configuration options do you use for the paraview cmake? I can build it, but at runtime I get a segmentation fault. I've also written an ebuild for OpenFOAM for gentoo boxes. Yet in the emerge/sandbox environment I can't even compile the PVFoamReader. The log's said like: + cmake ../.. -- Check for working C compiler: /usr/bin/gcc -- Check for working C compiler: /usr/bin/gcc -- works -- Check size of void* -- Check size of void* - done -- Check for working CXX compiler: /usr/bin/g++ -- Check for working CXX compiler: /usr/bin/g++ -- works Warning: CMake is forcing CMAKE_CXX_COMPILER to "/usr/bin/c++" to match that imported from VTK. This is required because C++ projects must use the same compiler. If this message appears for more than one imported project, you have conflicting C++ compilers and will have to re-build one of those projects. Was set to /usr/bin/g++ -- Loading ParaView CMake commands -- Loading ParaView CMake commands - done -- Configuring done -- Generating done -- Build files have been written to: /var/tmp/portage/sci-libs/openfoam-1.4.1_p20071028/work/OpenFOAM-1.4.1/applicati ons/utilities/postProcessing/graphics/PVFoamReader/PVFoamReader/Make/linux64DPOp t + make make[3]: Entering directory `/var/tmp/portage/sci-libs/openfoam-1.4.1_p20071028/work/OpenFOAM-1.4.1/applicat ions/utilities/postProcessing/graphics/PVFoamReader/PVFoamReader/Make/linux64DPO pt' make[4]: Entering directory `/var/tmp/portage/sci-libs/openfoam-1.4.1_p20071028/work/OpenFOAM-1.4.1/applicat ions/utilities/postProcessing/graphics/PVFoamReader/PVFoamReader/Make/linux64DPO pt' make[5]: Entering directory `/var/tmp/portage/sci-libs/openfoam-1.4.1_p20071028/work/OpenFOAM-1.4.1/applicat ions/utilities/postProcessing/graphics/PVFoamReader/PVFoamReader/Make/linux64DPO pt' [ 14%] Generating vtkFoamDataClientServer.cxx make[5]: execvp: ../../vtkFoamData.h: Permission denied make[5]: *** [vtkFoamDataClientServer.cxx] Error 127 [ 28%] Generating vtkFoamReaderClientServer.cxx make[5]: execvp: ../../vtkFoamReader.h: Permission denied make[5]: *** [vtkFoamReaderClientServer.cxx] Error 127 make[5]: Target `CMakeFiles/PVFoamReader.dir/depend' not remade because of errors. Has anybody some ideas? |
Problems with installation of OpenFoam | sheyer | OpenFOAM Installation | 8 | July 28, 2008 04:45 |
OpenFOAM installation | Mark | Main CFD Forum | 2 | March 29, 2008 08:45 |
Problem in installation of OpenFOAM | sachin | OpenFOAM Installation | 7 | January 22, 2008 02:40 |
Installation OpenFoam on SUSE 101 | t42 | OpenFOAM Installation | 1 | August 1, 2007 07:15 |
OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 06:41 |
