Specifying multiple machines with a machines file
Old   February 6, 2008, 19:24
Default I'm trying to run interFoam an
mellanoxuser
I'm trying to run interFoam and damBreak3D on 2 machines and eventually on 4 and 8 machines. I've specified the machine names in "machines" file. I'm using openMPI - so in the mpirun command I use a -hostfile flag as per section 3.4 of User Guide.
I keep getting errors like " ERROR: A daemon on node mtilab246 failed to start as expected". I've shared my openFOAM directory across the nodes and sourced the bashrc on all the machines.
Why is the "orted" daemon not starting on the other nodes?
Fluent cases in parallel across multiple machines Riaan FLUENT 3 April 11, 2005 12:51
tutorial for windows machines Arnab Siemens 8 October 14, 2004 20:59
earth runtimes on different machines Nick May Phoenics 1 April 27, 2004 01:36
Clustering of Linux machines Ajay s. Parihar Main CFD Forum 6 January 24, 2003 16:47
733 MHZ machines John McGrath FLUENT 1 January 26, 2000 04:50
