January 19, 2008, 10:03 |
I am new to linux and OF
In
Sachin Kanetkar
Rep Power: 17 |
In fact it is because of OF i am using Linux I am using SUSE 10.1 I would explain what all i did -Downloaded OF on my windows machine(unfortunately not allowed to connect my laptop to thru this LAN) -Transferred it by pen drive to Laptop -Unpacked using tar command -Added the last line as said in Readme file -from terminal . $HOME/ bashcr....i dont remeber but had copied from readme file and pasted it on console -but it just jumps to next console with doin anything if I run foaminstallationText it says source file not complied to home/sachin/OpenFoam Please help me out as early as possible |
February 17, 2008, 17:57 |
seems you had the same p
Joerg Schenkel
Rep Power: 17 |
seems you had the same problem like I. But where did you find the .bashrc file, I cant find it. How do you come this far? Do you download all thatt gcc and other-compiler-Stuff, do I really need it? I wasn´t able to put something in the $home directory, only in the $home/(username)/... . Is it meant that you put somthing in your Username-Home, when it is written put it in your-Home?? |
February 22, 2008, 11:20 |
The .bashrc file should be in
Jeremiah Hall
Rep Power: 17 |
The .bashrc file should be in your home directory, if you use the bash shell. Your home directory is defined by the environment variable $HOME, and should be the directory /home/<username>/. If you download everything into the directories described on the download page and in the README, you then have to modify your .bashrc accordingly and source it with:
> source ~/.bashrc Then you shouldn't need to compile from source. |
Trouble with installing OpenFOAM on Ubuntu | Milos | OpenFOAM Installation | 16 | November 16, 2009 03:44 |
Problem in Paraview While installing OpenFOAM 15 in Suse 103 | altranindia | OpenFOAM Installation | 1 | February 20, 2009 10:20 |
Pls help last problem to be solved for installing OPENfoam | daydayuper | OpenFOAM Installation | 5 | November 9, 2008 05:59 |
Installing OpenFOAM without Paraview | quartzian | OpenFOAM Installation | 0 | September 8, 2008 10:29 |
Installing OpenFOAM | honcho | OpenFOAM Installation | 1 | April 9, 2008 07:29 |
