February 8, 2007, 05:27 |
Hi everybody,
Trying to com
Hi everybody,
Trying to compile OpenFOAM with the intel compiler 9.1.042 version with standard OF options, everything goes right except for the compilation of trisurface library. I found these compiler errors: cosimo@kelvin:..src/triSurface> wmake libso make: Nothing to be done for `allFiles'. make: `lnInclude/uptodate' is up to date. make: `Make/linuxI32DPOpt/dependencies' is up to date. libso SOURCE_DIR=triSurface/interfaces/STL SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; foamFlex++ -f $SOURCE ; mv lex.yy.cc Make/linuxI32DPOpt/readSTLASCII.C ; icc -gcc-version=410 -Dlinux -DDP -wd654 -vec-report0 -O3 -no-prec-div -xP -DNoRepository -I/home/andreini/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -KPIC -c Make/linuxI32DPOpt/readSTLASCII.C -o Make/linuxI32DPOpt/readSTLASCII.o lex.yy.cc(5774): error: identifier "yy_current_buffer" is undefined if ( ! yy_current_buffer ) ^ lex.yy.cc(5988): error: identifier "yy_current_buffer" is undefined if ( yy_current_buffer->yy_buffer_status == YY_BUFFER_NEW ) ^ lex.yy.cc(6128): error: identifier "yy_current_buffer" is undefined yy_current_buffer = 0; ^ lex.yy.cc(6140): error: identifier "yy_current_buffer" is undefined yy_delete_buffer( yy_current_buffer ); ^ lex.yy.cc(6147): error: identifier "yy_current_buffer" is undefined yy_delete_buffer( yy_current_buffer ); ^ lex.yy.cc(6200): error: identifier "yy_current_buffer" is undefined register char *dest = yy_current_buffer->yy_ch_buf; ^ lex.yy.cc(6390): error: identifier "yy_current_buffer" is undefined if ( yy_cp <yy_current_buffer->yy_ch_buf + 2 ) ^ lex.yy.cc(6432): error: identifier "yy_current_buffer" is undefined if ( yy_c_buf_p <&yy_current_buffer->yy_ch_buf[yy_n_chars] ) ^ lex.yy.cc(6491): error: identifier "yy_current_buffer" is undefined if ( ! yy_current_buffer ) ^ lex.yy.cc(6501): error: identifier "yy_current_buffer" is undefined if ( yy_current_buffer == new_buffer ) ^ lex.yy.cc(6526): error: identifier "yy_current_buffer" is undefined yy_n_chars = yy_current_buffer->yy_n_chars; ^ lex.yy.cc(6563): error: identifier "yy_current_buffer" is undefined if ( b == yy_current_buffer ) ^ lex.yy.cc(6573): warning #584: omission of exception specification is incompatible with previous function "isatty" (declared at line 743 of "/usr/include/unistd.h") extern "C" int isatty YY_PROTO(( int )); ^ lex.yy.cc(6605): error: identifier "yy_current_buffer" is undefined if ( b == yy_current_buffer ) ^ compilation aborted for Make/linuxI32DPOpt/readSTLASCII.C (code 2) make: *** [Make/linuxI32DPOpt/readSTLASCII.o] Error 2 It seems there is problem with foamFlex++ Can anyone give any help about it? Thank in advance Cosimo
Cosimo Bianchini Ergon Research s.r.l. Via Panciatichi, 92 50127 Florence - ITALY Tel: +39 055 0763716 Mob: +39 320 9460153 e-mail: cosimo.bianchini@ergonresearch.it URL: www.ergonresearch.it |
March 6, 2008, 17:59 |
Hi cosimo,
maybe it is to l
Jens Klostermann
Rep Power: 17 |
Hi cosimo,
maybe it is to late?, if not you can try (as Hrv suggested) cd $FOAM_APP/utilities/miscellaneous cp foamFlex/FlexLexer.h $FOAM_SRC/OpenFOAM/lnInclude if FlexLexer.h doesn't live in $FOAM_SRC/OpenFOAM/lnInclude . Check also http://www.cfd-online.com/OpenFOAM_Discus/messages/126/6070.html Jens |
Compiling with Intel compiler icc90 | hjasak | OpenFOAM Installation | 19 | October 27, 2007 12:35 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 08:14 |
Compiling with Intel icc | gellert | OpenFOAM Installation | 9 | November 29, 2006 08:07 |
Compiling problem | Alper Albayraq | FLUENT | 7 | August 26, 2005 02:39 |
some problem about intel fortran | ztdep | Main CFD Forum | 1 | June 30, 2005 08:19 |
