Compiling
Old   February 26, 2008, 05:42
Default Hallo, I'm trying to compile
Mattia
morfeus80 is on a distinguished road
Hallo,
I'm trying to compile the liftDrag utility with OpenSuse 10.3, but I have this output:
mattia@linux:~/OpenFOAM/OpenFOAM-1.4.1/src/postProcessing> ./Allwmake
/home/mattia/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found
/home/mattia/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found
/home/mattia/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully
What have I to do?
morfeus80 is offline   Reply With Quote
Old   February 26, 2008, 06:34
Default You have to install at least (
Michael Wild
mwild is on a distinguished road
You have to install at least (using YaST):
- make
- flex
You probably will also need binutils and if it is not installed already, something called libc6-dev (or similar, I don't have suse).
If you didn't install the gcc binary pack you will also need gcc-c++.
Might be that I forgot something...
Hope this helps.
Michael
mwild is offline   Reply With Quote
Old   February 26, 2008, 08:03
Default I installed 'make' and 'flex'
Mattia
I installed 'make' and 'flex' and now it works.
Thanks!
Old   March 3, 2008, 05:55
Default Now I'm trying to install lift
Mattia
Now I'm trying to install liftDrag tool in another machine (a cluster), but when I run wmake in the liftDrag utility location, I have the following error:
[mattia@cluster liftDrag]$ wmake
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/ -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/cfdTools/general/lnInclude -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/specie/lnInclude -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/basic/lnInclude -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/postProcessing -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels/LESdeltas/lnInclude -IlnInclude -I. -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC Make/linux64GccDPOpt/liftDrag.o -L/home/mattia/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt \
-lcompressiblePostProcessing -lincompressiblePostProcessing -lOpenFOAM -liberty -ldl -lm -o /home/mattia/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/liftDrag
/usr/bin/ld: cannot find -lcompressiblePostProcessing
collect2: ld returned 1 exit status
make: *** [/home/mattia/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/liftDrag] Error 1
Can anyone help me?
Old   March 3, 2008, 11:24
Default It complains about libcompress
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
It complains about libcompressiblePostProcessing! I didn't find a library with this name in my distribution. Remove it from the options file and see what functions is actually after. Then you can try to identify them in a new library.
Dragos
dmoroian is offline   Reply With Quote
Old   March 6, 2008, 13:12
Default I removed lcompressiblePostPro
Mattia
I removed lcompressiblePostProcessing from the option file and now after typing "wmake" I have a lot of output lines. I post only the last, but if you need I can post all the output:
liftDrag.C.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldE NS_7volMeshEEC1ERKNS_8IOobject ERKS3_[Foam::GeometricField<double,>::GeometricField(Foam ::IOobject const&, Foam::GeometricField<double,> const&)]+0x105): undefined reference to `Foam::GeometricField<double,>::debug'
Make/linux64GccDPOpt/liftDrag.o: In function `Foam::GeometricField<double,>::GeometricField(Foa m::IOobject const&, Foam::fvMesh const&, Foam::dimensionSet const&, Foam::word const&)':
liftDrag.C.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldE NS_7volMeshEEC1ERKNS_8IOobject ERKNS_6fvMeshERKNS_12dimensionSetERKNS_4wordE[Foam::GeometricField<double,>::Geo metricField(Foam::IOobject const&, Foam::fvMesh const&, Foam::dimensionSet const&, Foam::word const&)]+0xde): undefined reference to `Foam::fvMesh::boundary() const'
liftDrag.C.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldE NS_7volMeshEEC1ERKNS_8IOobject ERKNS_6fvMeshERKNS_12dimensionSetERKNS_4wordE[Foam::GeometricField<double,>::Geo metricField(Foam::IOobject const&, Foam::fvMesh const&, Foam::dimensionSet const&, Foam::word const&)]+0xfd): undefined reference to `Foam::GeometricField<double,>::debug'
Make/linux64GccDPOpt/liftDrag.o: In function `Foam::tmp<foam::geometricfield<double,> > Foam::operator*<foam::fvpatchfield,>(Foam::Geometr icField<double,> const&, Foam::GeometricField<double,> const&)':
liftDrag.C.text._ZN4FoammlINS_12fvPatchFieldENS_7volMeshEEEN S_3tmpINS_14GeometricFieldIdT_ T0_EEEERKS7_SA_[Foam::tmp<foam::geometricfield<double,> > Foam::operator*<foam::fvpatchfield,>(Foam::Geometr icField<double,> const&, Foam::GeometricField<double,> const&)]+0x2a5): undefined reference to `Foam::calculatedFvPatchField<double>::typeName'
Make/linux64GccDPOpt/liftDrag.o.data.rel.ro._ZTIN4Foam11wallFvPatchE[typeinfo for Foam::wallFvPatch]+0x10): undefined reference to `typeinfo for Foam::fvPatch'
What's the problem now? Do you have any solution?
Old   March 6, 2008, 13:46
Default Ok, so try now to replace the
dmoroian's Avatar
Dragos
Ok, so try now to replace the -lcompressiblePostProcessing with -lOpenFOAM.
Dragos
Old   March 7, 2008, 03:54
Default Thanks Dragos, I raplaced -lco
Mattia
Thanks Dragos, I raplaced -lcompressiblePostProcessing and then it couldn't find the -lincompressiblePostProcessing. So I removed that line from the option file and now the error is the following:
What can I do now?
Old   March 7, 2008, 05:16
Default Hi Mattia, In my previous pos
dmoroian's Avatar
Dragos
Hi Mattia,
In my previous post I said that you have to replace -lcompressiblePostProcessing with -lOpenFOAM.
The removing part was just a test to see what functions it needs.
Dragos
Old   March 7, 2008, 10:37
Default Hi Dragos, that's what I did,
Mattia
Hi Dragos,
that's what I did, but now I have the same problem with -lincompressiblePostProcessing that is in the line under in the option file.
Old   March 7, 2008, 18:58
Default Hm, my appologies, I should re
  #11
dmoroian's Avatar
Dragos
Hm, my appologies, I should read more careful the post.
Ok, so until now you have removed -lcompressiblePostProcessing and -lincompressiblePostProcessing, and added -lOpenFOAM.
Now add -lfiniteVolume in your options file.
Dragos
Old   March 8, 2008, 06:03
Default Hi Dragos, this is last outpu
  #12
Mattia
Hi Dragos,
this is last output after -lfiniteVolume has been added:
SOURCE=liftDrag.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/ -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/cfdTools/general/lnInclude -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/specie/lnInclude -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/basic/lnInclude -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/postProcessing -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels/LESdeltas/lnInclude -IlnInclude -I. -I/home/mattia/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/liftDrag.o
-lOpenFOAM -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/mattia/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/liftDrag
Make/linux64GccDPOpt/liftDrag.o: In function `main':
liftDrag.C.text+0x2729): undefined reference to `Foam::basicThermo::New(Foam::fvMesh const&)'
liftDrag.C.text+0x2d46): undefined reference to `Foam::momentCoefficient(Foam::GeometricField<foam ::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::dimensioned<double> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&)'
liftDrag.C.text+0x2de2): undefined reference to `Foam::liftCoefficient(Foam::GeometricField<foam:: vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::dimensioned<double> const&, Foam::word const&, Foam::Vector<double> const&, double const&)'
liftDrag.C.text+0x2e75): undefined reference to `Foam::dragCoefficient(Foam::GeometricField<foam:: vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::dimensioned<double> const&, Foam::word const&, Foam::Vector<double> const&, double const&)'
liftDrag.C.text+0x390b): undefined reference to `Foam::compressible::pressureMomentCoefficient(Foa m::GeometricField<foam::vector <double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&, double const&)'
liftDrag.C.text+0x39ad): undefined reference to `Foam::compressible::pressureLiftCoefficient(Foam: :GeometricField<foam::vector<d ouble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&)'
liftDrag.C.text+0x3a43): undefined reference to `Foam::compressible::pressureDragCoefficient(Foam: :GeometricField<foam::vector<d ouble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&)'
liftDrag.C.text+0x4461): undefined reference to `Foam::compressible::momentCoefficient(Foam::Geome tricField<foam::vector<double> , Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&, double const&)'
liftDrag.C.text+0x450e): undefined reference to `Foam::compressible::liftCoefficient(Foam::Geometr icField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&)'
liftDrag.C.text+0x45ae): undefined reference to `Foam::compressible::dragCoefficient(Foam::Geometr icField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&)'
Thanks in advance!
Old   March 8, 2008, 06:25
Default The class basicThermo comes in
  #13
dmoroian's Avatar
Dragos
The class basicThermo comes in libbasicThermophysicalModels, so add:
-lbasicThermophysicalModels
Dragos
Old   March 8, 2008, 07:24
Default Thanks, these are last lines o
  #14
Mattia
Thanks, these are last lines of the new output:
ragCoefficient(Foam::GeometricField<foam::vector<d ouble>, Foam::fvPatchField, Fo
am::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volM
esh> const&, Foam::word const&, Foam::Vector<double> const&, double const&, doub
le const&)'
fficient(Foam::GeometricField<foam::vector<double> , Foam::fvPatchField, Foam::vo
lMesh> const&, Foam::GeometricField<double,> c onst&, Foam::GeometricField<double,> const&, F oam::word const&, Foam::Vector<double> const&, double const&, double const&, dou ble const&)'
liftDrag.C.text+0x450e): undefined reference to `Foam::compressible::liftCoeff icient(Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volM esh> const&, Foam::GeometricField<double,> con st&, Foam::GeometricField<double,> const&, Foa m::word const&, Foam::Vector<double> const&, double const&, double const&)'
liftDrag.C.text+0x45ae): undefined reference to `Foam::compressible::dragCoeff icient(Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volM esh> const&, Foam::GeometricField<double,> con st&, Foam::GeometricField<double,> const&, Foa m::word const&, Foam::Vector<double> const&, double const&, double const&)'
/home/mattia/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so: undefined reference to `Foam::specie::RR'
/home/mattia/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so: undefined reference to `Foam::perfectGas::perfectGas(Foam::Istream&)'
/home/mattia/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysicalM odels.so: undefined reference to `Foam::specie::Tstd'
make: *** [/home/mattia/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt /liftDrag] Error 1
Old   March 8, 2008, 10:16
Default Another thing: if I copy the -
  #15
Mattia
Another thing: if I copy the -libcompressiblePostProcessing and -libincompressiblePostProcessing libraries from the 32bit version to the 64bit version where I can't find them, can it cause any problem?
Old   March 10, 2008, 02:23
Default Hi Mattia, On short: 1. If y
  #16
dmoroian's Avatar
Dragos
Hi Mattia,
On short:
1. If you copy the libraries and put them in let say /tmp/libcompressiblePostProcessing and /tmp/libincompressiblePostProcessing you should add something like this -L/tmp and then the usual -lcompress.... But I don't know if you can use the 32bit versions!
2. The function/class missed by the compiler (Foam::compressible::pressureDragCoefficient) in the above message is not on my distribution so...
Anyway I will try to compile myself the utility and I will let you know about it.
Dragos
Old   March 10, 2008, 03:53
Default Thanks Dragos, you're very ki
  #17
Mattia
Thanks Dragos,
you're very kind to help me!
Old   March 13, 2008, 07:26
Default Hello Mattia, Well, good and
  #18
dmoroian's Avatar
Dragos
Hello Mattia,
Well, good and bad news. The good ones are that liftDrag utility gets compiled without any problems on the OpenFOAM-1.4.1-dev version. The bad news is that you have to download it and compile it yourself, still if you follow the build instructions it should go smooth.
Dragos
Old   March 16, 2008, 02:21
Default Hey, Im a relatively new Op
  #19
Ryan Middleton
ryan_m is on a distinguished road
Hey,
Im a relatively new OpenFOAM user (1 week). I have run plenty of 2D cases with ok results. Im looking at using the liftDrag tool but getting really confused with so much info on the forum. The only version of OpenFOAM I have on my computer is 1.4.1. Can somebody please tell where to download liftDrag from and which folder to put it in for 1.4.1?
Thanks very much for any help.
Ryan
ryan_m is offline   Reply With Quote
Compiling UDF Claud FLUENT 10 December 18, 2006 17:52
Compiling my UDF chris FLUENT 5 July 12, 2006 09:49
Compiling UDF Rahul FLUENT 3 March 23, 2003 06:12
Compiling MON FLUENT 0 October 20, 2002 21:48
Compiling UDF Zhang_clement FLUENT 5 February 3, 2002 01:56
