April 3, 2008, 08:01 |
Hi all,
I have already inst
Francois Beaubert
Rep Power: 17 |
Hi all,
I have already installed OpenFOAM-1.4.1 on my $HOME directory and I'm now playing with a central installation on our cluster. According to the wiki (http://www.mfix.org/mwiki/index.php/Organise_Your_Work_with_OpenFOAM#Working_Wit h_Central_Installation) I have made some minor modifications on the WM_PROJECT_INST_DIR like export WM_PROJECT_INST_DIR=/opt/software/$WM_PROJECT And I add this line to my $HOME/.bashrc source /opt/software/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc When I login I have the followings messages: -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1/bin/foamCleanPath: Permission denied -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1/bin/foamCleanPath: Permission denied -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1/bin/foamCleanPath: Permission denied -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1/.bashrc: Permission denied -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1//apps/ensightFoam/bashrc: No such file or directory -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1//apps/paraview/bashrc: No such file or directory -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1/bin/foamCleanPath: Permission denied -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1/bin/foamCleanPath: Permission denied -bash: /opt/software/OpenFOAM/OpenFOAM-1.4.1/bin/foamCleanPath: Permission denied So obviously there are some permissions problems. Don't know why ... So I change those permissions with: chmod -R a+r /opt/software/OpenFOAM/OpenFOAM-1.4.1/ chmod -R a+x /opt/software/OpenFOAM/OpenFOAM-1.4.1/bin Is it safe to do this this way ? After I login I still have some error messages: Executing: /opt/software/OpenFOAM/OpenFOAM-1.4.1/.bashrc mkdir: cannot chdir to directory `/opt/software/OpenFOAM/OpenFOAM-1.4.1/src/openmpi-1.2.3/platforms/linux64GccDPO pt': Permission denied mkdir: cannot chdir to directory `/opt/software/OpenFOAM/OpenFOAM-1.4.1/src/openmpi-1.2.3/platforms/linux64GccDPO pt': Permission denied mkdir: cannot chdir to directory `/opt/software/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt': Permission denied Executing: /opt/software/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/ensightFoam/bashrc Executing: /opt/software/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/paraview/bashrc And I saw some strange thinks because I do not have applications like icoFoam,gmshToFoam on the command line. But the PATH is correct A ls -l on /opt/software/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/ gives me stange thinks: total 0 ?--------- ? ? ? ? ? adiabaticFlameT ?--------- ? ? ? ? ? ansysToFoam ?--------- ? ? ? ? ? attachMesh ?--------- ? ? ? ? ? autoPatch ?--------- ? ? ? ? ? autoRefineMesh ?--------- ? ? ? ? ? blockMesh ?--------- ? ? ? ? ? boundaryFoam ?--------- ? ? ? ? ? boxTurb Is there a bug with tar. My system use tar (GNU tar) 1.14 So to conclude what is the best way to make a good clean central installation. Is there a bug with tar with long filename-path ? Thank you very much for your help Have a nice day Francois |
April 3, 2008, 08:22 |
Try chmod -R a+rX /opt/softwar
Mark Olesen
Rep Power: 40 |
Try chmod -R a+rX /opt/software/OpenFOAM
Using a large 'X' instead of an small 'x' causes the execution bit to set only if any of the user/group/other execution bits are set. This grants read permissions for everyone and lets change in to directories, but without making every file excutable (like using a small 'x' would do). /mark |
April 3, 2008, 09:07 |
Hi Mark,
Thank you very muc
Francois Beaubert
Rep Power: 17 |
Hi Mark,
Thank you very much for the tips Everythings seems to be ok now for permissions Tanks ! Francois |
How to add a central jet | badri1979 | OpenFOAM Running, Solving & CFD | 0 | September 11, 2006 16:20 |
Central/QUICK | Paul | Main CFD Forum | 12 | January 9, 2006 22:32 |
Central DIfference | Glen | Main CFD Forum | 9 | May 27, 2005 03:06 |
Central differencing scheme | alice | FLUENT | 1 | March 11, 2004 20:07 |
Central jet injection in a fluidized bed | Mike | Main CFD Forum | 0 | April 26, 2002 16:14 |
