yarrort
Rep Power: 0 ![]() |
When Finished installation,type FoamX,
there exists the following error: nsd: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory executing ./foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: at.at OS: Linux version 2.6.9-42.EL User: at User_config: /home/at/.bashrc Foam_config: /home/at/.OpenFOAM-1.4.1/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/at/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/at/OpenFOAM/at-1.4.1 yes no $FOAM_JOB_DIR /home/at/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/at/OpenFOAM/OpenFOAM-1.4.1 yes yes yes $FOAM_USER_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes no $FOAM_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes yes $WM_DIR /home/at/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /home/at/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH .../mico-2.3.12/platforms/linuxGccDPOpt yes yes yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN .../OpenFOAM/at-1.4.1/lib/linuxGccDPOpt yes yes no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.2.1 /home/at/OpenFOAM/linux/gcc-4.2.1/bin/gcc java 1.4.2_05 /home/at/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.3 /bin/gzip tar 1.3.3 /bin/tar icoFoam .../OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_at.at Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. |
Valter Dal Bo
Rep Power: 17 ![]() |
Hi !
It sounds like the problem I have except I use RHEL4 and you seem to be using RHEL5. Correct ? See my post "FoamX and the infamous libssl.so.0.9.7 problem on RHEL4" maybe what I already tried is going to work for you. VDB |
Libsslso098 library missing | ahorvat | OpenFOAM Bugs | 8 | October 23, 2009 07:05 |
Cannot find file points in directory constantpolyMesh | blo | OpenFOAM Installation | 4 | August 26, 2008 07:06 |
[OpenFOAM] Cannot find file points in directory constantpolyMesh | ztdep | ParaView | 3 | March 25, 2008 21:23 |
[blockMesh] FOAM FATAL ERROR Cannot find file points in directory constantpolyMesh | evgenii | OpenFOAM Meshing & Mesh Conversion | 2 | October 9, 2006 15:27 |
File "core" in Fluent directory | Ralf Schmidt | FLUENT | 1 | January 15, 2006 11:23 |
