Gcc for SGI IRIX 65
Old   February 23, 2006, 10:33
Default Hi Sebastien! I tried to inst
  #41
Francesco Del Citto
fra76 is on a distinguished road
Hi Sebastien!
I tried to install OpenFOAM on the same OS, but after some unsuccesfull attempt, I gived up.
Could you please explain in detail how could you install gcc 4.0.2 and then OpenFOAM?
I was able to compile gcc 3.4.5, and tried to compile openFOAM 1.1 using it, but I had a problem while building dependencies, because the command line generated by the Makefile was too long for the system settings.
Any help would be really appreciated!
Francesco
fra76 is offline   Reply With Quote
Old   February 23, 2006, 10:53
Default Niklas, You were right, if
  #42
seb
Sebastien RIFFLART
seb is on a distinguished road
Niklas,
You were right, if I put the full path it's OK. I should have been able to find it was in thermodynamicProperties, but I too tired. Thanks a lot.
Now I tried to run in parallel, and of course an other problem :
mpirun -np 4 interFoam . damBreak
mpirun (set_stdio): Invalid argument
Can you be my saver once again?
Francesco,
For the length of command line, I didn't had this problem, but the solution has already been done :
# systune |grep ncargs
ncargs = 20480 (0x5000)
# systune ncargs 0x6000
as a summary for installation :
- install GNU Tar, because IRIX Tar will forget some files because of too long path
- install GNU Make
- install Binutils (for GNU as and GNU ld)
- install gcc
after that try to compile a hello world ! program with g++, if it's OK you can make OpenFoam
seb is offline   Reply With Quote
Old   February 23, 2006, 10:55
Default your syntax is incorrect mp
  #43
stefan
stefanke is on a distinguished road
mpirun -np 4 interFoam . damBreak -parallel
for details consult the user guide!
stefanke is offline   Reply With Quote
Old   February 23, 2006, 11:53
Default I was using the correct syntax
  #44
seb
Sebastien RIFFLART
I was using the correct syntax, my message was wrong (sorry).
I found the problem on the Web :
This is a bug in glibc. mpirun's -f option bypasses this code path.
Old   February 28, 2006, 04:38
Default I had problem with the native
  #45
seb
Sebastien RIFFLART
I had problem with the native MPI, so I recompile OpenFoam with "setenv WM_MPLIB LAM" in the .cshrc.
The compilation was OK.
Now, if I had "/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/dummy" to the LD_LIBRARY_PATH, solvers can be run normally, if I don't add it to the LD_LIBRARY_PATH it choose the lam-7.1.1 libPstream.so and I've got this message :
1382330:interFoam: rld: Error: unresolvable symbol in /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream. so: _ZN4PMPI9Intracomm10current_opE
1382330:interFoam: rld: Error: unresolvable symbol in /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream. so: _ZN3MPI2Op4FreeEv
1382330:interFoam: rld: Error: unresolvable symbol in /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream. so: op_intercept
1382330:interFoam: rld: Error: unresolvable symbol in /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream. so: _ZN4PMPI4Comm11mpi_err_mapE
1382330:interFoam: rld: Error: unresolvable symbol in /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream. so: _ZN3MPI2Op4InitEPFvPKvPviRKNS_8DatatypeEEb
1382330:interFoam: rld: Error: unresolvable symbol in /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream. so: _ZN4PMPI4Comm12mpi_comm_mapE
1382330:interFoam: rld: Fatal Error: this executable has unresolvable symbols
of course if I try to run in parallel, I've got the same message,
What can I do, I think it's a problem of linking when making the library lipPstream.so, but I had no error when compiling.
What can I do?
Old   February 28, 2006, 05:46
Default - remove lam-7.1.1/libPstream.
  #46
Mattijs Janssens
mattijs is on a distinguished road
- remove lam-7.1.1/libPstream.so
- source your .cshrc/.bashrc so you're sure you have all the right settings
- rebuild Pstream:
cd Pstream/mpi
wmake libso
and check the compilation and link lines very carefully.
- try to find one of those missing symbols (using e.g. nm) and see what file you're missing.
mattijs is offline   Reply With Quote
Old   February 28, 2006, 06:43
Default When I rebuild Pstream, here a
  #47
seb
Sebastien RIFFLART
When I rebuild Pstream, here are the lines :
make: Nothing to be done for `allFiles'.
make: `lnInclude/uptodate' is up to date.
make: `Make/sgiN32GccOpt/dependencies' is up to date.
libso
/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/wmake/cshScripts/mkObjectDir /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream
rm -f so_locations
cd Make/sgiN32GccOpt ; \
g++ -mabi=n32 -mips4 -DsgiN32 -Wall -W -Wno-unused-parameter -O3 -ffast-math -fno-schedule-insns -DNoRepository -ftemplate-depth-30 -I/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/src/lam-7.1.1/platforms/sgiN32GccOpt /include -I/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -shared -Wl,-LD_LAYOUT:lgot_buffer=100 OPwrite.o IPread.o Pstream.o -L/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt -L/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/src/lam-7.1.1/platforms/sgiN32GccOpt /lib -lmpi -llam -lpthread -o /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream. so
ld32: WARNING 84 : /usr/lib32/libm.so is not used for resolving any symbol.
`/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/lib/sgiN32GccOpt/lam-7.1.1/libPstream .so' is up to date.
And it seems that all the missings symbols are in
liblammpi++.a (from /hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/src/lam-7.1.1/platforms/sgiN32GccOpt/l ib/)
I think I have to had something to
/hydrowork/usr/cres/OpenFOAM/OpenFOAM-1.2/wmake/rules/sgiN32Gcc/mplibLAM which I edit like that :
PFLAGS =
PINC = -I$(LAM_ARCH_PATH)/include
PLIBS = -L$(LAM_ARCH_PATH)/lib -lmpi -llam -lpthread
I tried to add -lutil (like linux rules) but it gives me error :
ld32: FATAL 9 : I/O error (-lutil): No such file or directory
What can I do?
Old   February 28, 2006, 14:10
Default I found the solution : PLIBS
  #48
seb
Sebastien RIFFLART
PLIBS = -lm -lpthread -L$(LAM_ARCH_PATH)/lib -llammpi++ -llammpio -llamf77mpi -lmpi -llam
and now it's OK
Old   March 28, 2006, 09:58
Default Hi! I'm still in trouble with
  #49
Francesco Del Citto
Hi!
I'm still in trouble with OpenFOAM on IRIX 6.5.
The first problem I'd like to resolve is the gcc compiler.
If I try to compile gcc 4.0.2 with the internal cc compiler, this is what I do and the error I get:
$ ../gcc-4.0.2/configure --prefix=/mnt/users/delcitto/local/gcc-4.0.2 --enable-threads 2>&1 | tee log_configure
$ nohup make bootstrap 1>./bootstrap-gcc4.0.2-irix.out 2>&1 &
And the error is:
config.status: executing default commands
make[1]: Entering directory `/mnt/users/delcitto/download/GNU/gcc-4.0.2-irix/build-mips-sgi-irix6.5/libibert y'
if [ x"" != x ] && [ ! -d pic ]; then \
mkdir pic; \
else true; fi
touch stamp-picdir
if [ x"" != x ]; then \
/bin/cc -c -DHAVE_CONFIG_H -I. -I../../../gcc-4.0.2/libiberty/../include ../../../gcc-4.0.2/libiberty/regex.c -o pic/regex.o; \
else true; fi
/bin/cc -c -DHAVE_CONFIG_H -I. -I../../../gcc-4.0.2/libiberty/../include ../../../gcc-4.0.2/libiberty/regex.c -o regex.o
No server for this feature (-3,121:2) No such file or directory
The MIPSpro C Compiler
(license FEATURE string = cc)
requires a license password.
If you are Outside of North America or you are not a Silicon
Graphics support customer then contact your local support provider.
cc-1552 cc: WARNING File = ../../../gcc-4.0.2/libiberty/regex.c, Line = 7239
The variable "pdummy" is set but never used.
UCHAR_T *pdummy = NULL;
cc-1552 cc: WARNING File = ../../../gcc-4.0.2/libiberty/regex.c, Line = 7240
The variable "sdummy" is set but never used.
const CHAR_T *sdummy = NULL;
cc-1548 cc: WARNING File = ../../../gcc-4.0.2/libiberty/regex.c, Line = 7575
The transfer of control bypasses...
... the initialization of variable "same_str_p" (declared at line
6012).
goto restore_best_regs;
/bin/cc -c -DHAVE_CONFIG_H -I. -I../../../gcc-4.0.2/libiberty/../include ../../../gcc-4.0.2/libiberty/cplus-dem.c -o pic/cplus-dem.o; \
else true; fi
/bin/cc -c -DHAVE_CONFIG_H -I. -I../../../gcc-4.0.2/libiberty/../include ../../../gcc-4.0.2/libiberty/cplus-dem.c -o cplus-dem.o
cc-1349 cc: WARNING File = /usr/include/sys/types.h, Line = 120
The indicated declaration requires a typedef name.
typedef long pid_t; /* proc & grp IDs */ ^
cc-1213 cc: ERROR File = /usr/include/sys/types.h, Line = 326
The declaration contains a duplicate specifier.
typedef unsigned long int uintptr_t;
cc-1349 cc: WARNING File = /usr/include/sys/types.h, Line = 326
cc-1116 cc: WARNING File = ../../../gcc-4.0.2/libiberty/cplus-dem.c, Line = 631
Non-void function "code_for_qualifier" (declared at line 611) should return a
value.
cc-1116 cc: WARNING File = ../../../gcc-4.0.2/libiberty/cplus-dem.c, Line = 672
Non-void function "qualifier_string" (declared at line 637) should return a
value.
1 error detected in the compilation of "../../../gcc-4.0.2/libiberty/cplus-dem.c".
make[1]: *** [cplus-dem.o] Error 2
make[1]: Leaving directory `/mnt/users/delcitto/download/GNU/gcc-4.0.2-irix/build-mips-sgi-irix6.5/libibert y'
make: *** [all-build-libiberty] Error 2
How can I resolve this problem?
Francesco
Old   April 5, 2006, 11:12
Default Next step: I'm trying to boot
  #50
Francesco Del Citto
Next step:
I'm trying to bootstra gcc 4.0.2 using the working gcc 3.4.5 I've on my SGI, using the standard IRIX linker /usr/bin/ld (with gnu ld I have other kind of errors).
This is the configure command:
../gcc-4.0.2/configure --with-gnu-as --with-as=/mnt/users/delcitto/local/bin/as --prefix=/mnt/users/delcitto/local/gcc-4.0.2 --enable-threads 2>&1 |tee conf_01.log
This is the error during bootstrap:
stage1/xgcc -Bstage1/ -B/mnt/users/delcitto/local/gcc-4.0.2/mips-sgi-irix6.5/bin/ -c -g -O2 -DIN_GCC -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -pedantic -Wno-long-long -Wno-variadic-macros -Wold-style-definition -DHAVE_CONFIG_H -I. -Icp -I../../gcc-4.0.2/gcc -I../../gcc-4.0.2/gcc/cp -I../../gcc-4.0.2/gcc/../include -I./../intl -I../../gcc-4.0.2/gcc/../libcpp/include ../../gcc-4.0.2/gcc/cp/cp-gimplify.c -o cp/cp-gimplify.o stage1/xgcc -Bstage1/ -B/mnt/users/delcitto/local/gcc-4.0.2/mips-sgi-irix6.5/bin/ -g -O2 -DIN_GCC -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -pedantic -Wno-long-long -Wno-variadic-macros -Wold-style-definition -DHAVE_CONFIG_H -o cc1plus \
cp/cp-lang.o stub-objc.o cp/call.o cp/decl.o cp/expr.o cp/pt.o cp/typeck2.o cp/class.o cp/decl2.o cp/error.o cp/lex.o cp/parser.o cp/ptree.o cp/rtti.o cp/typeck.o cp/cvt.o cp/except.o cp/friend.o cp/init.o cp/method.o cp/search.o cp/semantics.o cp/tree.o cp/repo.o cp/dump.o cp/optimize.o cp/mangle.o cp/cp-objcp-common.o cp/name-lookup.o cp/cxx-pretty-print.o cp/cp-gimplify.o tree-mudflap.o attribs.o c-common.o c-format.o c-pragma.o c-semantics.o c-lex.o c-dump.o c-pretty-print.o c-opts.o c-pch.o c-incpath.o cppdefault.o c-ppoutput.o c-cppbuiltin.o prefix.o c-gimplify.o tree-inline.o main.o libbackend.a ../libcpp/libcpp.a ../libcpp/libcpp.a ./../intl/libintl.a ../libiberty/libiberty.a
ld32: WARNING 84 : ../libcpp/libcpp.a is not used for resolving any symbol.
ld32: ERROR 33 : Unresolved data symbol "libc_name_p" -- 1st referenced by cp/except.o.
Use linker option -v to see when and which objects, archives and dsos are loaded.
ld32: INFO 152: Output file removed because of error.
collect2: ld returned 2 exit status
make[2]: *** [cc1plus] Error 1
make[2]: Leaving directory `/mnt/users/delcitto/download/GNU/gcc-4.0.2-irix/gcc'
make[1]: *** [stage2_build] Error 2
make[1]: Leaving directory `/mnt/users/delcitto/download/GNU/gcc-4.0.2-irix/gcc'
make: *** [bootstrap] Error 2
Any suggestions?
Francesco
Old   May 29, 2007, 01:12
Default Hi again, Can I use CC to co
  #51
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Hi again,
Can I use CC to compile OpenFOAM in IRIX?
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   June 7, 2007, 22:15
Default Hi, Now, I have installed GCC
  #52
lakeat's Avatar
Daniel WEI (老魏)
Now, I have installed GCC in IRIX6.5.
First, I came to know from "http://gcc.gnu.org/gcc-4.1/buildstat.html" that GCC-4.1.1 can be successfully installed.
Then I Configure with
~/Codes/gcc*1/configure --prefix=$HOME/OpenFOAM/linux/gcc-4.1.1 --exec-prefix=$HOME/OpenFOAM/linux/gcc-4.1.1 --enable-languages=c,c++ --enable-shared --enable-threads --disable-nls --disable-multilib --with-gnu-ld --disable-wchart_t
And after a rather considerably long time, it's done eventually.
Daniel WEI
Beijing, China
Email
Old   June 14, 2007, 02:50
Default hi, I managed to build OpenFO
  #53
lakeat's Avatar
Daniel WEI (老魏)
hi,
I managed to build OpenFOAM-1.4 with dubug option for sgi IRIX6.5, I have paid special concern on
1> use foamFlex (from source OF-1.3);
2> modify any.cc, fixed.cc, os-unix.cc, util.cc in OpenFOAM-1.0.2/src/mico-2.3.11/orb;
it seems there isn't any error during the entire compiling process, however, when i type icoFoam or any other, there came a segmetation fault immediately.
when i gdb blockMesh, i was told segmentation fault and you can't do that without a process to debug.
it seems It can not execute even the first line of blockMesh as if I have made some very silly mistake
I am wondering whether my gcc is installed rightly. and how could i know that.
Thanks
Daniel
Daniel WEI
Beijing, China
Email
Old   November 28, 2007, 05:11
Default Hi again, I met many erro
  #54
lakeat's Avatar
Daniel WEI (老魏)
Hi again,
I met many errors (Irix6.5 Gcc-4.2.1)
In the beginning of compiling,
+ cd Pstream
+ ./Allwmake
+ wmake libso dummy
/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1/wmake/wmakeLnInclude: linking include files to /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1/src/Pstream/dummy/lnInclude
Making dependency list for source file Pstream.C
could not open file math.h for source file Pstream.C
Making dependency list for source file IPread.C
could not open file math.h for source file IPread.C
Making dependency list for source file OPwrite.C
could not open file math.h for source file OPwrite.C
SOURCE=Pstream.C ; g++ -DsgiN32 -DDP -O0 -fdefault-inline -finline-functions -ggdb3 -DFULLDEBUG -DNoRepository -IlnInclude -I. -I/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -LANG:std -c $SOURCE -o Make/sgiN32GccDPDebug/Pstream.o
make: *** [Make/sgiN32GccDPDebug/Pstream.o] Interrupt
It seems that haeder file math.h cannot be lnincluded.
Thanks in advance!
Daniel
Daniel WEI
Beijing, China
Email
Old   December 2, 2007, 01:52
Default Hi again, I solved the som
  #55
lakeat's Avatar
Daniel WEI (老魏)
Hi again,
I solved the some error above by configuring wmake/makefile, but there still remain many other files which "could not open file s% for source file %s", I examined wmake/src/wmkdep.l, and around the lines:
if (!(yyin = fopen(fileName, "r")))
for (d=0; d<nDirectories; d++)
pathName = addDirectoryName(directories[d], fileName);
if ((yyin = fopen(pathName, "r")))
printf("%s: %s\n", depFile, pathName);
yy_switch_to_buffer(yy_create_buffer(yyin, YY_BUF_SIZE));
BEGIN(INITIAL);
free(pathName);
return;
free(pathName);
fprintf
stderr,
"could not open file %s for source file %s\n",
fileName, sourceFile
fflush(stdout);
currentBuffer--;
BEGIN(INITIAL);
I feel confused, since LnInclude has been link these files in OpenFOAM-1.4.1/src/OpenFOAM/lnInclude,
and I can see they are there, but why couldn't them be opened?
And another question:
while compiling clockTime.o, there's an error, said "field 'startTime_' has incomplete type"...
Any help would be highly appreciated .
Daniel
Daniel WEI
Beijing, China
Email
Old   December 2, 2007, 06:01
Default I got it! In file wmkdep.l, I
  #56
lakeat's Avatar
Daniel WEI (老魏)
I got it!
In file wmkdep.l, I cancel the comment-out:
/* This causes strange problems
fclose(yyin);
yyin = 0;
But, since fclose is necessary for fopen correctly, why these two lines were commented out?
Is this a bug
Daniel WEI
Beijing, China
Email
Old   December 2, 2007, 08:33
Default The problem I mentioned above
  #57
lakeat's Avatar
Daniel WEI (老魏)
The problem I mentioned above is solved,
by insert a head <sys/time.h> in clockTime.H.
Though I don't understand why it is <sys/type.h>, since timeval is not defined there.
another error I met is much the same as
http://www.cfd-online.com/OpenFOAM_D...es/1/1523.html
had mentioned, that is
no execinfo.h found!
so I followed Bernhard Gschaider's instruction by
comment out the two missing headers and all the stuff in the printStack-method
I cannot tell for sure whether it is right or not.
Daniel
Daniel WEI
Beijing, China
Email
Old   April 14, 2008, 10:51
Default On IRIX6.5, I have no idea whi
  #58
lakeat's Avatar
Daniel WEI (老魏)
On IRIX6.5, I have no idea which malloc shall I switch on, fbsdmalloc, or bsdmalloc or gmalloc or g++malloc or mmalloc?
Any hints much appreciated!
Daniel
Daniel WEI
Beijing, China
Email
Old   April 24, 2008, 06:02
Default Can anyone give me some help,
  #59
lakeat's Avatar
Daniel WEI (老魏)
Can anyone give me some help, please?
Daniel
Daniel WEI
Beijing, China
Email
Building OpenFOAM on IRIX lakeat OpenFOAM Installation 7 July 16, 2008 08:27
Problems in Compiling OpenFOAM in IRIX lakeat OpenFOAM Installation 0 June 7, 2007 22:44
help-parallel computing in irix kim FLUENT 0 August 7, 2003 16:22
FLUENT, 64-bit platform & IRIX jim clancy FLUENT 1 January 31, 2002 18:32
