Java home how to
Old   April 27, 2008, 22:51
Default Can someone explain to me how
Stephen
basilwatson is on a distinguished road
Can someone explain to me how to do this , I am unsure of how to proceed.
Kind Regards Stephen
To use the JAVA supplied with the system, you need to set the $JAVA_HOME environment variable to the path of the installation, e.g. '/usr'. This is set in the $HOME/OpenFOAM/OpenFOAM-1.4.1/.bashrc (or .cshrc) file.
basilwatson is offline   Reply With Quote
Old   April 28, 2008, 09:37
Default There may be a bit of a gotcha
Graeme Cottrell
platopus is on a distinguished road
There may be a bit of a gotcha in there somewhere, because if you tell it the system's Java is somewhere that places the system's C++ compiler on the path before the C++ compiler installed under $HOME/OpenFOAM/linux, you can run into trouble.
From memory, it can be overcome with a simple edit of one of the OpenFOAM shell initialisation scripts. Sorry, but I can't remember which one.
Probably safer to use the Java and C++ downloadable from openfoam.co.uk if you can't get it to work.
Regards, Graeme.
platopus is offline   Reply With Quote
home environnement Matthieu FLUENT 0 November 14, 2004 09:41
home environment john FLUENT 2 May 24, 2004 06:55
64-bit processors for home computing Ananda Himansu Main CFD Forum 2 March 16, 2004 13:48
Home environment must be set!! Michael Vredevoort FLUENT 1 April 1, 2002 14:59
