Is Testsuite on the way or not
Old   April 24, 2008, 04:22
Default Dear Developers, Since the
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Dear Developers,
Since the OpenFOAM core dumping all the time on my IRIX system, (execpt icoFoam and a few solvers), so I am wondering do you have a plan to release a testsuite just as what gcc did to fully test the final installation and all the FOAM_Template_Library? I noticed there are some in application/test dir, but I think it is far from enough, isn't it?
Looking forward for your reply! thanks.
Daniel
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   April 24, 2008, 05:03
Default Daniel, I'm not a develope
Graeme Cottrell
platopus is on a distinguished road
Daniel,
I'm not a developer, but I think that the cases in the tutorials section might be adapted for use as test cases, with the addition of what should be some relatively simple code to compare the results of running them, or simplified cases of them, to results generated by the developers and thought to be 'correct'.
One problem is that some of the cases that are run by the main Allrun script in the tutorials directory actually take a very long time to execute on a uniprocessor, so to just get a sanity check you'd need to pare down those cases quite a bit.
Also, there would be a lot of data involved unless some steps are taken to log it less frequently and/or compute using coarser grids. I think that seeing whether a particular solver is working as the developer expected on a simplified tutorial case would be a useful step in the right direction.
Regards, Graeme.
platopus is offline   Reply With Quote
Old   April 27, 2008, 22:46
Default Thank you, Graeme! There's
lakeat's Avatar
Daniel WEI (老魏)
Thank you, Graeme!
There's a strange problem on my IRIX machine.
I installed gcc-4.3.0,
binutils-2.18.
After a very difficult compilation, what's strange is I can build icoFoam and it runs without core dumping, but turbFoam or oodles core dumped!
Interestingly, those that need link the libraries
-incompressibletransportModels
-incompressibleturbulenceModels
are all core dumped!
The reason I posted my first post is that I just want to have an easy way to test files like these two:
-incompressibletransportModels.so
-incompressibleturbulenceModels.so
And also, I turn to guess that it is my gnu-ld is "somewhat" or "a litte bit" incompatible with my system.
So finally I implement all my transportModels and turbulenceModels which are needed by turbFoam and the like to finiteVolume and rebuild the new finiteVolume.so.
Now turbFoam -> PASS!
Daniel
Daniel WEI
Beijing, China
Email
Old   April 28, 2008, 05:01
Default To test using the tutorials th
Mattijs Janssens
mattijs is on a distinguished road
To test using the tutorials there is the Alltest script in $FOAM_TUTORIALS which will just run a few iterations.
mattijs is offline   Reply With Quote
Old   April 28, 2008, 06:06
Default Hello, all, There seems to
lakeat's Avatar
Daniel WEI (老魏)
Hello, all,
There seems to be one step left for me to make it work on IRIX, it's all about MPI.
Here's the error message.
I dont understand what does this line mean.
libexc(513638): ERROR __exc_get_fde_name: Couldn't find any name at 0x60204334
Any help much appreciated!
Well, I can run icoFoam very well without using mpirun.
Daniel
bash-2.05$ mpirun -np 4 `which icoFoam` $FOAM_RUN/tutorials/icoFoam cavity -parallel
MPI Pstream initialized with:
floatTransfer : 1
nProcsSimpleSum : 0
scheduledTransfer : 0
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1-dev |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/sgiN32Gc cDPDebug/icoFoam /disk4/usr/people/student3/OpenFOAM/student3-1.4.1-dev/run/tutorials/icoFoam cavity -parallel
[0] Date : Apr 28 2008
[0] Time : 16:44:15
[0] Host : onyx-bridge
[0] PID : 513629
[3] Date : Apr 28 2008
[3] Time : 16:44:15
[3] Host : onyx-bridge
[3] PID : 513638
[1] Date : Apr 28 2008
[1] Time : 16:44:15
[1] Host : onyx-bridge
[1] PID : 513610
[2] Date : Apr 28 2008
[2] Time : 16:44:15
[2] Host : onyx-bridge
[2] PID : 513608
MPI: Program /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/sgiN32Gc cDPDebug/icoFoam, Rank 3, Process 513638 received signal SIGBUS(10)
MPI: --------stack traceback-------
PC: 0x5ddb100 MPI_SGI_stacktraceback in /usr/lib32/libmpi.so
PC: 0x5ddb544 first_arriver_handler in /usr/lib32/libmpi.so
PC: 0x5ddb7d8 slave_sig_handler in /usr/lib32/libmpi.so
PC: 0xfaee79c _sigtramp in /usr/lib32/libc.so.1
libexc(513638): ERROR __exc_get_fde_name: Couldn't find any name at 0x60204334 in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
0 0x60197ac8 abs
(a lot of messages the same as above)
115 0x60197ac8 abs
PC: 0x42d432c (null) in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
0 0x60197ac8 abs
6 0x60197ac8 abs
libexc(513638): ERROR __exc_get_fde_name: Couldn't find any name at 0x6020374c in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
7 0x60197ac8 abs
115 0x60197ac8 abs
PC: 0x42d3744 (null) in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
libexc(513638): ERROR __exc_get_fde_name: Couldn't find any name at 0x602064bc in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
0 0x60197ac8 abs
115 0x60197ac8 abs
PC: 0x42d64b4 (null) in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
libexc(513638): ERROR __exc_get_fde_name: Couldn't find any name at 0x601ee308 in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
0 0x60197ac8 abs
115 0x60197ac8 abs
PC: 0x42be300 (null) in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
libexc(513638): ERROR __exc_get_fde_name: Couldn't find any name at 0x601c262c in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
0 0x60197ac8 abs
115 0x60197ac8 abs
PC: 0x4292624 (null) in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
libexc(513638): ERROR __exc_get_fde_name: Couldn't find any name at 0x601b0904 in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
0 0x60197ac8 abs
115 0x60197ac8 abs
PC: 0x42808fc (null) in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/lib/sgiN32GccDPDebug/libO penFOAM.so
PC: 0x1002aeec main in /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/sgiN32Gc cDPDebug/icoFoam
MPI: dbx version 7.3.3 (78517_Dec16 MR) Dec 16 2001 07:45:22
MPI: Process 513638 (icoFoam) stopped at [__waitsys:24 +0x8,0xfa53338]
MPI: Source (of /xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/proc/waitsys.s) not available for Process 513638
MPI: > 0 __waitsys(0x0, 0x7d662, 0x7ffb5080, 0x3, 0x0, 0x7ffb4ec8, 0x0, 0xf8) ["/xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/proc/waitsys.s":24, 0xfa53338]
MPI: 1 _system(0x7ffb5150, 0x7d662, 0x7ffb5080, 0x3, 0x0, 0x7ffb4ec8, 0x0, 0xf8) ["/xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/stdio/system.c":116, 0xfa5f868]
MPI: 2 MPI_SGI_stacktraceback(0x0, 0x7d662, 0x7ffb5080, 0x3, 0x0, 0x7ffb4ec8, 0x0, 0xf8) ["/xlv4/mpt/1.8/mpi/work/4.3/lib/libmpi/libmpi_n32_M4/adi/sig.c":242, 0x5ddb268]
MPI: 3 first_arriver_handler(0xa, 0x71756974, 0x7ffb5080, 0x3, 0x0, 0x7ffb4ec8, 0x0, 0xf8) ["/xlv4/mpt/1.8/mpi/work/4.3/lib/libmpi/libmpi_n32_M4/adi/sig.c":445, 0x5ddb544]
MPI: 4 slave_sig_handler(0xa, 0x7d662, 0x7ffb5080, 0x3, 0x0, 0x7ffb4ec8, 0x0, 0xf8) ["/xlv4/mpt/1.8/mpi/work/4.3/lib/libmpi/libmpi_n32_M4/adi/sig.c":542, 0x5ddb7e0]
MPI: 5 _sigtramp(0x0, 0x7d662, 0x0, 0x3, 0x0, 0x0, 0x0, 0xf8) ["/xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/signal/sigtramp.s":71, 0xfaee79c]
MPI: 6 Foam::IPstream::readFromBuffer(this = <illegal>, t = <illegal>) ["/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/db/IOstrea ms/Pstreams/IPread.C":2, 0x42d4334]
MPI: 7 Foam::IPstream::read(this = <illegal>, l = <illegal>) ["/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/db/IOstrea ms/Pstreams/IPread.C":27, 0x42d3744]
MPI: 8 Foam::IPstream::read(this = <illegal>, t = <illegal>) ["/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/db/IOstrea ms/Pstreams/IPreadToken.C":4
MPI: More (n if no)?, 0x42d64b4]
MPI: 9 Foam::token::token(this = <illegal>, is = <illegal>) ["/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/db/IOstrea ms/token/tokenIO.C":4, 0x42be300]
MPI: 10 <unknown>(is = <illegal>, L = <illegal>) ["/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/global/arg List/argList.C":40, 0x4292624]
MPI: 11 <unknown>(this = <illegal>, argc = <illegal>, argv = <illegal>, checkArgs = <illegal>, checkOpts = <illegal>) ["/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/global/arg List/argList.C":66, 0x42808fc]
MPI: 12 ::main(The debugger has detected a dbxpcs server error (Internal Consistency Error).
MPI: dbxpcs server attempting to continue
MPI: ) ["/disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/applications/solvers/in compressible/icoFoam/icoFoam.C":0, 0x1002aeec]
MPI: 13 __start() ["/xlv55/kudzu-apr12/work/irix/lib/libc/libc_n32_M4/csu/crt1text.s":177, 0x1002a668]
MPI: -----stack traceback ends-----
MPI: Program /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/sgiN32Gc cDPDebug/icoFoam, Rank 3, Process 513638: Dumping core on signal SIGBUS(10) into directory /disk4/usr/people/student3/OpenFOAM/student3-1.4.1-dev/run/tutorials/icoFoam
MPI: Program /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/sgiN32Gc cDPDebug/icoFoam, Rank 1, Process 513610: Core dump on signal SIGBUS(10) suppressed.
MPI: Program /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/sgiN32Gc cDPDebug/icoFoam, Rank 2, Process 513608: Core dump on signal SIGBUS(10) suppressed.
MPI: MPI_COMM_WORLD rank 1 has terminated without calling MPI_Finalize()
MPI: aborting job
MPI: Received signal 9
Daniel WEI
Beijing, China
Email
Old   April 28, 2008, 09:02
Default Daniel wrote: > Thank you,
Graeme Cottrell
Daniel wrote:
> Thank you, Graeme!
You're welcome.
Good for you! :-)
I've given some thought to implementing the ideas I floated in my previous message; I'm not likely to have time to do much with this in the next couple of weeks, but perhaps a month from now...
I saw Mattijs' mention of the Alltest script. I haven't looked at it in detail and I wasn't clear about what it did, but it still seems to me that if we have a transient solver it will still be worthwhile to have a set of tests that can run to completion and give a fully developed flow in a reasonable amount of elapsed time (albeit on a coarser mesh), and generate sort-of reasonable data rather than just doing a few iterations as Mattijs says the Alltest script does.
I'll plan on making that happen, but not tomorrow.
Regards, Graeme.
Old   April 28, 2008, 12:12
Default Thank you, Mattijs. http://www
lakeat's Avatar
Daniel WEI (老魏)
Thank you, Mattijs.
Yes, I agree, I have examined the Alltest file this afternoon, and that's not what I want.
a coarser mesh plus certain solver is a good choice.
Yet what if a solver or a utility cannot run at all, and core dumps all the more? How can I diagnose the problem? For me, the hard time arises when debugger (dbx or gdb) and "par -s -SS" and the like couldn't give me enough useful information.
Thank you all the time, Graeme.
Kindly Regards,
Daniel
Daniel WEI
Beijing, China
Email
