June 23, 2008, 11:28 |
Hi All,
After trying OF on
Mark Couwenberg
Rep Power: 17 |
Hi All,
After trying OF on a dual boot machine I now want to install OF such that collegues can also work with it. The preferred way is to place a computer somewhere with Linux/OF installed on which we can log in in order to work with OF. We all have Win XP installed. Does anyone know how to install such a server? Other people have experience in this area? Brgds, Mark |
June 23, 2008, 12:21 |
Mark,
There is nothing spec
Mark Olesen
Rep Power: 40 |
Mark,
There is nothing special you need to do. Just take a normal Linux machine and install OpenFOAM on top of it and connect to it. Since you already have a dual-boot, that might also be a good place to start experimenting. We have a few guys that log in from windows to linux (not for OpenFOAM though). They use putty and xming: http://www.putty.org http://sourceforge.net/projects/xming If you try doing post-processing (eg, paraview) across the network you will not be very happy. I can't help you with any details about configuring the windows clients, but you could also consider another solution (depending on which windows applications you actually need): since my only windows use is email and powerpoint, I just have a virtual windows machine running on top of linux. This solution works really quite well for me. |
1D hydraulic network | A_CFD-student | Main CFD Forum | 7 | February 11, 2010 09:57 |
Installation of CCM+ on HPC server 2008 | Peter Schiøler | Siemens | 0 | January 29, 2009 06:49 |
Can't get server:No server lines in license file | xhliu1 | Siemens | 2 | September 27, 2006 02:39 |
Run Fluent on the network | Kim | FLUENT | 2 | April 23, 2004 09:08 |
network option | Ajay S. Parihar | FLUENT | 0 | June 26, 2002 03:27 |
