April 8, 2008, 22:40 |
Sorry for starting a new threa
Stephen
Rep Power: 17 |
Sorry for starting a new thread, but I am not sure if its the same problem as the others below
below is the output file from installation test with this warning the one I am concerned about; FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/s/.foam2.3/bashrc How do I go about pointing openfoam in the right direction? Kind Regards Stephen Executing /home/s/OpenFOAM/linux/OpenFOAM-1.4.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: s-desktop OS: Linux version 2.6.22-14-generic User: s User_config: /home/s/.bashrc Foam_config: /home/s/.OpenFOAM-1.4.1/bashrc sourced correctly. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/s/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.3 WARNING: Conflicting installations: foam settings: /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.6.0_03 WARNING: Conflicting installations: foam settings: /bin/java current path : /usr/bin/java gzip 1.3.12 /bin/gzip tar 1.3.12 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_s-desktop Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. s@s-desktop:~$ |
April 9, 2008, 06:35 |
This looks like what you get w
Graeme Cottrell
Rep Power: 17 |
This looks like what you get when you've added a line to the end of ~/.bashrc but you're running foamInstallationTest in a shell that hasn't had the benefit of that modification.
Try closing all your terminal sessions, open a new one, and run foamInstallationTest again. Regards, Graeme. |
April 10, 2008, 02:35 |
Thanks Graeme
I have 2 bash
Stephen
Rep Power: 17 |
Thanks Graeme
I have 2 bashrc .bashrc~ and bashrc also bashrc~~ I added the line you see below to all of the ( one at a time then deleting that line after running foam installation test below is the result of the installation test what am I doing wrong??? have I missed a . before the bashrc ??? Thanks for your help, it appreciated Kind Regards Stephen Line added to bashrc ..... snip) # enable programmable completion features (you don't need to enable # this, if it's already enabled in /etc/bash.bashrc and /etc/profile # sources /etc/bash.bashrc). if [ -f /etc/bash_completion ]; then . /etc/bash_completion fi . /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc He is now rising from affluence to poverty. -- Mark Twain bash: /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc: No such file or directory s@s-desktop:~$ /home/s/OpenFOAM/linux/OpenFOAM-1.4.1/bin/foamInstallationTest Executing /home/s/OpenFOAM/linux/OpenFOAM-1.4.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: s-desktop OS: Linux version 2.6.22-14-generic User: s User_config: /home/s/.bashrc Foam_config: /home/s/.OpenFOAM-1.4.1/bashrc sourced correctly. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/s/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.3 WARNING: Conflicting installations: foam settings: /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.6.0_03 WARNING: Conflicting installations: foam settings: /bin/java current path : /usr/bin/java gzip 1.3.12 /bin/gzip tar 1.3.12 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_s-desktop Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. s@s-desktop:~$ |
April 10, 2008, 05:30 |
> I have 2 bashrc
> .bash
Graeme Cottrell
Rep Power: 17 |
> I have 2 bashrc
> > .bashrc~ and bashrc also bashrc~~ What happened to ~/.bashrc ? The ones with the tildes on the ends are backups. > (snip) > . /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc That looks okay, but what file is it in? > He is now rising from affluence to poverty. > -- Mark Twain > bash: > /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc: No such file or directory This is a clue. It can't find the file. > s@s-desktop:~$ > /home/s/OpenFOAM/linux/OpenFOAM-1.4.1/bin/foamInstallationTest Executing > /home/s/OpenFOAM/linux/OpenFOAM-1.4.1/bin/foamInstallationTest: You've untarred the OpenFOAM software into the linux subdirectory of the OpenFOAM directory. That's the wrong place. Try this: mv ~/OpenFOAM/linux/OpenFOAM-1.4.1 ~/OpenFOAM/ Maybe you'll have better results if you put it where it's supposed to be. Regards, Graeme. |
April 10, 2008, 23:13 |
Thanks Graeme
I followed t
Stephen
Rep Power: 17 |
Thanks Graeme
I followed these instructions , and mis understood them http://ubuntuforums.org/showthread.php?t=156298 will give it another shot and see how it goes Kind regards Stephen |
April 11, 2008, 00:45 |
Ok have moved the files , test
Stephen
Rep Power: 17 |
Ok have moved the files , test output the same , found
/home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1 but its empty , as in completely empty Can I just copy the bash file from /home/s..... Kind regards Stephen |
April 11, 2008, 00:53 |
Stephen
Rep Power: 17 |
Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/s/.foam2.3/bashrc this is the problem I think ,,, cant find this file either , Kind regards Stephen |
April 11, 2008, 06:49 |
Graeme Cottrell
Rep Power: 17 |
> > http://ubuntuforums.org/showthread.php?t=156298 They look a bit misleading to me. > Ok have moved the files , test output the same , found > /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1 > > but its empty , as in completely empty That's odd. > Can I just copy the bash file from /home/s..... No, it's a completely different file. > FATAL ERROR Foam install directory not set. > > Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/s/.foam2.3/bashrc > > this is the problem I think ,,, cant find this file either , No, I'm pretty sure that message is left over from a previous incarnation of OpenFOAM. There should be no .foam2.3 directory in the home directory. At this point I think you should take the files you've downloaded and put them in a safe place, then delete contents of the OpenFOAM directory and start again after reading http://www.opencfd.co.uk/openfoam/linux.html#linux Then go to the README file at ~/OpenFOAM/OpenFOAM-1.4.1/README and take it from there. Note that you put the OpenFOAM*.gtgz files in the ~/OpenFOAM directory, change directory to there, and untar them in that directory. The other *.tgz files go into the ~/OpenFOAM/linux directory, you change directory to there and untar them there. Regards, Graeme. |
April 11, 2008, 10:20 |
Thanks Graeme
I ll give it
#9 |
Stephen
Rep Power: 17 |
Thanks Graeme
I ll give it a try tomorrow night will let you know how it goes Kind regards Stephen |
April 14, 2008, 00:45 |
O This is frustrating ( Here
#10 |
Stephen
Rep Power: 17 |
O This is frustrating ( Here is exactly what I typed in and the errors I recieved
Using the installation guide and the readme ( which I couldnt find in OpenFOAM/OpenFOAM-1.4.1/README ( not there ) a) Downloaded the following files from www.openfoam.org OpenFOAM-1.4.1.General.gtgz OpenFOAM-1.4.1.linuxGccDPOpt.gtgz OpenFOAM-1.4.1.linuxGccSPOpt.gtgz I Saved these files to $home/OpenFOAM. by making # mkdir /home/OpenFOAM OpenFOAM directory is sitting next to my user directory gcc-4.1.1.linux.tgz paraview-2.4.4.linux.tgz j2sdk1.4.2.os.linux.tgz Save these files to $home/OpenFOAM/linux.   I changed directory and Untared every single file in the previous order using this command: ----------------------------------------------------- tar -xzvf <filename> Error message returned ( on the zipped files OpenFOAM-1.4.1.linuxGccDPOpt.gtgz and OpenFOAM-1.4.1.linuxGccSPOpt.gtgz gzip: stdin: unexpected end of file tar: Unexpected EOF in archive tar: Unexpected EOF in archive tar: Error is not recoverable: exiting now root@s-desktop:/home/OpenFOAM# OAM-1.4.1/bin/foamInstallationTest ----------------------------------------------------- Then did foamSystemCheck using the following shell command line by line: ----------------------------------------------------- cd ~/OpenFoam/OpenFOAM-1.4.1/bin chmod -v 555 foamSystemCheck setenv PATH ${PATH}:~/OpenFOAM/OpenFOAM-1.4.1/bin/ ( came back with no command found ) foamSystemCheck chmod -v 755 foamSystemCheck -----------------------------------------------------   e) Set the environmental variable using the following shell command line by line: ----------------------------------------------------- gedit ~/.bashrc & . ~/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4/bashrc this was found at the bottom of the bashrc file , saved then exited ----------------------------------------------------- Once you are in gedit mode, add the following line to the end of the file: After you have saved the file, type in the following shell ( shell as in terminal???) command: source ~/.cshrc The environmental variable has been changed. Double check it by the command: echo $PATH To which It returned a whole lot of path names -----------------------------------------------------   Then I Checked the installation by foamInstallationTest: ----------------------------------------------------- cd $HOME/OpenFOAM/OpenFOAM-1.4.1/bin chmod -v 555 foamInstallationTest foamInstallationTest The results being root@s-desktop:/home/OpenFOAM/OpenFOAM-1.4.1/bin# /home/OpenFOAM/OpenFOAM-1.4.1/bin/foamInstallationTest Executing /home/OpenFOAM/OpenFOAM-1.4.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: s-desktop OS: Linux version 2.6.22-14-generic User: root User_config: /root/.bashrc Foam_config: /root/.OpenFOAM-1.4.1/bashrc sourced correctly. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /root/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.3 WARNING: Conflicting installations: foam settings: /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.6.0_03 WARNING: Conflicting installations: foam settings: /bin/java current path : /usr/bin/java gzip 1.3.12 /bin/gzip tar 1.3.12 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_s-desktop Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. root@s-desktop:/home/OpenFOAM/OpenFOAM-1.4.1/bin# Exactly where i was in the begining except now im in a different folder What the earth is going on !!!! The only difference between unpacking this time from the last time is that the files had a X above them and needed a permision change ( the X i assume is that the file did not unpack properly Please help Kind regards Stephen |
April 14, 2008, 01:22 |
the problem may be that this f
#11 |
Stephen
Rep Power: 17 |
the problem may be that this file isnt being created , or at least I havent found it ,,,
Stephen bash: /root/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc: No such file or directory bash: /root/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4/bashrc: No such file or directory root@s-desktop:/home/s# |
April 14, 2008, 07:21 |
Imagine I set up an account fo
#12 |
Graeme Cottrell
Rep Power: 17 |
Imagine I set up an account for you on my machine here, and
I stood behind you and told you what to type. ! Here's the start of a shell session: s@graeme-vaio:~$ cp ../graeme/stephen.txt s.txt s@graeme-vaio:~$ ls Desktop s.txt ! See, it's an almost clean home directory. s@graeme-vaio:~$ mkdir OpenFOAM ! As directed by the web site, we create a directory. s@graeme-vaio:~$ cp ../graeme/OpenFOAM/*.gtgz OpenFOAM ! In this case it's a local copy - in reality, you might have ! to download some of your files again. s@graeme-vaio:~$ cd OpenFOAM s@graeme-vaio:~/OpenFOAM$ ls -l total 259996 -rw-r--r-- 1 s s 148526808 2008-04-14 18:52 OpenFOAM-1.4.1.General.gtgz -rw-r--r-- 1 s s 58886901 2008-04-14 18:52 OpenFOAM-1.4.1.linuxGccDPOpt.gtgz -rw-r--r-- 1 s s 58538845 2008-04-14 18:52 OpenFOAM-1.4.1.linuxGccSPOpt.gtgz ! This is how big these particular versions of these files should be. s@graeme-vaio:~/OpenFOAM$ mkdir linux ! Creating the linux subdirectory of the OpenFOAM directory, as directed. s@graeme-vaio:~/OpenFOAM$ cp ../../graeme/OpenFOAM/linux/*.tgz linux ! Getting the third-party stuff, again this is local, the files you have lying ! around may be quite okay. s@graeme-vaio:~/OpenFOAM$ cd linux s@graeme-vaio:~/OpenFOAM/linux$ ls -l total 117940 -rw-r--r-- 1 s s 41485330 2008-04-14 18:54 gcc-4.2.1.linux.tgz -rw-r--r-- 1 s s 49045283 2008-04-14 18:54 j2sdk1.4.2_05.linux.tgz -rw-r--r-- 1 s s 30097888 2008-04-14 18:54 paraview-2.4.4.linux.tgz ! This is how big they should be. s@graeme-vaio:~/OpenFOAM/linux$ cd .. ! Back up. s@graeme-vaio:~/OpenFOAM$ ls linux OpenFOAM-1.4.1.linuxGccDPOpt.gtgz OpenFOAM-1.4.1.General.gtgz OpenFOAM-1.4.1.linuxGccSPOpt.gtgz s@graeme-vaio:~/OpenFOAM$ tar -xzf OpenFOAM-1.4.1.General.gtgz s@graeme-vaio:~/OpenFOAM$ tar -xzf OpenFOAM-1.4.1.linuxGccDPOpt.gtgz s@graeme-vaio:~/OpenFOAM$ tar -xzf OpenFOAM-1.4.1.linuxGccSPOpt.gtgz ! Now we untar the files. I've left out the v option to make them silent. ! No news is good news. s@graeme-vaio:~/OpenFOAM$ ls -l total 260004 drwxr-xr-x 2 s s 4096 2008-04-14 18:54 linux drwxr-xr-x 10 s s 4096 2008-04-14 18:57 OpenFOAM-1.4.1 -rw-r--r-- 1 s s 148526808 2008-04-14 18:52 OpenFOAM-1.4.1.General.gtgz -rw-r--r-- 1 s s 58886901 2008-04-14 18:52 OpenFOAM-1.4.1.linuxGccDPOpt.gtgz -rw-r--r-- 1 s s 58538845 2008-04-14 18:52 OpenFOAM-1.4.1.linuxGccSPOpt.gtgz ! Now we have an OpenFOAM-1.4.1 subdirectory. s@graeme-vaio:~/OpenFOAM$ ls -l OpenFOAM-1.4.1 total 72 -rwxr-x--- 1 s s 163 2006-04-06 07:18 Allwmake drwxr-xr-x 6 s s 4096 2008-04-14 18:57 applications drwxr-xr-x 3 s s 4096 2008-04-14 18:56 bin -rw-r----- 1 s s 17994 2005-06-22 02:12 COPYING drwxr-xr-x 5 s s 4096 2008-04-14 18:56 doc drwxr-xr-x 4 s s 4096 2008-04-14 18:57 lib -rw-r----- 1 s s 8745 2007-07-31 23:28 README -rw-r----- 1 s s 6171 2007-08-03 07:28 ReleaseNotes-1.4.1 drwxr-xr-x 29 s s 4096 2008-04-14 18:56 src drwxr-xr-x 43 s s 4096 2008-04-14 18:56 tutorials drwxr-xr-x 5 s s 4096 2008-04-14 18:56 wmake ! And look, it contains a README! We'll get to that later. s@graeme-vaio:~/OpenFOAM$ cd linux s@graeme-vaio:~/OpenFOAM/linux$ ls gcc-4.2.1.linux.tgz j2sdk1.4.2_05.linux.tgz paraview-2.4.4.linux.tgz s@graeme-vaio:~/OpenFOAM/linux$ tar -xzf gcc-4.2.1.linux.tgz s@graeme-vaio:~/OpenFOAM/linux$ tar -xzf j2sdk1.4.2_05.linux.tgz s@graeme-vaio:~/OpenFOAM/linux$ tar -xzf paraview-2.4.4.linux.tgz ! Untar the 3rd party apps, silently. s@graeme-vaio:~/OpenFOAM/linux$ ls -l total 117952 drwxr-xr-x 9 s s 4096 2007-08-02 02:30 gcc-4.2.1 -rw-r--r-- 1 s s 41485330 2008-04-14 18:54 gcc-4.2.1.linux.tgz drwxr-xr-x 9 s s 4096 2004-07-06 21:52 j2sdk1.4.2_05 -rw-r--r-- 1 s s 49045283 2008-04-14 18:54 j2sdk1.4.2_05.linux.tgz drwxr-x--- 6 s s 4096 2007-04-11 21:26 paraview-2.4.4 -rw-r--r-- 1 s s 30097888 2008-04-14 18:54 paraview-2.4.4.linux.tgz ! Now we have some directories here, and since we're using exactly ! the versions supplied with the OF 1.4.1, we won't have to muck about ! too much with shell scripts. s@graeme-vaio:~/OpenFOAM/linux$ cd .. s@graeme-vaio:~/OpenFOAM$ cd OpenFOAM-1.4.1/ s@graeme-vaio:~/OpenFOAM/OpenFOAM-1.4.1$ ls Allwmake bin doc README src wmake applications COPYING lib ReleaseNotes-1.4.1 tutorials s@graeme-vaio:~/OpenFOAM/OpenFOAM-1.4.1$ less README ! Now we get to the README, and find the bit about modifying ~/.bashrc, ! so in another shell we edit it, just cutting and pasting from the ! README. s@graeme-vaio:~$ vi .bashrc s@graeme-vaio:~$ ! We notice that the README says to instruct the shell to run the ! new scripts to prepare the environment, but why not just close ! down all the old shells and open new ones up? ! When we do that we are greeted with: Executing: /home/s/OpenFOAM/OpenFOAM-1.4.1/.bashrc Executing: /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/ensightFoam/bashrc Executing: /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/paraview/bashrc ! So it seems to have found everything. s@graeme-vaio:~$ cd OpenFOAM/OpenFOAM-1.4.1/ s@graeme-vaio:~/OpenFOAM/OpenFOAM-1.4.1$ ls Allwmake bin doc README src wmake applications COPYING lib ReleaseNotes-1.4.1 tutorials s@graeme-vaio:~/OpenFOAM/OpenFOAM-1.4.1$ less README ! Back to the README for more, and open up yet another shell session ! to do some experimenting in. Executing: /home/s/OpenFOAM/OpenFOAM-1.4.1/.bashrc Executing: /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/ensightFoam/bashrc Executing: /home/s/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/paraview/bashrc ! Will wonders never cease? It's done it again. ! Belatedly, I realised I forgot the foamSystemCheck ! No chmodding, no superuser priveliges, just: s@graeme-vaio:~$ foamSystemCheck Checking basic system... ----------------------------------------------------------------------- Shell: bash Host: graeme-vaio OS: Linux version 2.6.22-14-generic User: s Checking networking... ----------------------------------------------------------------------- Ping_graeme-vaio: Successful Ping_localHost: Successful Test_rsh: Unsuccessful, connection refused* Test_ssh: Successful (*) Only one of rsh or ssh is required and only by FoamX. System check: PASS ================== Continue Foam installation. ! It was even on the path. ! Now for the next foamInstallationTest: s@graeme-vaio:~$ foamInstallationTest Executing /home/s/OpenFOAM/OpenFOAM-1.4.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: graeme-vaio OS: Linux version 2.6.22-14-generic User: s User_config: /home/s/.bashrc Foam_config: /home/s/.OpenFOAM-1.4.1/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/s/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/s/OpenFOAM/s-1.4.1 yes no $FOAM_JOB_DIR /home/s/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/s/OpenFOAM/OpenFOAM-1.4.1 yes yes yes $FOAM_USER_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes no $FOAM_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes yes $WM_DIR /home/s/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /home/s/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH .../mico-2.3.12/platforms/linuxGccDPOpt yes yes yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN ...s/OpenFOAM/s-1.4.1/lib/linuxGccDPOpt yes yes no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.2.1 /home/s/OpenFOAM/linux/gcc-4.2.1/bin/gcc java 1.4.2_05 /home/s/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.12 /bin/gzip tar 1.3.12 /bin/tar icoFoam .../OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_graeme-vaio Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. ! Flying colours. ! Now, following the directions in the README to create a 'run' directory ! and then copy the tutorials over into it ... s@graeme-vaio:~$ s@graeme-vaio:~$ mkdir -p $HOME/OpenFOAM/${LOGNAME}-1.4.1/run s@graeme-vaio:~$ s@graeme-vaio:~$ cp -r $WM_PROJECT_DIR/tutorials $HOME/OpenFOAM/${LOGNAME}-1.4.1/run s@graeme-vaio:~$ ! Now we can get started. Go to the right place ... s@graeme-vaio:~$ cd $HOME/OpenFOAM/${LOGNAME}-1.4.1/run/tutorials/icoFoam s@graeme-vaio:~/OpenFOAM/s-1.4.1/run/tutorials/icoFoam$ s@graeme-vaio:~/OpenFOAM/s-1.4.1/run/tutorials/icoFoam$ ls -l total 28 -rwxr-x--- 1 s s 392 2008-04-14 19:09 Allclean -rwxr-x--- 1 s s 2712 2008-04-14 19:09 Allrun drwxr-xr-x 5 s s 4096 2008-04-14 19:09 cavity drwxr-xr-x 5 s s 4096 2008-04-14 19:09 cavityClipped drwxr-xr-x 5 s s 4096 2008-04-14 19:09 cavityGrade drwxr-xr-x 5 s s 4096 2008-04-14 19:09 elbow -rw-r----- 1 s s 160 2008-04-14 19:09 resetFixedWallsScr ! Note the Allclean and Allrun scripts? Well don't use them yet. ! We follow the README to mesh a case: s@graeme-vaio:~/OpenFOAM/s-1.4.1/run/tutorials/icoFoam$ blockMesh . cavity /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh . cavity Date : Apr 14 2008 Time : 19:10:43 Host : graeme-vaio PID : 10518 Root : /home/s/OpenFOAM/s-1.4.1/run/tutorials/icoFoam Case : cavity Nprocs : 1 Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Creating merge patch pairs Writing polyMesh end s@graeme-vaio:~/OpenFOAM/s-1.4.1/run/tutorials/icoFoam$ ! And we run a solver on that mesh with the fields that have been set up: s@graeme-vaio:~/OpenFOAM/s-1.4.1/run/tutorials/icoFoam$ icoFoam . cavity /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : icoFoam . cavity Date : Apr 14 2008 Time : 19:11:05 Host : graeme-vaio PID : 10519 Root : /home/s/OpenFOAM/s-1.4.1/run/tutorials/icoFoam Case : cavity Nprocs : 1 Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0 max: 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.96338e-06, No Iterations 8 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 7.55402e-07, No Iterations 35 time step continuity errors : sum local = 5.03809e-09, global = -3.84804e-19, cumulative = -3.84804e-19 DICPCG: Solving for p, Initial residual = 0.523591, Final residual = 9.72352e-07, No Iterations 34 time step continuity errors : sum local = 1.07766e-08, global = 4.10447e-19, cumulative = 2.56426e-20 ExecutionTime = 0.04 s ClockTime = 0 s Time = 0.01 <snip> (many many lines of fascinating numbers elided) Time = 0.5 Courant Number mean: 0.116925 max: 0.852134 DILUPBiCG: Solving for Ux, Initial residual = 1.89493e-07, Final residual = 1.89493e-07, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 4.14522e-07, Final residual = 4.14522e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 1.06665e-06, Final residual = 3.39604e-07, No Iterations 1 time step continuity errors : sum local = 5.25344e-09, global = 1.23705e-18, cumulative = -4.08805e-18 DICPCG: Solving for p, Initial residual = 5.36118e-07, Final residual = 5.36118e-07, No Iterations 0 time step continuity errors : sum local = 6.86432e-09, global = 1.37312e-18, cumulative = -2.71493e-18 ExecutionTime = 0.43 s ClockTime = 1 s End s@graeme-vaio:~/OpenFOAM/s-1.4.1/run/tutorials/icoFoam$ s@graeme-vaio:~/OpenFOAM/s-1.4.1/run/tutorials/icoFoam$ ! And that's how it works. ! Happy? ! Regards, Graeme. ! P.S. Next time, try not to make a spelling mistake in the subject of the message, it makes a bad impression. |
July 17, 2008, 02:32 |
I am really desperate for your
#13 |
mayank gupta
Rep Power: 17 |
I am really desperate for your help.
I am having problems trying to install the Openfoam on my linux ubuntu for the past 2 weeks. I came across your discussion on the forum but could not reply there as there was no option to register. I did exactly what you said, and this is what I get when I do the foam Installation test Checking basic system... ----------------------------------------------------------------------- Shell: bash Host: Techn-028 OS: Linux version 2.6.24-19-generic User: frpelikan Checking networking... ----------------------------------------------------------------------- Ping_Techn-028: Successful Ping_localHost: Successful Test_rsh: Unsuccessful, connection refused* Test_ssh: Unsuccessful, connection refused* FATALERROR: No remote shell available. FoamX requires passwordless 'ssh' and/or 'rsh' to the current host. Contact your system administrator if you intend to run FoamX. System check: FAIL ================== Your system is not currently compatible with Foam installation requirements. Review the error messages and consult the documentation for further instructions. frpelikan@Techn-028:~$ chmod -v 755 foamSystemCheck chmod: cannot access `foamSystemCheck': No such file or directory failed to change mode of `foamSystemCheck' to 0000 (---------) frpelikan@Techn-028:~$ gedit ~/.bashrc & [1] 6618 frpelikan@Techn-028:~$ . ~/.bashrc Executing: /home/frpelikan/OpenFOAM/OpenFOAM-1.4/.bashrc [1]+ Done gedit ~/.bashrc Executing: /home/frpelikan/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/ensightFoam/bashrc Executing: /home/frpelikan/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/paraview/bashrc frpelikan@Techn-028:~$ pwd /home/frpelikan frpelikan@Techn-028:~$ cd OpenFOAM frpelikan@Techn-028:~/OpenFOAM$ cd OpenFOAM-1.4 frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.4$ ls Allwmake bin doc README src wmake applications COPYING lib ReleaseNotes-1.4 tutorials frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.4$ foamSystemCheck Checking basic system... ----------------------------------------------------------------------- Shell: bash Host: Techn-028 OS: Linux version 2.6.24-19-generic User: frpelikan Checking networking... ----------------------------------------------------------------------- Ping_Techn-028: Successful Ping_localHost: Successful Test_rsh: Unsuccessful, connection refused* Test_ssh: Unsuccessful, connection refused* FATALERROR: No remote shell available. FoamX requires passwordless 'ssh' and/or 'rsh' to the current host. Contact your system administrator if you intend to run FoamX. System check: FAIL ================== Your system is not currently compatible with Foam installation requirements. Review the error messages and consult the documentation for further instructions. frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.4$ foamInstallationTest Executing /home/frpelikan/OpenFOAM/OpenFOAM-1.4/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: Techn-028 OS: Linux version 2.6.24-19-generic User: frpelikan User_config: /home/frpelikan/.bashrc Foam_config: /home/frpelikan/.OpenFOAM-1.4/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/frpelikan/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/frpelikan/OpenFOAM/frpelikan-1.4 yes no $FOAM_JOB_DIR /home/frpelikan/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/frpelikan/OpenFOAM/OpenFOAM-1.4 yes yes yes $FOAM_USER_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes no $FOAM_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes yes $WM_DIR ...rpelikan/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH ...pelikan/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH ...mico-2.3.12/platforms/linuxGcc4DPOpt yes yes yes $LAM_ARCH_PATH ...c/lam-7.1.2/platforms/linuxGcc4DPOpt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...FOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt yes yes yes $FOAM_USER_LIBBIN ...OAM/frpelikan-1.4/lib/linuxGcc4DPOpt yes yes no $LAM_ARCH_PATH ...c/lam-7.1.2/platforms/linuxGcc4DPOpt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.2.3 WARNING: Conflicting installations: foam settings: /home/frpelikan/OpenFOAM/linux/gcc-4.1.2-64/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java /home/frpelikan/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.12 /bin/gzip tar 1.3.12 /bin/tar icoFoam ...M/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_Techn-028 Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Unsuccessful_connection_refused* yes FATAL ERROR: No remote shell available. Foam1.4 enviroment requires either ssh and/or rsh. Contact your system administrator. ------------------------------------------------------------------------------- The system test has evoked 1 fatal error(s). The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. I am highlighting what I think is the error. I have tried to contact my IT department in this regard but they are of no help as I am the first person here to be working in Linux. Another problem is when I tried to run blockMesh . cavity I get the following error, frpelikan@Techn-028:~/OpenFOAM/mayank/run/tutorials/icoFoam$ blockMesh . cavity bash: /home/frpelikan/OpenFOAM/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/blockMesh: No such file or directory this i cant understand as I have sourced the file correctly. Can you please help me as I have tried everything available on the internet for the last 2 weeks but have been really helpless and am desperate. Thanx in advance |
July 17, 2008, 09:44 |
Try OpenFOAM-1.5. I think it h
#14 |
Eugene de Villiers
Rep Power: 21 |
Try OpenFOAM-1.5. I think it has better support for Ubuntu.
March 9, 2012, 07:50 |
Install OpenFOAM-1.4.1 on Linux
#15 |
kunar
Rep Power: 15 |
Dear foamers,
i install OF-1.4.1 linux ,i download all files(OpenFOAM-1.4.1.General.gtgz,OpenFOAM-1.4.1.linuxGccDPOpt.gtgz,OpenFOAM-1.4.1.linuxGccSPOpt.gtgz,paraview-2.4.4.linux.tgz, j2sdk1.4.2.os.linux.tgz from www.openfoam.org or sourceforge.)except gcc-4.1.1.linux.tgz.i dont how to download gcc-4.1.1.linux.tgz file.please help me where i can get this file. |
March 9, 2012, 17:20 |
#16 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kumar,
You can get Gcc 4.1.2 from OpenFOAM 1.4: http://sourceforge.net/projects/foam/files/foam/1.4/ But for OpenFOAM 1.4.1, it seems that you should use at least Gcc 4.2.1: http://sourceforge.net/projects/foam/files/foam/1.4.1/ Either way, you don't need Gcc 4.1.1. Best regards, Bruno
March 10, 2012, 03:46 |
flapping wing
#17 |
kunar
Rep Power: 15 |
Dear Bruno,
really thanks for information,i am working in flapping wing analysis,for that i have to find lift,drag and thrust.right now i have the input data is(velocity=2m/s,throttle speed,and xyz coordinates of model with xyz data 33 rows and 225 columns in .csv file format,how i can create block mesh and how i can import all xyz coordinates allready i work OF 2.1 in that i work tutorials cavity,airfoil,but my laptop get crashed and i have little knowledge about OF,for this flapping wing my point of view is, step1.i import xyz coordinates of data and create block mesh 2. and create snappy hex mesh 3. solver is icofoam(laminar incompressible flow) but how i import my data and how i can start Please help Kind regards kumar. |
March 16, 2012, 21:16 |
#18 |
Bruno Santos
Rep Power: 128 |
Hi Kumar,
I didn't even gather enough strength to answer you sooner. You've posted a question that isn't remotely related to this very old thread. If you want to get help on this forum, you better learn a bit more how it works: How To Get Help On The Message Board Best regards, Bruno
Help with parallel working instalation. | Jonathan | FLUENT | 9 | November 8, 2011 00:25 |
Help in Instalation of OpenFOAM | duartealbuquerque | OpenFOAM Installation | 3 | March 12, 2009 00:44 |
141 Instalation on Fedora Core 8 with Pentium 4 | markozeta | OpenFOAM Installation | 0 | April 16, 2008 20:52 |
Comet Instalation | Merkru | Siemens | 0 | June 12, 2006 04:31 |
cfx-4.2 or cfx-4.3 instalation | Antonio Melendez | CFX | 1 | June 28, 2001 04:58 |
