March 8, 2007, 17:44 |
Thanks Martin & Hrvoje for tho
#21 |
Chris Harvey
Thanks Martin & Hrvoje for those incredibly fast replies. I got the soft link to work (strange... I tried that before but kept getting "No such file or directory" errors. It works now though so nevermind). It is a quick and dirty solution though (as Bernhard said) so I will at some point try to rebuild as described as well.
Thanks for your help, Chris |
March 17, 2007, 13:29 |
I'm a super new to OpenFOAM, a
#22 |
Ben Hawkins
Rep Power: 17 |
I'm a super new to OpenFOAM, and as a Mac user, very excited about the possibility of using it natively. However, I'm having trouble running it. I've followed the directions given at the top, but not successfully. My questions are:
1. After these instructions, is a compile required? 2. What should be in .bashrc? It contains OpenFOAM relavent text, so I'm not sure where to put the "source..." line. Thanks! |
March 19, 2007, 14:42 |
Hi Ben!
@1: If you download
#23 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Ben!
@1: If you downloaded the binaries: No @2: Which bashrc? The one in your home directory? That should be just the same as in the general OpenFOAM-installation instructions What exactly are your troubles?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 20, 2007, 09:17 |
Thanks for the reply.
1. I
#24 |
Ben Hawkins
Rep Power: 17 |
1. I did so I'm not missing anything there. 2. I've tried this with both ~/.basrch and ~/.cshrc, they both contain OpenFOAM comment blocks at the top. I've added the lines as per the instructions above, and still get "command not found" for FoamX. I can write the whole path out, and that calls FoamX but then I get an error: "Can't find FoamX configuration directory at /.-/apps/FoamX." |
March 20, 2007, 09:59 |
Figured it out. New error is:
#25 |
Ben Hawkins
Rep Power: 17 |
Figured it out. New error is: "/Users/g4ben/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 122: nsd: command not found"
and hangs. Thanks again for the help! |
March 20, 2007, 10:03 |
FoamX does not work: use OpenF
#26 |
Hrvoje Jasak
Rep Power: 33 |
FoamX does not work: use OpenFOAM applications straight from the xommand line (xterm).
Sorry, there was too many problems compiling mico on OS X. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
March 21, 2007, 04:30 |
Hi I tried to open ParaView, b
#27 |
Hi I tried to open ParaView, but the following error message poped up:
Major opcode of failed request: 129 (Apple-DRI) Minor opcode of failed request: 1 () Serial number of failed request: 1146 Current serial number in output stream: 1146 could anyone help me, please? I am a beginner mac/linux user. felicia |
March 21, 2007, 08:26 |
This seems like a problem betw
#28 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
This seems like a problem between paraview and the X-Server. Maybe the paraview-list is a better source for that problem.
But: - When does the problem occur (before or after the splash-screen ....) - What is your architecture (PowerPC or Intel)? - Which verison of the OS/X-Server (xdpyinfo gives that kind of info)? - what is the output of glxinfo | grep direct xdpyinfo | grep Apple - does paraview (not Foam) work? (you could also try if the problem persists with the original paraview from their site)
March 21, 2007, 09:31 |
An add-on comment: you need to
#29 |
Hrvoje Jasak
Rep Power: 33 |
An add-on comment: you need to run paraview from xterm - and xterm is something that does not come with your standard installation. You can get it for free from the Apple web site.
Hrv
March 21, 2007, 09:36 |
Hi Bernhard,
Thank you for r
#30 |
Hi Bernhard,
Thank you for replying to my message. Answer to your question in order: - Problem I could not even get a splash-screen working now. It worked before, but when I restarted my computer it does not work anymore - Architecture: Intel Duo Processor (I just bought this MacBook, and I am very new to them.) - I would say I have the Mac OS X latest version. I am not aware as to what are the available version out there. - output of: felicia-tristantos-computer:~ flic$ glxinfo | grep direct direct rendering: Yes -output of: felicia-tristantos-computer:~ flic$ xdpyinfo | grep Apple Apple-DRI Apple-WM Both outputs are obtained from typing command in xterm windows. I do not understand why I am getting different error message. I was very sure that the problem that paraView did not opened up is because I do not know how to set the $DISPLAY environment. I typed: source ~/.bashrc then when I typed paraFoam . cavity, it comes out with this message: /Users/flic/OpenFOAM/OpenFOAM-1.3/bin/paraFoam: line 57: paraview: command not found -flic- |
March 21, 2007, 09:49 |
Hi Hrv,
Yep, I have install
#31 |
Hi Hrv,
Yep, I have installed X11 from the installation CD that comes with it. I basically followed installation guide from the following link: http://xanana.ucsc.edu/xtal/x11.html after I installed X11, when I typed paraFoam . cavity it asks for the $DISPLAY environment. Then I typed: touch ~/.bashrc but do not know how to insert the attached .bashrc file in the above link to the file. after this, when I ran ParaFoam . cavity it gives the following error: bash: paraView: command not found cheers, felicia |
March 21, 2007, 09:54 |
Hi Felicia!
OK. Your archit
#32 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Felicia!
OK. Your architecture is an Intel (mine is PowerPC so I won't be able to reproduce your problem). Which binaries are you using? My theory is that they are PowerPC (at least the last time I looked only those were available) and they have trouble talking to the X-Server (which is an Intel-binary). But that is a guess. I think I'll have to pass the question to someone who is running OpenFOAM on an Intel-MacOS. (Anyone? Could you please stand up?) Bernhard
March 21, 2007, 10:08 |
paraview - all lowercase, righ
#33 |
Hrvoje Jasak
Rep Power: 33 |
paraview - all lowercase, right?
Could you try saying 'which paraview' and find out if the directory exists etc. Mine lives under ~/OpenFOAM/darwin/paraview-... Having in mind that you're running a shiny new Intel Mac and Bernhard and I are still in the last century, could you tell me if this worked before + did you compile paraview yourself. Did you mount the disk images (if that's now you work)? Keeping my fingers crossed, Hrv
March 21, 2007, 20:48 |
Hi Hrv, Bernhard,
I'm Felic
#34 |
Richard Morgans
Rep Power: 17 |
Hi Hrv, Bernhard,
I'm Felicia's supervisor - we're both new to the mac world. I've had a little experience with linux and a small amount of OF. Somehow the darwin disk image became unmounted since I last tried + xterm sources .bashrc and terminal sources .bash_profile -> this is all fixed now. Which paraview finds it in the same place as above, and running paraview brings up the splash screen and then dumps the same error as above. we haven't compiled paraview ourselves. If this is the next obvious step we'll give it a go (unless anyone knows of paraview-2.4.3 binaries for intel mac? - or is it likely that the 2.4.4 binaries from the paraview website will work? Actually given time constraints, I'm downloading paraview 2.6 binaries, will see if I can get something like this (http://oshima.eng.niigata-u.ac.jp/Op...-20070224.html) working. Will let you know if we have success. Cheers Rick |
March 22, 2007, 06:24 |
I'm afraid there are no Intel-
#35 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I'm afraid there are no Intel-Darwin-binaries at
http://www.paraview.org/files/v2.4/ Try the 2.6-Binaries found there. If they work you might as well try recompiling 2.6 (it's the same effort). The process of recompiling paraview is quite good documented. The problem might be to compile the 'glue' between paraview and Foam (I had to hand-patch some files on my Mac before I succeeded, but that was with a 2.4-version. Might be better with 2.6). On the other hand: if I remember it correctly the 2.6-source-tree has an OpenFOAM-reader. I just don't know if it is enabled in their standard-binaries. If it is you might safe you all the trouble of recompiling. I know: there's a lot of if/might/should in this message, but it's the best I know.
March 22, 2007, 08:26 |
You may be in trouble (let's h
#36 |
Hrvoje Jasak
Rep Power: 33 |
You may be in trouble (let's hope not). I had a ton of problems with the Mac build and had to manually fiddle the build flags in order to get it to work. If you "just compile" it, the executable will start up, show a banner and then fall over.
The other issue is that you need a full build, with all the header files, position-specific derivaed headers from cmake etc just to rebuild the OpenFOAM reader. The last issue is whether the binary build has been done with shared libraries or not: by default, they used to be off, which will not work. In any case, the time is nigh for me to re-port all my bug fixes etc to the Mac, so please keep me posted. Hrv
March 22, 2007, 09:39 |
I meant to do this some time a
#37 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I meant to do this some time ago: I've added a list of things I had to do in order to compile OF1.3 on a Mac on the Wiki:
http://openfoamwiki.net/index.php/Ho...e_OpenFOAM_Mac My guess is that most of the stuff you don't have to do if you're using Hrv's images as a basis and only clean out the PPC-binary files. Only the last thing (the flag for the PVReader - if I remember it correctly cmake overwrites it every time) @compiling paraview to cooperate with OF: maybe http://openfoamwiki.net/index.php/Howto_compile_OpenFOAM#Compiling_and_installin g_ParaView can be helpful (you might want to interpolate it with http://www.paraview.org/Wiki/ParaView:FAQ#How_do_I_compile_ParaView_for_Mac_OS_ X .3F)
April 3, 2007, 11:05 |
Not sure if this helps anyone,
#38 |
Ben Hawkins
Rep Power: 17 |
Not sure if this helps anyone, but I know one of the major problems compiling FoamX was mico:
http://mico.darwinports.com/ |
April 3, 2007, 16:24 |
Mico is all done and working -
#39 |
Hrvoje Jasak
Rep Power: 33 |
Mico is all done and working - did anyone manage to right click?
Hrv
April 10, 2007, 20:32 |
Greetings everyone!
This is
#40 |
Rep Power: 18 |
Greetings everyone!
This is my first post over here. First of all, thank you very much Hrvoje for your Mac porting! I am just learning how to use OpenFOAM and so far I do whole tutorial under my linux machine where everything works and is stable. Then I try to do the same things on my Mac machine - which is also stable, but to be sure first I try in linux. The only problem which I experience on Mac is a paraFoam file opener. Software opens, however it has got some problems with opening .foam files. It means, I do: paraFoam <root> <example> What happens paraviem/Foam opens in X11 environment (as it should), however it doesn't want to open the picked file. After paraview is launched, I can only point out to file manually, but even then it cannot open it, the paraview is somehow stucked, but functional so I can stop openning etc. What I discovered, when I click File -> Open there is no .foam extension to choose in file extension list (on Mac machine), whereas on my linux box it appears as (probably) a second one from the bottom. Any ideas or tips how to open these .foam files in paraview under Mac, so I can actually see how structure/example looks like? Actually, I am playing in tutorial with '..path../icoFoam cavityGrade' example. Thanks! And thanks for a great work with OpenFOAM Mac port! Krystian |
Differences OpenFOAM12 and OpenFOAM13 | lr103476 | OpenFOAM Running, Solving & CFD | 43 | July 22, 2008 17:46 |
OpenFOAM14 for Mac OSX Darwin 104 | gschaider | OpenFOAM Installation | 118 | July 20, 2008 06:19 |
Problems in OpenFOAM13 srcthermophysicalmodelsliquid | aderliner | OpenFOAM Running, Solving & CFD | 1 | March 18, 2007 02:33 |
What is wrong with the OpenFOAM13 on Cygwin151 | waynezw0618 | OpenFOAM Installation | 0 | November 6, 2006 21:31 |
Help%7e%7einstall openfoam13 on fc5%7e%7e | aderliner | OpenFOAM Installation | 2 | September 11, 2006 08:24 |
