#61 |
Pierre-Olivier Dallaire
Rep Power: 17 ![]() |
Thanks !
Also, openmpi 1.2.3 comes pre-compiled with XCode g++ --v Using built-in specs. Target: i686-apple-darwin9 Configured with: /var/tmp/gcc/gcc-5465~16/src/configure --disable-checking -enable-werror --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/lib --build=i686-apple-darwin9 --with-arch=apple --with-tune=generic --host=i686-apple-darwin9 --target=i686-apple-darwin9 Thread model: posix gcc version 4.0.1 (Apple Inc. build 5465) |
#62 |
I compiled openfoam on Leopard, some notes :
1) As suggested by Bernhard, a minor modification must be done in uintIO.C 2) With the opengl bug, a flag must be added for foamDebugSwitches : -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries /libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/li bGL.dylib 3) Problem with FoamX and Java -> compiled with error and FoamX does not work ... Good evening, PO |
#63 |
adding "-source 1.4" to java flags (in file make/rules/General/java) will solve java critical errors
PO |
#64 |
Bernhard,
Are you putting all of the OSX patches into 1.4.1-dev? I assumed that you probably had done this, but when I tried to build 1.4.1-dev on 10.5, it complained about not recognizing Darwin. Closer inspection of OpenFOAM-1.4.1-dev/.bashrc, etc. shows that the patch has not been applied.... Is there an easy way to get the OSX patch off the svn repostitory? Eric |
#65 |
Hrvoje Jasak
Rep Power: 33 ![]() |
That would be my fault, in two ways:
- I didn't merge the Darwin bits from 1.3 to 1.4.1-dev - I haven't re-ported to Mac OSX, in expectation of Leopard. The beast is now in the post and when I upgrade my Macs, the dev line will be ported and packed up into sparse disc images. Bernhard, if there is a way to push the Darwin porting changes into the dev line, please have a go. Thanks, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
#66 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 ![]() ![]() |
Hi Eric, Hi Hrv!
The reason I never put the Mac-Patches into the dev is that I didn't have the disk space on my iBook for two separate OpenFOAM-Installations and I didn't want to inject it into svn from my Linux-machines (where I obviously can't test it) I will try to do it over the weekend (if the mighty god of diskspace allows it) Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
#67 |
Holly Corbett
Hi all,
I'm trying to compile on my Macbook running Leopard. Have added the rules to the directory, and applied the patch, but when .OpenFOAM-1.4.1/.bashrc runs, I get the following error message: Your Darwin operating system is not supported by this release of OpenFOAM. For further assistance, please contact www.openfoam.org I'm using MacPorts 1.6.0 - really not sure where to go from here. Any help would be greatly appreciated. Cheers, Holly. |
#68 |
Assistant Moderator
Bernhard Gschaider
Hi!
In .OpenF.OpenFOAM-1.4.1/bashrc there should be an entry concerning darwin just before the comment that says "An unsupported operating system". Otherwise the patch was not correctly applied/the patch-file is faulty. What does patch say if you apply the patch again (at least it should complain about a previously applied patch in some places) Bernhard
#69 |
Holly Corbett
Thanks for the assistance - the darwin part is there, and it says this: Mac OS X 10.4 Darwin # ~~~~~~~~~~~~~~~~~~~~ elif [ "$machineTest" = "Darwin" ]; then export WM_ARCH=darwin export WM_COMPILER= export WM_MPLIB=OPENMPI MACOSX_DEPLOYMENT_TARGET="10.4" Then when I run the patch, this is what happens: b-macbook ![]() patching file .bashrc Reversed (or previously applied) patch detected! Assume -R? [n] y patching file .OpenFOAM-1.4.1/bashrc Reversed (or previously applied) patch detected! Assume -R? [n] y Hunk #1 succeeded at 156 (offset 1 line). patching file .OpenFOAM-1.4.1/apps/paraview/bashrc patching file wmake/src/lex.yy.c Reversed (or previously applied) patch detected! Assume -R? [n] y patching file wmake/rules/darwin/c++Debug patching file wmake/rules/darwin/c patching file wmake/rules/darwin/mplibMPICH patching file wmake/rules/darwin/cDebug patching file wmake/rules/darwin/mplibOPENMPI patching file wmake/rules/darwin/c++Opt patching file wmake/rules/darwin/.gdb_history patching file wmake/rules/darwin/mplibLAM patching file wmake/rules/darwin/c++Prof patching file wmake/rules/darwin/mplib patching file wmake/rules/darwin/cOpt patching file wmake/rules/darwin/X patching file wmake/rules/darwin/c++ patching file wmake/rules/darwin/cProf patching file wmake/rules/darwin/general patching file wmake/wmakeLnInclude patching file wmake/wmake patching file wmake/Makefile patching file applications/utilities/postProcessing/graphics/PVFoamReader/Allwmake patching file applications/utilities/miscellaneous/foamDebugSwitches/Make/options patching file applications/utilities/preProcessing/mapFields/Make/options patching file applications/utilities/preProcessing/FoamX/C++/FoamXLib/ITypeDescriptorImpl.C patching file applications/utilities/parallelProcessing/decompositionMethods/metis-5.0pre2/GKl ib/trunk/error.c patching file applications/utilities/parallelProcessing/decompositionMethods/metis-5.0pre2/GKl ib/trunk/memory.c patching file applications/utilities/parallelProcessing/decompositionMethods/metis-5.0pre2/GKl ib/trunk/gk_externs.h Reversed (or previously applied) patch detected! Assume -R? [n] y patching file applications/utilities/parallelProcessing/decompositionMethods/metis-5.0pre2/GKl ib/Make/options patching file applications/utilities/parallelProcessing/decompositionMethods/parMetisDecomp/Pa rMetis-3.1/ParMETISLib/stdheaders.h patching file applications/utilities/mesh/conversion/ccm26ToFoam/libccmio/libcgns/Make/options Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/Allwmake Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/thermophysicalModels/chemistryModel/chemistryModel/chemistryModel.H Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/dynamicMesh/fvMeshDistribute/fvMeshDistributeTemplates.C Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/MGridGenGamgAgglomeration/ParMGridGen-1.0/MGridGen/Lib/mgridgen.h Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/MGridGenGamgAgglomeration/ParMGridGen-1.0/MGridGen/Lib/Make/options Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/MGridGenGamgAgglomeration/ParMGridGen-1.0/MGridGen/IMlib/IMlib.h Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/OpenFOAM/OSspecific/Unix/printStack.C Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/OpenFOAM/OSspecific/Unix/clockTime/clockTime.H Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/OpenFOAM/OSspecific/Unix/fileStat.C Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/OpenFOAM/primitives/ulong/ulongIO.C Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/OpenFOAM/primitives/Scalar/doubleFloat.H Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/OpenFOAM/primitives/Scalar/Scalar.H Reversed (or previously applied) patch detected! Assume -R? [n] y patching file src/triSurface/triSurface/interfaces/NAS/readNAS.C Reversed (or previously applied) patch detected! Assume -R? [n] y patching file bin/patchTool Reversed (or previously applied) patch detected! Assume -R? [n] y patching file bin/FoamX Reversed (or previously applied) patch detected! Assume -R? [n] y patching file bin/killFoamX Reversed (or previously applied) patch detected! Assume -R? [n] y patching file bin/foamEndJob Reversed (or previously applied) patch detected! Assume -R? [n] y patching file bin/foamInstallationTest Reversed (or previously applied) patch detected! Assume -R? [n] y patching file bin/runFoamXHB Reversed (or previously applied) patch detected! Assume -R? [n] y and then I try and . $HOME/.bashrc I get this: Your Darwin operating system is not supported by this release of OpenFOAM. For further assistance, please contact www.openfoam.org. Executing: /Volumes/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/ensightFoam/bashrc Executing: /Volumes/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/paraview/bashrc Thanks for the assistance |
#70 |
Assistant Moderator
Bernhard Gschaider
OK. The patch seems to be alright (sorry for doubting you). Obviously (but I'm not really good with shell-programming )"$machineTest" is "Darwin" because it is printed like this by the catch-all-else from the original and the elif-condition printed above should be true.
Could you source the bashrc from the command line with . ~/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc and see what happens? Add some echo-commands to the script and see what parts actually get sexecuted (I really don't know what could be the problem) Bernhard
#71 |
Holly Corbett
Well that was exciting...
So just before I sourced the bashrc, I thought I'd check it - and lo and behold.. no Darwin section. So I reapplied the patch again.. checked it.. and there was a Darwin section.. so I sourced it - it ran perfectly. I ran OpenFOAM-1.4.1/Allwmake and it appears that everything went great :D So I attempt to run FoamX.. and I get this: b-macbook:tutorials Holly$ FoamX /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94458) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94464) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94471) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94478) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94485) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94492) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94499) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: . . (so it goes on...) . . line 88: kill: (94741) - No such process /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/killFoamX: line 88: kill: (94748) - No such process Starting NameServer with inet:b-macbook.aibn.uq.edu.au:1234 ... Starting FoamX Host Browser with inet:b-macbook.aibn.uq.edu.au:1234 ... /Volumes/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 139: FoamXHostBrowser: command not found runFoamXHB : cleanup runFoamXHB: Name server is not running. Hopefully this makes sense to someone - I have no idea. Any help much appreciated ![]() - Holly |
#72 |
Assistant Moderator
Bernhard Gschaider
Hi Holly!
I hardly use FoamX. I remember that some of the shell-scripts that call FoamX got patched because some commands on MacOSX behave BSDy (as opposed to the Linuxy behaviour that is assumed by the original OF-scripts). MAYBE (I don't have Leopard) this behaviour has changed and now these patches are contraproductive. Look at the patch-file. Maybe manually reversing the relevant patches helps. Bernhard
#73 |
Sung-Eun Kim
Hi Bernhard,
Greetings from D.C. Any progress on MAC patch to the dev version? |
#74 |
Assistant Moderator
Bernhard Gschaider
Hi!
You mean Hrv's version on https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/O penFOAM-1.4.1-dev/ ? The patches were submitted some time back (and are in the repository) but I forgot to announce it. Bernhard
#75 |
Sung-Eun Kim
I compiled 1.4.1 on MAc OX10.4 darwin intel processor, and tried to run paraview. This is what I got. =========================================== ParaView error: InitializeTcl failed Tk_Init error: no display name and no $DISPLAY environment variable ============================================ Cab someone tell me what's going on and what I should do? Thanks, |
#76 |
Hrvoje Jasak
Did you start it from xterm + are you running X?
Hrv
#77 |
Sung-Eun Kim
I thought I was running X, but I actually wasn't. M X11 applications were not working because of that, Thanks for poining this out. BTW how are you handling going back and force between xterm and shell terminal on MAC?
Thanks in advance, |
#78 |
Sung-Eun Kim
Hrv's dev version doesn't compile properly because the linker can't locate libraries. The rror message looks like /usr/bin/ld: can;t locate file for: -lfiniteVolume Can anybody tell me how to resolve this? It appears there's something to do with $LIB_SRC. TIA |
#79 |
Heinz-Jürgen Geurtz
Location: Althengstett-Neuhengstett, Baden-Württemberg, Deutschland
Hello All,
I'm trying to install OpenFoam-1.4.1. My current platform is a iMac Intel DuoCore with MacOsX-10.5.2. Iwas following the instructions also given on the Wiki (Installation of 1.4.1). Allwmake exits at the same point with message: make[2]: *** [/Users/heinzjuergengeurtz/OpenFOAM/OpenFOAM-1.4.1/applications/bin/darwinDPOpt/ mixtureAdiabaticFlameT] Error 1 make[1]: *** [mixtureAdiabaticFlameT] Error 2 make[1]: Target `application' not remade because of errors. make: *** [thermophysical] Error 2 make: Target `application' not remade because of errors. + '[' 0 = 1 -a '' = doc ']' Has anybody an idea how to solve this??? Live long and prosper... HJG
Live long and prosper ... Glückauf HJG |
#80 |
Assistant Moderator
Bernhard Gschaider
Hi HJ!
There must be another error message before the one you posted (I really appreciate that you do not post the whole compile-output). Just run it again with (assuming bash) ./Allwake 2>&1 | tee compile.log and look in the compile.log for the first error before the message you were posting Bernhard
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 05:06 |
VTK errors in ParaFOAM on OpenFOAM14 | stevemchale | OpenFOAM Installation | 5 | August 29, 2007 15:39 |
Compilation from source failed OpenFOAM14 | hsieh | OpenFOAM Installation | 1 | June 20, 2007 10:06 |
Probes in OpenFOAM14 | otsuki | OpenFOAM Running, Solving & CFD | 2 | May 16, 2007 06:18 |
Port of OpenFOAM14 to FreeBSD | thierry | OpenFOAM Installation | 0 | April 28, 2007 09:36 |
