July 21, 2008, 06:39 |
hi,
I have a macintosh and
#101 |
mayank gupta
Rep Power: 17 |
hi,
I have a macintosh and luckily openfoam-1.4.1 is running good on it. but i need to solve for lift and drag on a 2-d airfoil and the liftDrag solver is not there in my postprocessing utilities or src directory. I wrote a code and wanted to add it to the utility but am unable to do so. It says the openfoam-1.4.1 can not be modified. Could anyone please tell me how to solve this problem? thanx a lot. |
July 21, 2008, 07:42 |
There are many ways to skin th
#102 |
There are many ways to skin the cat, however, none of them have anything to do specifically with MacOSX (this really belongs in a force/moment/liftDrag/forceAndTorque/forces/forceCoeffs thread). Anyway, you can do the following:
1. write your own code 2. download the liftDrag class and the liftDrag post-processor from the forum. I think this stuff is from 1.2 vintage OF. 3. download and compile 1.4.1-dev from the openfoam-extend project. This includes forceAndTorque class which is compiled into a library ($(FOAM_LIBBIN)/libincompressiblePostProcessing) and can be called at runTime in the controlDict. 4. download and compile 1.5. This includes force and forceCoeffs classes which are compiled into a library ($(FOAM_LIBBIN)/libforces) which gives the same capability as was provided in 1.4.1-dev. Eric |
OpenFOAM 15 icc build | mschoenberg | OpenFOAM Installation | 4 | October 2, 2008 01:09 |
How can I build OpenFOAM in cygwin | joywe | OpenFOAM Installation | 10 | September 12, 2008 10:39 |
OpenFOAM 14 Parallel build | mplongjr | OpenFOAM Installation | 3 | May 15, 2007 04:32 |
OpenFOAM build from source instructions | tj22 | OpenFOAM Installation | 7 | April 6, 2006 17:15 |
Build OpenFOAM on Tru64 | francois | OpenFOAM Installation | 18 | April 4, 2006 06:45 |
