Build OpenFOAM on MacOSX
Old   January 16, 2006, 06:47
Default Heya, Environment variables
  #61
Hrvoje Jasak
Heya,
Environment variables: the idea is that you copy the OpenFOAM-1.2/.OpenFOAM-1.2 directory into your home directorn and change and source it from there:
source ~/.OpenFOAM-1.2/cshrc
(as well as the apps stuff)
This will allow you to set up the additional environment variables (separating the installation and your own stuff) into separate places.
paraView script: I haven't seen problems (sorry, couldn't resist it). This is one of Mattijs's and I will defer the suggestions to him
Paraview: still causing trouble. If I build the release build, it fails as I have described earlier and I cannot help it (I will carry on playing with it...). However, the debug build runs fine and that's what I've got for the moment. The switch is under the basic cmake options when you build paraview and I'm still not happy about this. Have you tried bulding paraview locally?
Hrv
Hrvoje Jasak
Old   January 16, 2006, 14:48
Default paraview, PATH and LD_LIBRARY_
  #62
Mattijs Janssens
mattijs is on a distinguished road
paraview, PATH and LD_LIBRARY_PATH : we'll add them to the front, like the path to gcc and java.
mattijs is offline   Reply With Quote
Old   January 17, 2006, 05:43
Default Heya, After a lot of messin
  #63
Hrvoje Jasak
Heya,
After a lot of messing about, I have found out that paraview fails if it's compiled with more optimization than -O1. I 've got a working version without the debug symbols, it's much smaller and a bit faster. Everything else is rebuilding once more (switched to paraview-2.4.2) and I'll update the disk images in due course.
Thanks for your help everyone,
Hrv
Hrvoje Jasak
Old   January 18, 2006, 12:16
Default Hi Bernhard, I'm having a b
  #64
Hrvoje Jasak
Hi Bernhard,
I'm having a bit of trouble with this disk image stuff. I've set it up exactly as we've said (tried both the compressed and uncompressed disk image) and the environment looks good. I also have an external disk that has been used for the build.
When I try and run with the external disk attached, all is well. The paths and libraries point to the installation and I thought that would be it. However, if I unmount my external disk and try using the installation on its own, the apps don't run and complain that the external disk libraries could no be reached. This is in spite of the fact that the libraries are correct and present in the installation disk images.
This looks pretty crappy to me and I believe I've done something stupid (especially if you've managed to run off the disk images I have prepared). Any ideas?
Hrv
Hrvoje Jasak
Old   January 18, 2006, 12:42
Default Hello Hrv The problem is, t
  #65
Assistant Moderator
Bernhard Gschaider
Hello Hrv
The problem is, that I tried to make your images work without making them writeable. I "emulated" your setup by mounting the images and then creating a directory "/Volumes/MacExternal/local" and creating a symbolic link in that to the image. So for the binaries it looks "just like Hrv's disk". And therefor I never had this problem.
If I interpret your problem correctly the paths to the dylibs are "hardcoded" in the library and the LD_LIBRARY_PATH is ignored. I never had this problem with my build because I built it on the image in the first place (so I might have the same problem).
I can't test this theory right now, but I'll get back to you tomorrow.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 18, 2006, 12:47
Default I meant to say: hardcoded in t
  #66
Assistant Moderator
Bernhard Gschaider
I meant to say: hardcoded in the binaries
Old   January 19, 2006, 07:21
Default Bernhard wrote: > If I inte
  #67
Markus Hitter
traumflug is on a distinguished road
> are "hardcoded" in the library ...
You are right, it's an unfortunate requirement of mach-o (Mac OS X) libraries to have their own installation path compiled in. Either an absolute path or a path relative to the executable.
So, to move them around, you have to fix the installation path inside the dylib each time. See libtool's -installpath option and Xcode's documentation.
GNU/OpenSource software usually solves this problem by installing libraries into well known places, including compiling this well known path into the lib or changing the built in path at installation time.
Preferred Mac OS X way is, to put the libraries into the app's bundle and to compile a relative path into the lib. This makes applications moveable, no installer required.
I don't know enough about OpenFOAM to give an educated suggestion, yet (I didn't solve _any_ problem, yet *sigh*). Today I had a chance to download Hrvoje's "distribution", so I hopefully find some time over the weekend to get into the materia.
Bundling everything into a single app would be just great :-)
Markus
traumflug is offline   Reply With Quote
Old   January 19, 2006, 10:58
Default I think the easiest solution w
  #68
Assistant Moderator
Bernhard Gschaider
I think the easiest solution would be to decide on a directory where OpenFoam should exist on a Mac (For instance /OpenFOAM )
Inside of this directory should reside the directories: OpenFOAM-1.2, OpenFOAM-1.3, user-1.2 etc.
Whether these directories are there "for real" or just by symbolic linking to their real place (for instance inside a DiskImage: 'ln -s /Volumes/OpenFOAM-1.2readOnlyDist/OpenFOAM-1.2 /OpenFOAM/OpenFOAM-1.2') would make no difference.
That way libraries would always be found at a "standard"-path (/OpenFOAM/OpenFOAM-1.2/lib/darwin/libOpenFOAM.dylib for instance).
User installation would be 'ln -s /OpenFOAM ~/OpenFOAM'.
@"a single app": that would be FoamX ;-)
Old   January 22, 2006, 17:05
Default Easy. Embarassingly easy:
  #69
Hrvoje Jasak
setenv DYLD_LIBRARY_PATH $LD_LIBRARY_PATH
and all is well.
I think this concludes matters. I have re-packed the disk images for nicer links and you can even run off compressed images. I'm really happy with this. If someone want to have a go at replacing MICO with another Corba implementation, please give me a shout. I'll cross the port off my development list :-)
Thanks for you help everyone,
Hrv
Hrvoje Jasak
Old   February 14, 2006, 10:08
Default Hello, I am a newbie to Ope
  #70
Ganesan Subramanian
ganesan is on a distinguished road
I am a newbie to OpenFOAM. I installed it on my MacOSX thanks to Hrvoje Jasak (from his disk img and instructons).
Now what i see is that i am not able to run FoamX. But i have mico, flex and bison....
Is there any one succeeded to use FoamX on Mac OS X or anyone help me on this issue?
ganesan is offline   Reply With Quote
Old   February 21, 2006, 07:29
Default Hi Hrvoje Jasak, Could you
  #71
Ganesan Subramanian
Hi Hrvoje Jasak,
Could you please help me on the following point.
I took a image of your Mac based OpenFOAM. I tried to compile it with your darwin options.
I get error message :
/usr/bin/libtool : ld external link command failed
like this.
COuld you help how to compile myself to take into account the small modifs if i would do in src...especially in combustion..
Regards
Ganesan
Old   February 21, 2006, 07:47
Default For which application/lib does
  #72
Assistant Moderator
Bernhard Gschaider
For which application/lib does the link fail? And is the error message of ld also available?
Just one guess: is the MACOSX_DEPLOYMENT_TARGET environment variable set? At least that's the cause for some linkage-failures on my installation (it should be set to the version of your OS X - "10.3" or "10.4"). It's not set by the OF-scripts but some of the compilation targets need it.
Old   February 21, 2006, 13:14
Default Bernhard Thanks, here is th
  #73
Ganesan Subramanian
Bernhard
Thanks, here is the error :
/usr.bin/ld: can't locate file for : -lcombustionThermophysicalModels it is just an example. But most of the applications were failed.
Concerning MACOSX_DEPLOYMENT_TARGET it was not set bcos i commented it as it was 10.1 by default. I will try and let you by putting 10.4.
thanks
Old   February 21, 2006, 13:29
Default See above: do setenv DYLD_L
  #74
Hrvoje Jasak
See above: do
or the bash equivalent and all should be well. I'll add it to the setup when I rebuild the installation.
Hrv
Hrvoje Jasak
Old   February 22, 2006, 04:38
Default Hello Thanks for helping me
  #75
Ganesan Subramanian
Hello
Thanks for helping me. I did both. DYLD_LIBRARY_PATH setting and MACOSX_DEPLOYMENT_TARGET as well.
i get still /usr/bin/ld: can't locate file for for: -lcfdTools
similar to some other libraries.
What i did : i took the source from you. i used wcleanAll, wcleanAlmostAll and wcleanMachine. so cleaned the objetc files.
i started ./Allwmake... problem is some libraries like cfdTools and -lincompressibleTurbulenceModels etc.. are not there in in the lib/darwinOpt/
my bashrc is exactly the same available in your image disk. DYLD_LIBRARY_PATH i set it in my ~/.bashrc...
i don't understand why it does making dynamic libraries in part....
Thanks
Ganesan
Old   February 22, 2006, 05:00
Default Try this (assuming your using
  #76
Assistant Moderator
Bernhard Gschaider
Try this (assuming your using bash):
./Allwmake 2>&1 | tee Allwmake.out
Open the file Allwmake.out with a text editor and look for the first error. Post the first error AND the command that caused it. When we find a way to fix that first error chances are good that the other stuff is fixed too.
Old   February 22, 2006, 07:37
Default Hi here is the first error :
  #77
Ganesan Subramanian
SOURCE=yylex.c ; gcc -ggdb -Ddarwin -Wall -O0 -I/Users/ganesan/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -c $SOURCE -o Make/darwinOpt/yylex.o
/Users/ganesan/OpenFOAM/OpenFOAM-1.2/wmake/bashScripts/mkObjectDir /Users/ganesan/OpenFOAM/OpenFOAM-1.2/applications/bin/darwinOpt/foamFlex++
g++ -Ddarwin -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -I/Users/ganesan/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -lpthread Make/darwinOpt/foamSkel.o Make/darwinOpt/parse.o Make/darwinOpt/tblcmp.o Make/darwinOpt/misc.o Make/darwinOpt/scan.o Make/darwinOpt/nfa.o Make/darwinOpt/main.o Make/darwinOpt/gen.o Make/darwinOpt/dfa.o Make/darwinOpt/sym.o Make/darwinOpt/ecs.o Make/darwinOpt/ccl.o Make/darwinOpt/yylex.o \
-lpthread -L/Users/ganesan/OpenFOAM/OpenFOAM-1.2/lib/darwinOpt/dummy -lPstream -o /Users/ganesan/OpenFOAM/OpenFOAM-1.2/applications/bin/darwinOpt/foamFlex++
/usr/bin/ld: warning -L: directory name (/Users/ganesan/OpenFOAM/OpenFOAM-1.2/lib/darwinOpt/dummy) does not exist
/usr/bin/ld: can't locate file for: -lPstream
collect2: ld returned 1 exit status
make: *** [/Users/ganesan/OpenFOAM/OpenFOAM-1.2/applications/bin/darwinOpt/foamFlex++] Error 1
Do you think i do not have some libraries not installed on my Mac??
Thanks for help
Old   February 22, 2006, 08:13
Default No. Libraries should be all th
  #78
Assistant Moderator
Bernhard Gschaider
No. Libraries should be all there. The problem is that the the Library libPstream.dylib that is supposed to reside in /Users/ganesan/OpenFOAM/OpenFOAM-1.2/lib/darwinOpt/dummy (==$FOAM_LIBBIN/dummy) isn't there.
The problem seems to be that Pstream is made after flex. Normally this should work anyway when running Allwmake twice (without cleaning). The other way would be to
1. cd to src/Pstream
2. build the library with 'wmake libso dummy'
3. go back to OpenFOAM-1.2
4. do the Allwmake-tango there
(but I can't try this out because I don't want to wclean my installation)
The bottom-line is: never clean out the libraries unless you want to boot-strap your installation from scratch.
Old   February 22, 2006, 08:26
Default Thanks a lot. I did clean bcos
  #79
Ganesan Subramanian
Thanks a lot. I did clean bcos i did not installed the image disk as external... i formatted my Mac to get UFS. then i copied the source. Most of the applications did not work bcos:
binary file wmkdep generated by hrv is having /Volumes/etc.. path while compiling using flex to generate wmkdep...
so i was supposed to do clean..anyway i will try your idea...
Thanks again..
Old   February 22, 2006, 09:16
Default how should i compile if i add
  #80
Ganesan Subramanian
how should i compile if i add a model in Combustion module....could you suggest me
OpenFOAM 15 icc build mschoenberg OpenFOAM Installation 4 October 2, 2008 01:09
How can I build OpenFOAM in cygwin joywe OpenFOAM Installation 10 September 12, 2008 10:39
OpenFOAM 14 Parallel build mplongjr OpenFOAM Installation 3 May 15, 2007 04:32
OpenFOAM build from source instructions tj22 OpenFOAM Installation 7 April 6, 2006 17:15
Build OpenFOAM on Tru64 francois OpenFOAM Installation 18 April 4, 2006 06:45
