Build OpenFOAM on MacOSX
Old   June 13, 2005, 14:05
Default Java is used for FoamX and pat
  #21
henry is on a distinguished road
Java is used for FoamX and patchTool, if you can live without the pre-processor then you don't need it but if you want these applications then you will need a usable Java 1.4.?, older versions will not work.
henry is offline   Reply With Quote
Old   June 14, 2005, 04:47
Default Chris, I copied the OpenFOA
  #22
Matt Amos
mattamos is on a distinguished road
Chris,
I copied the OpenFOAM/wmake/rules/linux directory to "linuxPPC" and edited:
c: changed cc = gcc -m32 to cc = gcc
c++: changed CC = g++ -m32 to CC = g++
c++Opt: added "-mcpu=750" to c++OPT
cOpt: added "-mcpu=750" to cOPT
general: removed the "-melf_i386" option from LD
I can't remember how much of the .OpenFOAM-1.0 directory I changed. I don't think very much except to use my pre-compiled MPICH rather than OpenFOAM's bundled LAM.
Oh, and I also had a pre-compiled version of mico, gcc and all the other stuff that OpenFOAM bundles.
Hope that helps. If not I can post the full diffs.
Matt
mattamos is offline   Reply With Quote
Old   July 18, 2005, 09:51
Default Coming back to the topic of th
  #23
Mauro Augelli
augelli is on a distinguished road
Coming back to the topic of this discussion: the build of OpenFOAM on mac OSX. I tried a lot of way without success. The problem of the file system case-sensitive or not is easily solvable, at least to compile the code. What I do is to create a disk image, to format it as a HFS+ case-sensitive, to mount it and to compile openFOAM on this mounted image.
But, thanks to the suggestions of Mattijs Janssens I can compile something, but at a certain point compiling fails.
Had anyone more chance in compiling openFOAM on OSX?
Thanks,
Mauro.
augelli is offline   Reply With Quote
Old   July 24, 2005, 12:28
Default Here's my update: I have up
  #24
Hrvoje Jasak
Here's my update:
I have upgraded my Mac to OS 10.4 which should make it easier to deal with the filing system issue. I have also bought an external disk and formatted it to be cases sensitive - it si not recommended to re-format the installation disk and do it there because it is likely to show tons of bugs in various applications regarding the "proper" filing system.
I have started the porting and got decent progress. The issues come in two flavours: Unix-related and compiler-related. The unix-related stuff is totally straightforward and deadly boring (reading lits of man pages and looking for headers) and the gcc stuff is due to the tact that OS X comes with gcc version 4.
Now, I cannot be bothered to deal with all of the gcc-4 stuff in foam version 1.1 because Henry tells me he's already done most of it in 1.2. The release of new foam should (have) happened any time soon so I'll carry on with the port once the new version gets officially released.
There will still eb problems with people trying to compile up teir own extensions on a Mac but at least I'll be able to demonstrate what it looks like.
The saga continues...
Hrv
Hrvoje Jasak
Old   September 13, 2005, 05:56
Default Any news with this new version
  #25
Mauro Augelli
Any news with this new version? I have the same troubles to compile it.
Thanks,
Mauro.
Old   September 13, 2005, 06:22
Default Compiled and running over here
  #26
Hrvoje Jasak
Compiled and running over here. I want to fix the linker error I mentioned in the previous message, have a play with paraview etc and we should be in business. I am currently building on the case-sensitive filing system, but there's a bunch of scripts which will change it into .hpp and .cpp files + resolve the name clashes.
The remaining issue is that mico does not compile on OS X, which will require further digging...
Hrv
Hrvoje Jasak
Old   September 13, 2005, 08:38
Default This is a great news!!! When y
  #27
Mauro Augelli
This is a great news!!! When you have fixed the remaining problems (or also before if you want), can you post the main hints to be able to compile OF on OSX?
Thank you so much,
Mauro.
Old   October 19, 2005, 05:59
Default Hello, I am in a rush. I need
  #28
Mauro Augelli
Hello, I am in a rush. I need to perform a CFD calculation. I would like to do it using OpenFoam on OSX, but I cannot compile it. Hrvoje or others can, please, give me some details on how to compile OF on OSX (here or at my email address).
Thanks a lot for any information,
Mauro.
Old   October 19, 2005, 09:32
Default I've got it working on my Mac.
  #29
Hrvoje Jasak
I've got it working on my Mac. However, there is a bug in paraview which makes it core dump on Tiger and I don't want to announce the port before some post-processing is available. The port has been done in collaboration with Julio Ng, working at Apple Inc. and I would like to thank him and the company for their effort.
Further news and ported code will follow once the paraview bug gets fixed (Bug #2193 - MacOS X Tiger with X11 and Tk: segment fault)
Hrv
Hrvoje Jasak
Old   October 24, 2005, 05:33
Default Does the port compile under Pa
  #30
Paul Wells
wells is on a distinguished road
Does the port compile under Panther? Paraview works fine in Panther. I could try compiling if that's any help
wells is offline   Reply With Quote
Old   January 5, 2006, 07:31
Default Hello Hrvoje, being new to
  #31
Markus Hitter
traumflug is on a distinguished road
Hello Hrvoje,
being new to OpenFOAM, but being an CAD and Mac OS X old-timer as well, I'd like to join your porting efforts.
The previous posts sound like you're near to completion. Experience shows, waiting for Apple to fix a bug can take years. Hence, we/I should find a workaround.
As I'm not keen on duplicating your work, could you make some patch against the 1.2 release available - public or privately?
Thanks,
Markus
traumflug is offline   Reply With Quote
Old   January 5, 2006, 08:01
Default Hi Markus, Currently, there
  #32
Hrvoje Jasak
Hi Markus,
Currently, there are only 2 problems:
1) foamFlex.
This is a foam-customised version of flex++ and it is used in several places in the code, e.g. reading mesh files or material properties. The problem occurs when I use foamFlex in 2 libraries and try to link them to the same executable. The one that's causing me trouble is in:
./combustion/chemistryReaders/chemkinReader/chemkinLexer.L
The actual problem is that the lexer has got an inlined virtual destructor and when I do this across 2 libraries I get a multiply defined symbol and (because it is virtual and connected with the virtual function tables) the error is fatal.
Currently, I cannot be asked to fix this one. I believe the compiler is right and major re-organisation of foamFlex is required to get it right. If you know the correct compiler/linker option to get around this one, I'd be very grateful.
Currently, it's hacked and all the apps are OK, I am happy with the temporary solution so let's move on. :-)
2) Post-processing.
As you know, the main post-processor for OpenFOAM is paraview. I can download and use the pre-compiled paraview from their web site and all is well. However, paraFoam uses a reader library and is MUCH more convenient than anything else. In order to build it, I cannot use the pre-built version of paraview (doesn't have all the stuff I need to build the reader library. This brings us to the problem of building paraview on Mac OS X from scratch.
There were a few problems with the older version of paraview (2.2.1) and because I'm running Tiger, I have switched to the latest stable release (2.4.1). Now, this all builds fine but when I try to run it (on its own!) I get a segmentation fault.
There is a bug report on this, but I think this is a red herring. Basically, if Apple can build paraview so that it runs, I should be able to do the same. I am pretty certain this is some linker option that needs to be added but haven't got the time to deal with it (very annoying!).
If you want to get stuck into this, you could download the paraview sources and rebuild paraview from scratch so that it works from your build.
For the rest, I can give you my development source and you can start running OpenFOAM on your Mac - I am interested in some performance numbers as well...
Hrv
Hrvoje Jasak
Old   January 5, 2006, 08:03
  #33
Markus Hitter
Hello Hrvoje,
Thanks,
Markus
Old   January 5, 2006, 08:10
Default Markus, Duplicate post? Co
  #34
Hrvoje Jasak
Markus,
Duplicate post? Could you try again please.
Thanks,
Hrv
Hrvoje Jasak
Old   January 5, 2006, 08:25
Default First, sorry for the double po
  #35
Markus Hitter
First, sorry for the double post. The server didn't appear to respond, so I tried again ...
Not sure about this. Looking at the OpenDarwin 8.0.1 release - it was built inside Apple from what they made available as open source, but nobody outside Apple was able to do this again.
> Now, [paraview 2.4.1] builds fine but when I try to run it
Segfaults can be tackled with a debugger. Easier to find than some hidden bug giving wrong results. :-) I'll check this out.
> For the rest, I can give you my development source ...
That'd be great. Could you make a diff against a public available release, please? As a dial-up user (*sigh*) a 60 MB downloads takes about 3 hour, here.
Thanks,
Markus
Old   January 5, 2006, 12:34
Default Hi! Over XMas holidays i tr
  #36
Assistant Moderator
Bernhard Gschaider
Hi!
Over XMas holidays i tried to compile OpenFOAM on my iBook and succsseded to a degree.
Beeing a lazy guy I decided to avoid the upper/lowercase-issues: i created with the hdiutl-command an image with a case sensitive filesystem (HFS+J if I remember it correctly), mounted it and used it as an "OpenFOAM-partition".
Am I right, that if I get dieselFoam/aachenBomb-case to run the chemkinLexer should be working? With my compile it does (but I havn't looked at the results)
(I linked the libraries with -dynamiclib -undefined dynamic_lookup, the environment variable MACOSX_DEPLOYMENT_TARGET was set to "10.3")
I didn't bother to get FoamX to run.
Same for paraFoam. I used foamToVTK to convert the data and postprocessed it with the newest paraview binary downloaded from the official website.
In the beginning I experienced a segmentation fault when I tried to open the generated vtk-files. After using the -ascii switch of foamToVTK paraview could read the files. I don't know if this is the same segfault you have been experiencing. Could the problem with the binary files be a lowerEndian/higherEndian-problem for the PowerPC?
If I remember it correctly I only had to introduce a new architecture to the bashrc. I then copied the linux-directory in wmake/rules and removed/added some options.
So far I have only tested it only with the damBreak tutorial-case (the results look OK) so I don't dare to speak of a success (but for my purposes everything I need is working)
PS: sorry for this collection of half-informations but I did that stuff 2 weeks ago and didn't have the time to work on it since then and the details got lost in the mist of time
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 5, 2006, 14:00
Default Can you have a try and figure
  #37
Mattijs Janssens
mattijs is on a distinguished road
Can you have a try and figure out that littleendian business?
You only need to define/override in foamToVTK/writeFuns.C the LITTLEENDIAN flag.
Any people with experience on other power architectures (ibm?) or other big-endian machines (mips)
mattijs is offline   Reply With Quote
Old   January 5, 2006, 14:12
Default Almost identical: - I'm run
  #38
Hrvoje Jasak
Almost identical:
- I'm running Tiger (10.4)
- I've used an external disk with a case-sensitive file system
- did not use MACOSX_DEPLOYMENT_TARGET, works anyway
- the lexer I've commented out was in triSurface. I cannot remember which exec refused to link
- the option I've used was -undefined supress; the rest is the same
- some changes to the makefile were required to make it build .dylib files instead of .so
- there was some changes with the system-dependent includes, now properly added on #ifdef-s
- all codes run but I cannot look at the results.
The paraview saga continues... :-(
BTW, Markus, I keep my McSource on my McSite (sorry for the pun): http://homepage.mac.com/h.jasak/
I understand what you mean about slow download. If you send me your mailing address, I'll burn a CD and put it in the post.
Hrv
Hrvoje Jasak
Old   January 5, 2006, 14:29
Default I inserted an #undefine LIT
  #39
Assistant Moderator
Bernhard Gschaider
I inserted an
#undefine LITTLEENDIAN
as suggested by Mattijs and recompiled foamToVTK. Now paraview can read the binary files. So it definitly is an Endian-problem which has ended now (I don't know why the machine thought of itself as a little Indian in the first place).
I apologize for all the bad puns in this posting.
Old   January 5, 2006, 15:05
Default Hi Bernhard, can you find o
  #40
Mattijs Janssens
Hi Bernhard,
can you find out why LITTLENDIAN is defined and send fix to that logic in writeFuns.C?
OpenFOAM 15 icc build mschoenberg OpenFOAM Installation 4 October 2, 2008 01:09
How can I build OpenFOAM in cygwin joywe OpenFOAM Installation 10 September 12, 2008 10:39
OpenFOAM 14 Parallel build mplongjr OpenFOAM Installation 3 May 15, 2007 04:32
OpenFOAM build from source instructions tj22 OpenFOAM Installation 7 April 6, 2006 17:15
Build OpenFOAM on Tru64 francois OpenFOAM Installation 18 April 4, 2006 06:45
