July 23, 2008, 14:25 |
I have SUSE 11 installed. I h
Thomas Kosvic
Rep Power: 17 |
I have SUSE 11 installed. I have OpenFOAM 1.5 installed. All checks out well but paraFoam. After running tutorial case Cavity, I get the same message that others have pointed to, "reader cannot be found......".
SUSE comes with qt 4.4. OpenFOAM paraView needs qt 4.3. Where do I get a qt 4.3? Where do I install it? Can two qts exist on the same machine? The qt4.4 seems tied into much of SUSE and looks like it can't be deleted. Should I go back and install an earlier version of SUSE that utilized qt 4.3? Thanks for any help, Tom Kosvic |
July 23, 2008, 14:50 |
just comment line 94 in
Pierre-Olivier Dallaire
Rep Power: 17 |
just comment line 94 in Paraview3.3-cvs/CMakeLists.txt - should work. This way, you can compile Paraview with Qt4.4. Good luck PO |
July 23, 2008, 14:55 |
Hello Thomas,
if you succee
Alberto Passalacqua
Rep Power: 36 |
Hello Thomas,
if you succeed in compiling paraview with Qt 4.4, with a working reader on openSUSE 11.0, please could you just report that here? I'm still unable to get a working paraFoam, even if paraview works OK. Regards, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
July 23, 2008, 14:59 |
FYI, I reported this some time
Alberto Passalacqua
Rep Power: 36 |
July 23, 2008, 15:57 |
Alberto,
In the same thread
Alberto,
In the same thread you linked to, I reported a successful compilation of both Paraview and reader on openSUSE 11.0 with Qt 4.4: http://www.cfd-online.com/cgi-bin/OpenFOAM_Discus/show.cgi?tpc=126&post=24573#POST245 73 What is exactly your problem during the compilation of the reader? Regards, Jose Santos |
July 23, 2008, 15:58 |
Pierre-Olivier Dallaire,
Th
Thomas Kosvic
Rep Power: 17 |
Thanks for your response but it seems that just commenting out the test as you suggested for the qt version number is too simple a solution. Would not someone just change the test to include qt 4.4 in the version tests if paraView would work with qt4.4? I am reluctant to try this as I would probably overwrite the paraView that came with my installed openFOAM. |
July 23, 2008, 23:54 |
Hi Jose,
the problem I meet
Alberto Passalacqua
Rep Power: 36 |
Hi Jose,
the problem I meet is exactly what I reported there. If I recompile paraview and the reader with Qt 4.4, paraview works properly, but the reader passes to it a completely broken case (see the picture in the links to flickr). Regards, Alberto
Troubles with compiled version of paraviewparafoam | tgazz | OpenFOAM Bugs | 1 | April 17, 2008 10:42 |
[OpenFOAM] Exoprt eps from paraviewparaFoam | kyubi | ParaView | 5 | March 31, 2008 07:46 |
OpenFoam on Suse 101 | varun | OpenFOAM Installation | 0 | November 27, 2007 08:50 |
Fluent & Suse 9.1 | pp | FLUENT | 1 | December 4, 2004 20:05 |
SuSE 9.0 and CFX. | Carl | CFX | 0 | December 19, 2003 06:33 |
