Paraview33 build problem
Old   August 5, 2008, 10:33
Default Hello, I am trying to build
sds
Seth Schroeder
sds is on a distinguished road
I am trying to build Paraview3.3 on my RHEL 5.0 machine (Qt 4.3.1). The build script runs fine, but when I try to run paraview I get the error:
"paraview: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found ..."
I have tried adding the gcc libraries to my LD_LIBRARY_PATH, and have tried the solution suggested by Mattijs here: http://www.cfd-online.com/OpenFOAM_D...es/1/8399.html but have not had any luck yet.
Any help would be greatly appreciated. Thanks in advance.
Seth
sds is offline   Reply With Quote
Old   August 5, 2008, 15:06
Default This does sound exactly like t
Mattijs Janssens
mattijs is on a distinguished road
This does sound exactly like the problem I had: the vtk .so libraries point to /usr/lib64, not to my c++ compiler.
- what is your c++ compiler (which c++)
- Check for that VTK_USE_RPATH variable (see my previous post)
mattijs is offline   Reply With Quote
Old   August 5, 2008, 15:57
Default Hi Mattijs, Thanks for your
sds
Seth Schroeder
Hi Mattijs,
Thanks for your quick response.
It looks like your previously posted solution worked for me after all. I updated my Qt to 4.3.5 and it worked while using "VTK_USE_RPATH:BOOL=OFF". While I had Qt 4.3.1 installed I was given a 'Segmentation fault' after building with the option.
Thanks,
Seth
[OpenFOAM] Volume rendering in paraview33 aunola ParaView 0 October 4, 2008 16:35
[OpenFOAM] ParaView33 through VNC kar ParaView 4 April 13, 2008 10:53
Run-build problem hx CFX 0 January 28, 2004 23:59
Build problem Jeff CFX 0 July 31, 2003 14:21
Problem in using Build 4 kern CFX 0 May 30, 2001 07:49
