July 18, 2008, 00:40 |
Can you try the modified ParaV
#101 |
Takuya OSHIMA
Rep Power: 20 |
Can you try the modified ParaView 3.2.1 downloadable from http://oshima.eng.niigata-u.ac.jp/Op...iew/index.html ?
T |
July 18, 2008, 10:42 |
Thanks, Laurence.
After I c
#102 |
Paul Chang
Rep Power: 17 |
Thanks, Laurence.
After I created the softlink "ln -s flex flex++", the errors are significantly less. The installation, however, is still unsuccessful. The following is a copy of the error messages: make: *** [/home/paul/OpenFOAM/OpenFOAM-1.4/lib/cygwinGcc4DPOpt/libtriSurface.dll] Error 1 . . make: *** [/home/paul/OpenFOAM/OpenFOAM-1.4/lib/cygwinGcc4DPOpt/libcombustionThermophysica lModels.dll] Error 1 . . make[3]: *** [/home/paul/OpenFOAM/OpenFOAM-1.4/applications/bin/cygwinGcc4DPOpt/ansysToFoam] Error 1 make[3]: Leaving directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/conversion/ansysTo Foam' make[2]: *** [ansysToFoam] Error 2 make[2]: Leaving directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/conversion' make[1]: *** [conversion] Error 2 make[1]: Leaving directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh' make: *** [mesh] Error 2 + '[' 0 = 1 -a '' = doc ']' |
July 18, 2008, 11:36 |
Are you getting the error
u
#103 |
Laurence R. McGlashan
Rep Power: 23 |
undefined reference to yyFlexLexer::yywrap() associated with any of those error messages? If so, I think that particular problem has a workaround on these forums, albeit not a nice one.
Laurence R. McGlashan :: Website |
July 18, 2008, 11:57 |
Hello all,
Has anybody trie
#104 |
Yi Wang
Rep Power: 17 |
Hello all,
Has anybody tried the ParaView that Takuya posted with OpenFOAM 1.5 release? It seems they are not compatible. I got the following error message, when I start to load the data: ERROR: In \cygwin\home\kankyo\install\ParaView3\3.2\ParaView 3.2.1\VTK\IO\vtkOpenFOAMReader .cxx, line 3851 vtkOpenFOAMReader (05B2BC78): Numbers of faces in owner and neighbor don't match ERROR: In \cygwin\home\kankyo\install\ParaView3\3.2\ParaView 3.2.1\VTK\Filtering\vtkExecuti ve.cxx, line 757 vtkCompositeDataPipeline (05B45240): Algorithm vtkOpenFOAMReader(05B2BC78) returned failure for request: vtkInformation (05E2ED30) Debug: Off Modified Time: 88040 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA ALGORITHM_AFTER_FORWARD: 1 KEYS_TO_COPY: UPDATE_BLOCKS FROM_OUTPUT_PORT: 0 FORWARD_DIRECTION: 0 Is it easy to fix it? Thanks, Yi |
July 18, 2008, 12:29 |
Yi,
This is easy to fix. "N
#105 |
Mark Olesen
Rep Power: 40 |
Yi,
This is easy to fix. "Numbers of faces in owner and neighbor don't match" is an incorrect check. Since the boundary faces don't have neighbours, the list of neighbours will be shorter than the list of owners. In some OpenFOAM versions, these virtual neighbours were tagged with '-1' and both lists had the same length. A shorter neighbour list is fine though, so you can remove the check or use this: if(nNeigh > nFaces) { vtkErrorMacro(<<"More neighbours than faces"); return false; } |
July 18, 2008, 12:39 |
As Mark says it's expected. Th
#106 |
Takuya OSHIMA
Rep Power: 20 |
As Mark says it's expected. The reader is already working with 1.5 in my (and Mark's I hope) hands thanks to Mark's suggestions, but I still have to do several fine adjustments before release. Hopefully I can post a new version soon.
T |
July 18, 2008, 15:19 |
Laurence, thank you for the he
#107 |
Paul Chang
Rep Power: 17 |
Laurence, thank you for the help.
The error did relate to yyFlexLexer::yywrap(), and I modified those files mentioned in this post: http://www.cfd-online.com/cgi-bin/Op...2652#POST22652 One more compilation, however, just generated more errors. The following is part of those errors (please note: this time, the errors relate to more programs) Creating library file: /home/paul/OpenFOAM/OpenFOAM-1.4/lib/cygwinGcc4DPOpt/libcombustionThermophysical Models.achemkinReader.o:chemkinReader.C.rdata$_ZTVN4Foam13chemkinReaderE[vtable for Foam::chemkinReader]+0x48): undefined reference to `yyFlexLexer::yywrap()' chemkinLexer.o:chemkinLexer.C.rdata$_ZTV11yyFlexLexer[vtable for yyFlexLexer]+0x28): undefined reference to `yyFlexLexer::yywrap()' collect2: ld returned 1 exit status make: *** [/home/paul/OpenFOAM/OpenFOAM-1.4/lib/cygwinGcc4DPOpt/libcombustionThermophysica lModels.dll] Error 1 . . /home/paul/OpenFOAM/OpenFOAM-1.4/src/mico-2.3.12/platforms/cygwinGcc4DPOpt/inclu de/string.h:49: error: expected ';' before 'operator' . /home/paul/OpenFOAM/cygwin/gcc-4.1.2/bin/../lib/gcc/i686-pc-cygwin/4.1.2/include /c++/cstring:81: error: '::memmove' has not been declared . /home/paul/OpenFOAM/cygwin/gcc-4.1.2/bin/../lib/gcc/i686-pc-cygwin/4.1.2/include /c++/bits/char_traits.h:253: error: 'memcmp' was not declared in this scope . /home/paul/OpenFOAM/cygwin/gcc-4.1.2/bin/../lib/gcc/i686-pc-cygwin/4.1.2/include /c++/bits/locale_facets.h:1152: error: 'memcpy' was not declared in this scope. . /home/paul/OpenFOAM/OpenFOAM-1.4/src/mico-2.3.12/platforms/cygwinGcc4DPOpt/inclu de/mico/throw.h:111: error: 'strcmp' was not declared in this scope . PatchTool.C:883: warning: use of old-style cast . PatchTool.C:5694: error: 'strcmp' was not declared in this scope . . . |
July 18, 2008, 15:47 |
Thanks Mark and Takuya!
Do
#108 |
Yi Wang
Rep Power: 17 |
Does this mean I need to make the change you suggested in OpenFoam reader and recompile it with ParaView? If so, I will probably wait for Takuya's version. Yi |
July 18, 2008, 19:04 |
Hi Paul,
I can sympathise w
#109 |
Rep Power: 23 |
Hi Paul,
I can sympathise with you as it took me the best part of 2 days to get the Cygwin port running on both my laptop and my desktop. To be honest, if you really want to use OpenFOAM, run it on Linux, where the installation is generally rather trivial. I only use the Cygwin port to run the odd bits and bobs from home. I too still had some errors in the compilation but I only use the main solvers and libraries, which compiled fine. Have you tried running the solvers you are interested in? I just don't have the time to be rigorous about this unfortunately. The best I can do for you is to send you a document that I wrote whilst installing both Cygwin and OF. My e-mail is lrm29@cam.ac.uk_delete_this_bit if you're interested.
July 21, 2008, 14:13 |
Thanks, Laurence. I really app
#110 |
Paul Chang
Rep Power: 17 |
Thanks, Laurence. I really appreciate your kind offer. Could you send the document to paulchang6@yahoo.com?
July 28, 2008, 18:37 |
Hello all,
I've been trying t
#111 |
Pablo Grazziotin
Rep Power: 17 |
Hello all,
I've been trying to get OF to run on windows for quite a few days already. Thanks Laurence for the assistance through emails. I'm having a problem now with FoamX. I managed to get it to run, used for a bit, then closed it and could never get it to work again. This is the error im getting: $ FoamX Starting NameServer with inet:PEVPG1:1234 ... uncaught MICO exception: IDL:omg.org/CORBA/INITIALIZE:1.0 (0, not-completed) 3 [sig] nsd 1456 _cygtls::handle_exceptions: Error while dumping state (pr obably corrupted stack) /home/evxpg1/OpenFOAM/OpenFOAM-1.4/bin/runFoamXHB: line 149: 1456 Segmentation fault (core dumped) nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref < /d ev/null Any suggestions appreciated. Thanks, -Pablo |
July 31, 2008, 19:11 |
When try to compile the solver
#112 |
Sean Bian
Rep Power: 17 |
When try to compile the solver turbFoam i had the following error:
wmake /bin/sh: C:\cygwin\OpenFOAM\OpenFOAM-1.4\applications\wmake/bashScripts/addCompile: /bin/bash: bad interpreter: Permission denied Making dependency list for source file turbFoam.C make: *** [turbFoam.dep] Error 126 |
August 4, 2008, 17:51 |
What's your login shell? Could
#113 |
Ola Widlund
Rep Power: 17 |
What's your login shell? Could it be that it's not bash? Type "echo $SHELL", or check the last column of your user id:s line in /etc/passwd. It should read /bin/bash. I cannot reproduce your error, but I have a vague memory of something similar a year ago, on another PC, before I cleaned up the cygwin installation...
/Ola |
August 4, 2008, 18:40 |
Thanks for respond, now the er
#114 |
Sean Bian
Rep Power: 17 |
Thanks for respond, now the error is like:
wmake Dropping import dependency files /OpenFOAM/OpenFOAM-1.4/wmake/bashScripts /OpenFOAM/OpenFOAM-1.4/applications/bin/cygwinGcc4DPOpt/turbFoam make: execvp: /OpenFOAM/OpenFOAM-1.4/wmake/bashScripts/mkObjectDir: Permission denied make: *** [/OpenFOAM/OpenFOAM-1.4/applications/bin/cygwinGcc4DPOpt/turbFoam] Error 127 |
August 5, 2008, 09:14 |
Hi Sean,
The error message
#115 |
Ola Widlund
Rep Power: 17 |
Hi Sean,
The error message suggests that the script mkObjectDir does not have permission for whatever action it attempts. Either you're having problems with permissions (are you running under a uid other than the uid used for unpacking the OF tarballs?), or you're doing something strange... In what directory are you typing "wmake"? Why are you trying to recompile only turbFoam, inside the original OF tree? Have you already compiled the whole library yourself, without error, or are you using the precompiled binaries? I get the feeling you are doing something strange, possibly new to cygwin and/or linux. /Ola |
August 5, 2008, 12:20 |
Thanks Ola,
I am trying to co
#116 |
Sean Bian
Rep Power: 17 |
Thanks Ola,
I am trying to compile 1.4 but with too many errors so I test compiling turbFoam. eventually i hope to be able to run some custom make solvers/BCs.(my 1.3 binary installation is working) I run wmake in: C:\cygwin\OpenFOAM\OpenFOAM-1.4\applications\solvers\incompressible\turbFoam There are only a few lines in mkObjectDir: if [ $# = 1 ] then if [ ! -d ${1%/*} -a $1 != ${1%/*} ] then mkdir -p ${1%/*} fi fi I should be able to mkdir in c:\cygwin... Appreciate your advice |
August 7, 2008, 17:03 |
Laurence,
With more tries,
#117 |
Paul Chang
Rep Power: 17 |
Laurence,
With more tries, my installation is still not successful. I'll just use it in Linux. Anyway, thank you for the kind help. |
August 9, 2008, 07:54 |
Hi Sean,
Well, can _you_ mk
#118 |
Ola Widlund
Rep Power: 17 |
Hi Sean,
Well, can _you_ mkdir in c:\cygwin... ??? Try it by hand. You say you tried compiling the whole 1.4, but got too many errors. The errors do tell you something... Something is obviously not well. I would try to look at the first error and figure out what happens. Possibly you should re-unpack the whole tar pack and try from scratch... I followed the README of the cygwin pack to the last dot, and I had no problems. Maybe you shouldn't recompile everything? Just make a copy of turbFoam (myTurbFoam, for example), and see if it compiles? Bon courage, as the French say... /Ola |
OpenFoam vs CFX5 mass balance in OpenFoam | tangd | OpenFOAM Running, Solving & CFD | 33 | May 23, 2010 17:36 |
[Other] CAD and openFOAM | erik023 | OpenFOAM Meshing & Mesh Conversion | 2 | September 9, 2008 16:27 |
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 | martapajon | OpenFOAM Meshing & Mesh Conversion | 7 | January 21, 2008 13:52 |
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen | jaswi | OpenFOAM | 0 | August 3, 2007 14:11 |
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix | mbeaudoin | OpenFOAM Installation | 2 | April 28, 2006 09:54 |
