OpenFOAM 14 for WindowstmCygwin
Old   June 18, 2008, 11:42
Default Hello, I am having the same p
  #81
Kent Wardle
kwardle is on a distinguished road
I am having the same problem as Jason with flex. On compiling, I get an error that says
undefined reference to `yyFlexLexer ...
when it is compiling the ansystofoam mesh conversion utility. If it makes a difference, I don't anticipate needing this specific conversion tool, can I tell Allwmake to somehow skip this and compile everything else? Or is the flexlexer something I need? As it is, everything up to that point compiles fine but the make exits with "Error 2" after the undefined reference noted above. Any help?
I tried using the previous version of flex from cygwin (2.5.33-1) but get the same error.
Thanks,
Kent
kwardle is offline   Reply With Quote
Old   June 18, 2008, 17:39
Default hi, is there anyone that coul
  #82
Andrea Fuccio
iiiduncaniii is on a distinguished road
hi,
is there anyone that could help me with the installation of OF?
I have never used cygwin and i am having a problem following the instructions given in the cygwin.readme.
If anyone can help, i will appreciate it.
Thanks,
Andrea
PS Once version 1.5 comes out...will it work with cygwin?
iiiduncaniii is offline   Reply With Quote
Old   June 19, 2008, 16:40
Default It is amazing what you can lea
  #83
Kent Wardle
It is amazing what you can learn when you actually read the posts... I found my answer on another thread.
http://www.cfd-online.com/cgi-bin/Op...2652#POST22652
The switch suggested there seems to have done the trick with the undefined yyFlexLexer::yywrap() problem.
Old   July 3, 2008, 21:03
Default Hi Hans Linqvist,What error me
  #84
Takuya OSHIMA
7islands is on a distinguished road
Hi Hans Linqvist,
  • What error message did you get when you ran Allwmake? Can you post it?
  • Where is the exact installation directory of JDK?
Takuya
7islands is offline   Reply With Quote
Old   July 4, 2008, 03:38
Default Hi Takuya, the path to my jdk
  #85
Hans Linqvist
monroe is on a distinguished road
Hi Takuya, the path to my jdk is:
C:\Program\Java\jdk1.6.0_06
When executing Allmake the error message is:
$ bashrc
Monroe@oem-048e0ff0b68 ~/openfoam/OpenFOAM-1.4/.OpenFOAM-1.4
$ cd ..
$ Allwmake
+ cd wmake
+ ./makeWmake
Makefile:61: /rules//general: No such file or directory
Makefile:62: /rules: No such file or directory
make: *** No rule to make target `/rules'. Stop.
ln: creating symbolic link `Makefile': File exists
ln: creating symbolic link `MakefileFiles': File exists
+ cd src
+ ./Allwmake
+ cd /OpenFOAM
./Allwmake: line 4: cd: /OpenFOAM: No such file or directory
+ wmakeLnInclude .
./Allwmake: line 4: wmakeLnInclude: command not found
+ wmake libso zlib-1.2.1
./Allwmake: line 6: wmake: command not found
+ wmake libso foamUser
./Allwmake: line 7: wmake: command not found
+ '[' '' = cygwin ']'
+ '[' '' = OPENMPI ']'
+ '[' '' = LAM ']'
+ '[' '' = MPICH ']'
+ cd Pstream
+ ./Allwmake
+ wmake libso dummy
./Allwmake: line 4: wmake: command not found
+ '[' '' = LAM ']'
+ '[' '' = MPI ']'
+ '[' '' = MPICH-GM ']'
+ wmake libso OpenFOAM
./Allwmake: line 116: wmake: command not found
+ wmake libso lagrangian/basic
./Allwmake: line 119: wmake: command not found
+ wmake libso triSurface
./Allwmake: line 121: wmake: command not found
+ wmake libso edgeMesh
./Allwmake: line 122: wmake: command not found
+ wmake libso meshTools
./Allwmake: line 123: wmake: command not found
etc. etc.
Thanks
Hasse
monroe is offline   Reply With Quote
Old   July 4, 2008, 12:11
Default Hi Hasse, You most likely h
  #86
Takuya OSHIMA
Hi Hasse,
You most likely have to "source" the bashrc file into the current shell environment, instead of executing it directly.
source ~/openfoam/OpenFOAM-1.4/.OpenFOAM-1.4/bashrc
Takuya
Old   July 4, 2008, 12:47
Default Thanks Takuya, that did it, ha
  #87
Hans Linqvist
Thanks Takuya, that did it, had to sourced the allwmake to
Hasse
Old   July 8, 2008, 10:55
Default when run ~/openfoam/OpenFOAM-
  #88
eno
Sean Bian
eno is on a distinguished road
when run
I have the following errors:
line 56: [: too many arguments
line 262: [: too many arguments
What can be the problem?
eno is offline   Reply With Quote
Old   July 9, 2008, 20:51
Default Hi Sean Bian, Does your insta
  #89
Takuya OSHIMA
Hi Sean Bian,
Does your installation path contain a whitespace (e.g. C:\Documents and Settings\OpenFOAM)? If so could you try moving the path to the one without a whitespace.
Takuya
Old   July 11, 2008, 19:03
Default Takuya, Thanks. The files are
  #90
eno
Sean Bian
Takuya,
Thanks. The files are installed in C:\cygwin\OpenFOAM... but this problem is solved and i think the sources are successfully compiled now.
A new problem is when I type FoamX in cygwin terminal i have the error:
Can't find FoamX configuration directory at /cygerie/c /Documents and Settings/user/.OpenFOAM-1.4/apps/FoamX
Old   July 12, 2008, 21:25
Default Sean Bian, Just like the orig
  #91
Takuya OSHIMA
Sean Bian,
Just like the original Linux version, the Cygwin version by default assumes to be compiled and installed under $HOME/OpenFOAM and $HOME should not contain a whitespace.
Takuya
Old   July 14, 2008, 16:39
Default Hi All, I am trying to comp
  #92
Paul Chang
paulchang is on a distinguished road
Hi All,
I am trying to compile OpenFOAM-1.4.3 under cygwin. Everything looked normal until I got the following message after hours of compilation. Could any gurus give me any info what's wrong with my compilation? Many thanks!
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
make[2]: *** [/home/paul/OpenFOAM/OpenFOAM-1.4/applications/bin/cygwinGcc4DPOpt/laplacianFoam ] Error 1
make[2]: Leaving directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/solvers/basic/laplacianFoam'
make[1]: *** [laplacianFoam] Error 2
make[1]: Leaving directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/solvers/basic'
make: *** [basic] Error 2
+ cd utilities
+ wmake all
make[1]: Entering directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/utilities/errorEstimation'
make[2]: Entering directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/utilities/errorEstimation/estimat eScal
arError'
Making dependency list for source file estimateScalarError.C
Dropping import dependency files
make[2]: Leaving directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/utilities/errorEstimation/estimat eScala
rError'
arError'
SOURCE=estimateScalarError.C ; g++ -m32 -Dcygwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRe
pository -ftemplate-depth-30 -I/home/paul/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude -I/home/paul/OpenFOAM
/OpenFOAM-1.4/src/errorEstimation/lnInclude -I/home/paul/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -IlnInclude
-I. -c $SOURCE -o Make/cygwinGcc4DPOpt/estimateScalarError.o
/home/paul/OpenFOAM/OpenFOAM-1.4/wmake/bashScripts/mkObjectDir /home/paul/OpenFOAM/OpenFOAM-1.4/applications/bin
g++ -m32 -Dcygwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/
home/paul/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude -I/home/paul/OpenFOAM/OpenFOAM-1.4/src/errorEstimatio
n/lnInclude -I/home/paul/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -IlnInclude -I. Make/cygwinGcc4DPOpt/est
imateScalarError.o -L/home/paul/OpenFOAM/OpenFOAM-1.4/lib/cygwinGcc4DPOpt \
-lerrorEstimation -lfiniteVolume -lmeshTools -ldynamicMesh -lOpenFOAM -liberty -o /home/paul/OpenF
OAM/OpenFOAM-1.4/applications/bin/cygwinGcc4DPOpt/estimateScalarError
/usr/bin/ld: cannot find -lerrorEstimation
make[2]: *** [/home/paul/OpenFOAM/OpenFOAM-1.4/applications/bin/cygwinGcc4DPOpt/estimateScala rError] Error 1
rError'
make[1]: *** [estimateScalarError] Error 2
make[1]: Leaving directory `/home/paul/OpenFOAM/OpenFOAM-1.4/applications/utilities/errorEstimation'
make: *** [errorEstimation] Error 2
+ '[' 0 = 1 -a '' = doc ']'
Paul
paulchang is offline   Reply With Quote
Old   July 14, 2008, 18:24
Default Hi Paul! 1.4.3? As the patc
  #93
Assistant Moderator
Bernhard Gschaider
Hi Paul!
1.4.3? As the patches posted above are for previous versions it is not sure that they are correctly applied. Make sure that they are.
Please check whether this is the first error message you get during compilation (I doubt it)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 14, 2008, 22:15
Default Probably he meant the 1.4-3.cy
  #94
Takuya OSHIMA
Probably he meant the 1.4-3.cygwin version. My current guess is the available memory was not enough to link finiteVolume (see my post on June 14, 2007 above), but can't say for sure until I see the first error message.
T
Old   July 15, 2008, 13:12
Default Thanks, Bernhard and Takuya.
  #95
Paul Chang
Sorry for the confusion. Takuya is right, I meant 1.4-3.cygwin.
I guess it is not because of the memory, which is 3.2 GB in my computer.
Is the installation of "cygserver" mandatory? Since I don't have administrator privilege, I skipped the step of installing cygserver.
Old   July 15, 2008, 21:04
Default Hi Paul, You don't need cygse
  #96
Takuya OSHIMA
Hi Paul,
You don't need cygserver unless you do parallel runs. As Bernhard said posting the first error message may be helpful.
Takuya
Old   July 16, 2008, 17:10
Default Thanks, Takuya After carefu
  #97
Paul Chang
Thanks, Takuya
After carefully checked the compiling output info and did more internet search, I modified line 286 of the file "os-misc.h" from extern "C" int gettimeofday (struct timeval *, struct timezone *) to extern "C" int gettimeofday (struct timeval *, void*), and the errors are less than before, but the compilation is still not successful.
I also noticed that almost all the errors are related to "cygwinGcc4DPOpt", which I didn't download (Is this file needed? Where can I download this package?)
BTW, how can attached a text file to my message?
Old   July 17, 2008, 03:44
Default cygwinGcc4DPOpt is just a targ
  #98
Takuya OSHIMA
cygwinGcc4DPOpt is just a target name so there's no such distribution to download.
If you could precisely track down the occurrence of the first error, just copy-and-pasting several ten lines of the log around there should be enough. But if you think it is insufficient and would like to post the whole log, see the Formatting section of the forum documentation at the pane left of this forum screen. Note the size of the attachment is still limited to 50 KBytes (IIRC).
T
Old   July 17, 2008, 17:56
Default Try creating a softlink: ln -
  #99
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
ln -s flex flex++
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 17, 2008, 19:55
Default I gave up compiling ver1.4 and
  #100
eno
Sean Bian
I gave up compiling ver1.4 and installed 1.3 binary with a nonworking FoamX. When i try to use paraFoam to view the cavity sample i just run, I can not open the controlDict.foam in the GUI. It keeps asking:
a reader for "...controlDict.foam" could not be found, please choose one...
Which one should I choose?
The 0 0.1 0.2 ...0.5 folds are in .../cavity
and controlDict.foam is in .../system
I have paraview3.2.1 installed in c:/program files/paraview3.2.1
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 17:36
[Other] CAD and openFOAM erik023 OpenFOAM Meshing & Mesh Conversion 2 September 9, 2008 16:27
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 13:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 14:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 09:54
