Compiling MRFSimple foam error
Old   September 15, 2008, 16:09
Default Hi all, I'm trying to compi
Michael Rangitsch
mrangitschdowcom is on a distinguished road
Hi all,
I'm trying to compile the MRFSimpleFoam application with wmake and run into an error during the load:
SOURCE=MRFSimpleFoam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/transportModels -IlnInclude -I. -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MRFSimpleFoam.o
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/transportModels -IlnInclude -I. -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/MRFSimpleFoam.o -L/home/u091108/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt \
-lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/u091108/OpenFOAM/u091108-1.5/applications/bin/linux64GccDPOpt/MRFSimpleFoa m
/home/u091108/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86 _64-unknown-linux-gnu/4.3.1/../../../../lib64/libstdc++.so: file not recognized: File format not recognized
collect2: ld returned 1 exit status
make: *** [/home/u091108/OpenFOAM/u091108-1.5/applications/bin/linux64GccDPOpt/MRFSimpleFo am] Error 1
This is on a Suse 10.1 system. Any ideas why it wouldn't like libstdc++.so ?
Thanks!
Mike Rangitsch
mrangitschdowcom is offline   Reply With Quote
Error while compiling icoLagrangian Foam sara OpenFOAM Running, Solving & CFD 32 February 6, 2013 09:45
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 01:23
FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 4 July 30, 2008 11:06
FOAM installation error gcc amp g hanks OpenFOAM Installation 9 January 26, 2006 15:14
FOAM FATAL IO ERROR sita OpenFOAM Running, Solving & CFD 2 August 23, 2005 05:37
