ParaFoam on Ubuntu 804
Old   September 22, 2008, 05:28
Default I'm installed open foam on Ubu
Francesco Tonolli
francy is on a distinguished road
I'm installed open foam on Ubuntu 8.04, but when i try to star parafoam, I obtain this message of error:
paraview: error while loading shared libraries: libQtAssistantClient.so.4: cannot open shared object file: No such file or directory
thanks for all yours aid.
Francesco
francy is offline   Reply With Quote
Old   September 22, 2008, 06:18
Default Hi You need to install qt4.
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
You need to install qt4.3.5, which you can get by searching in Synaptic Package Manager.
When it is install please follow the README to compile Parafoam
/Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 22, 2008, 06:55
Default Thanks Niel, but i'm not an a
Francesco Tonolli
Thanks Niel,
but i'm not an abitual user in Linux, can you tell me where and what exactly i must download (the file name)
Thanks again
Francesco
Old   September 22, 2008, 08:08
Default libqt4-dev
ngj
libqt4-dev
Old   September 23, 2008, 11:38
Default I've installed libqt4-dev 4.3.
Francesco Tonolli
I've installed libqt4-dev 4.3.4, the only avaible for ubuntu 8.04
When I try to compile paraview obtain:
francy@francy-desktop:~/OpenFOAM$ cd ThirdParty/
francy@francy-desktop:~/OpenFOAM/ThirdParty$ rm -rf ParaView3.3-cvs/platforms/
francy@francy-desktop:~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs
Building ParaView3.3-cvs
MPI support : OFF
Python support : OFF
MESA support : OFF
Source : /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc
-- Check for working C compiler: /home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
-- Check for working C compiler: /home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- broken
CMake Error: The C compiler "/home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc" is not able to compile a simple test program.
It fails with the following output:
/usr/bin/make -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build
make[1]: Entering directory `/home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp'
/home/francy/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o
/home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/testCCompiler.c
/home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i6 86-pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
make[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1
make[1]: Leaving directory `/home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp'
make: *** [cmTryCompileExec/fast] Error 2
CMake will not be able to correctly generate this project.
-- Configuring done
make: *** No targets specified and no makefile found. Stop.
done
What i've to do??
Thanks at all
Francesco
Old   September 23, 2008, 14:25
Default Do the same, as with qt. Go to
ngj
Do the same, as with qt. Go to Synaptic Package Manager and search for mpfr.
Get libmpfr-dev and the manager will suggest the additional needed packages.
From there on, you should be set to go.
/ Niels
Old   May 8, 2009, 07:57
Julian Krick
Julian K. is on a distinguished road
Thanks ngi,
I had the same problem as francy, followed your instructions and the compiling of paraview3.3 works.
It's still running, so I do not know if the compiling of PV3FoamReader will work...
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
Instalation on ubuntu 710 basilwatson OpenFOAM Installation 17 March 16, 2012 21:16
Ubuntu Vs Fedora Vinayender Main CFD Forum 1 August 11, 2008 13:55
Fluent & Ubuntu 7.1 Charles FLUENT 6 April 1, 2008 01:13
Ubuntu 7.10 and Fluent Gibbon FLUENT 1 November 13, 2007 03:08
Fluent 6.3 on Ubuntu 7.04 adas FLUENT 1 March 20, 2007 20:31
