Problem of paraFoam in OF15
Old   September 29, 2008, 13:03
Default Hi all, I installed OF1
kai
Kai Liu
kai is on a distinguished road
Hi all,
I installed OF1.5 on my Fedora 9 system simply by extractiong all the binary packages as described in README. When I tested it with icoFoam's cavity case, the blockMesh and the solver icoFoam worked well, but the paraFoam programme told me it could not find a reader of the case. Now I can only use foamToVTK to see the result. So what is the problem and how to solve it?
Regards,
Kai
kai is offline   Reply With Quote
Old   September 29, 2008, 14:41
Default Hi You need QT4.3.x and yo
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
You need QT4.3.x and you need to compile paraFoam from scratch. Look in the README file for further informations.
It should be noted that on Fedora 9, QT4.4.x is the default, thus you need to download the source for QT4.3.x and compile that be yourself as well.
Further you will probably be needing libmpfr<something> for the gcc-compiler to be working.
Good luck,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   October 1, 2008, 03:50
Default Hi Niels, Thanks you for yo
kai
Kai Liu
Hi Niels,
Thanks you for your advice.
Yes, I tried the buildParaView3.3-cvs method mentioned in README and failed. The reason may be QT version incompliant as you said. Now, should I delete the qt-4.4.1 on my system before installing qt4.3, or just simply compile qt4.3 in the case of qt4.4.1 existing ?
Regards,
Kai
Old   October 1, 2008, 04:14
Default You don't need to install qt4.
Matthias Kern
make is on a distinguished road
You don't need to install qt4.3!
I just compiled paraview using qt4.4.2.
Simply uncomment the qt check in the CMakeLists.txt.
There is a line starting with MESSAGE(SEND_ERROR "QT ${QTVERSION }.... Add a # in front.
It compiled without error and runs perfectly. Didn't even crach once since a use it.
regards,
Matthias
make is offline   Reply With Quote
Old   October 1, 2008, 04:31
Default Note that even a slight mis-ma
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Note that even a slight mis-match in qt versions can cause problems. I had paraview and the OpenFOAM reader module compiled with qt 4.3.3.
One of the machines had qt 4.3.1 installed, which meant that paraview started okay, but the reader module didn't load. Updating all the workstations to the same qt4.3.3 version eliminated the problem.
olesen is offline   Reply With Quote
Old   October 1, 2008, 13:36
Default Hi Matthias, Thanks a lot
kai
Kai Liu
Hi Matthias,
Thanks a lot! I just followed your advice and successfully recompiled the paraFoam with qt-4.4.1. It runs well now. I cannot understand why the install guide says that versions older or newer than qt-4.3.x are not allowed.
Best regards,
Kai
Old   October 2, 2008, 03:31
Default Hi Kai, If you scan the par
Mark Olesen
Hi Kai,
If you scan the paraview mailing lists, you'll see that building with various qt versions, or even debug vs. release, is a constantly recurring topic. The qt API might change a little between versions, the cmake files might be too stringent in allowing/disallowing particular qt versions, there may be qt bugs that paraview triggers in particular qt versions, or simply that the paraview developers have compiled with a particular version and don't know if it works well with a newer/older version.
I hope this explains why the install guide really isn't misleading. What if the install guide stated "you should use qt-4.3.x, unless you change the CMakeLists.txt, clean out all the old build remnants (and cmake cache files, and it might be necessary to remove the entire paraview directory and do a fresh cvs checkout too) and pray that all goes well when you compile against a different qt version"?
Scan the paraview mailing lists and you'll see what I mean. I am personally grateful for the buildParaview script provided with OpenFOAM - it has greatly improved my success rate with building paraview!
[OpenFOAM] Problem with paraFoam wandeklein ParaView 1 October 9, 2008 17:12
[OpenFOAM] Parafoam problem mochzeen ParaView 12 September 22, 2008 18:46
OF15 paraFoam Update GUI not functional aunola OpenFOAM Installation 1 July 28, 2008 01:32
ParaFOam problem luca OpenFOAM Running, Solving & CFD 1 May 3, 2006 13:06
[OpenFOAM] Could anybody help me about the paraFoam problem liugx212 ParaView 1 February 3, 2006 12:06
