Cygwin install Missing icoFoam
Old   October 31, 2008, 19:34
Default Hi, I am trying to install
Chris D
turbome is on a distinguished road
I am trying to install Openfoam 1.4 for cygwin . I have followed the readme instructions up to the point before compile and am getting a critical error saying icofoam not installed. Can I proceed with the compile or do I need to fix this and if so how?
Here is the installtion test report:
Checking basic setup...
Shell: bash
Host: Engineering
OS: CYGWIN_NT-5.1 version 1.5.25(0.156/4/2)
User: cd
User_config: /cygdrive/h/.bashrc
Foam_config: /cygdrive/h/.OpenFOAM-1.4/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /cygdrive/h/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /cygdrive/h/OpenFOAM/cd-1.4 yes no
$FOAM_JOB_DIR /cygdrive/h/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /cygdrive/h/OpenFOAM/OpenFOAM-1.4 yes yes yes
$FOAM_USER_APPBIN ...1.4/applications/bin/cygwinGcc4DPOpt yes yes no
$FOAM_APPBIN ...1.4/applications/bin/cygwinGcc4DPOpt yes yes yes
$WM_DIR /cygdrive/h/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /cygdrive/c/Program Files/Java/jdk1.6.0 yes yes no
$MICO_ARCH_PATH ...ico-2.3.12/platforms/cygwinGcc4DPOpt no yes
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.4/lib/cygwinGcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/cdollery-1.4/lib/cygwinGcc4DPOpt yes yes no
Software versions
Software Version Location
gcc 4.1.2 /cygdrive/h/OpenFOAM/cygwin/gcc-4.1.2/bin/gcc
/cygdrive/c/Program Files/Java/jdk1.6.0/bin/java
gzip 1.3.12 /usr/bin/gzip
tar 1.3.12 /usr/bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_Engineering Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Unsuccessful_connection_refused* yes
FATAL ERROR: No remote shell available.
Foam1.4 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 1 fatal error(s).
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
turbome is offline   Reply With Quote
Old   November 1, 2008, 08:52
Default Hi Chris, Yes you can proce
Takuya OSHIMA
7islands is on a distinguished road
Hi Chris,
Yes you can proceed, since icoFoam is a product of the compile. However you'll have to meet some difficulties as the Cygwin port is becoming a bit outdated. Hope you can get it to work with the help of another thread.
Takuya
7islands is offline   Reply With Quote
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 05:10
gambit and cygwin Elyyan FLUENT 0 November 27, 2007 12:39
OpenFoam under Cygwin NeaZen Main CFD Forum 3 January 21, 2007 13:32
cygwin Adam M FLUENT 1 July 16, 2006 12:54
Cygwin B20 /tmp sean CFX 0 October 22, 2000 01:22
