Installation of OpenFOAM15 on the SGI Altix 4700 LinuxIA64I64DP0pt |
November 20, 2008, 17:10 |
Has anyone successfully compil
bong rhee
Has anyone successfully compiled OpenFOAM-1.5 on the SGI Altix Itanium 64 machine? Or Has anyone have a piece of advice as to crack at my installation problems I have encountered?
I am struggling to compile OpenFOAM-1.5 on the SGI Altix 4700 Itanium 64 machine (linuxIA64I64). When I run build script './Allwmake' at the top-level source dir, I get an error message saying "no such file or directory" found in linuxIA64I64 dir. For some reason the build script did not create that dir under rules dir. IOW there is no rule for wmake. Question 1: How come the build script did not create a rule for wmake? Is this something to do with a relativ new platform? Makefile:61: /hafs5/rhee/OpenFOAM/OpenFOAM-1.5/wmake/rules/linuxIA64I64/general: No such file or directory For the sake of my curiosity, I did a little experiment with wmake by blindly copying LinuxIA64I64 dir from OpenFOAM-1.4.1 onto OpenFOAM-1.5. I know this may not work because of compatibility issue. This time I get the following error messages including ones related to MPI library. I am aware that in order to properly compile MPI programs on the SGI Altix, I need to specify MPI option different from the one found in OpenFOAM. hawk-0:/hafs5/rhee/OpenFOAM/OpenFOAM-1.5/ ./Allwmake + cd . + cd wmake/src + make make: Nothing to be done for `all'. + cd /hafs5/rhee/OpenFOAM/ThirdParty + ./Allwmake + '[' -n '' ']' + '[' -n '' ']' + '[' -n '' ']' + '[' -n '' ']' + '[' -n '' ']' + wmake libso zlib-1.2.3 icpc: Command line error: no files specified; for help type "icpc -help" make: *** [libNULL.so] Error 1 + cd malloc + ./Allwmake + wmake libso hoard icpc: Command line error: no files specified; for help type "icpc -help" make: *** [libNULL.so] Error 1 + wmake libo fbsdmalloc ld -r -o libNULL.o ld: no input files make: *** [libNULL.o] Error 1 + case "$WM_MPLIB" in + '[' -r /hafs5/rhee/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxIA64I64DPOpt/lib/li bmpi.so ']' + echo 'have OPENMPI shared library' have OPENMPI shared library + cd metis-5.0pre2 + wmake libso GKlib '/hafs5/rhee/OpenFOAM/OpenFOAM-1.5/lib/linuxIA64I64DPOpt/libGKlib.so' is up to date. + wmake libs+ wmake libso dummy SOURCE=Pstream.C ; icpc -DlinuxIA64 -DDP -wd654,819,1125,1476,1505,1572 -DICC_IA64_PREFETCH -ansi-alias -O3 -ftz -mP3OPT_ecg_swp_control=0x400000 -fno-alias -mtune=itanium2 -fargument-noalias-global -unroll0 -DNoRepository -IlnInclude -I. -I/hafs5/rhee/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/hafs5/rhee/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -KPIC -c $SOURCE -o Make/linuxIA64I64DPOpt/Pstream.o /hafs5/rhee/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Pstream.H(45): catastrophic error: could not open source file "labelList.H" #include "labelList.H" ^ compilation aborted for Pstream.C (code 4) make: *** [Make/linuxIA64I64DPOpt/Pstream.o] Error 4 + case "$WM_MPLIB" in + export WM_OPTIONS=linuxIA64I64DPOptOPENMPI + WM_OPTIONS=linuxIA64I64DPOptOPENMPI + set +x Note: ignore spurious warnings about missing mpicxx.h headers + wmake libso mpi SOURCE=OPwrite.C ; icpc -DlinuxIA64 -DDP -wd654,819,1125,1476,1505,1572 -DICC_IA64_PREFETCH -ansi-alias -O3 -ftz -mP3OPT_ecg_swp_control=0x400000 -fno-alias -mtune=itanium2 -fargument-noalias-global -unroll0 -DNoRepository -DOMPI_SKIP_MPICXX -I/include -IlnInclude -I. -I/hafs5/rhee/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/hafs5/rhee/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -KPIC -c $SOURCE -o Make/linuxIA64I64DPOptOPENMPI/OPwrite.o /default/rhee/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linuxIA64I64/bin/../includ e/c++/4.3.1/ia64-unknown-linux-gnu/bits/c++config.h(233): error: expected a "{" _GLIBCXX_BEGIN_NAMESPACE(std) ^ /default/rhee/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linuxIA64I64/bin/../includ e/c++/4.3.1/bits/stringfwd.h(46): error: expected a "{" _GLIBCXX_BEGIN_NAMESPACE(std) ^ |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 11:54 |
Running Fluent on an SGI Altix machine | Jonathan Vogt | FLUENT | 1 | March 19, 2008 02:35 |
OF on Altix Itanium2 machine | skabilan | OpenFOAM Installation | 0 | December 14, 2007 05:04 |
Installation on an SGI Altix | eviled | OpenFOAM Installation | 0 | March 31, 2007 05:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 10:27 |
