Which Linux
Old   November 11, 2008, 10:22
Default Hi, I have first to install
hsj
Hervé Socquet-Juglard
hsj is on a distinguished road
I have first to install Linux on my machine before thinking about OpenFoam.
Which Linux distribution do you think I should install ?
When installing a Linux distribution, is it then easy to install OpenFoam ? Will I need to install extra packages to run OpenFoam ?
Regards,
Hervé
hsj is offline   Reply With Quote
Old   November 11, 2008, 10:47
Default Hi, I would suggest you to
Suresh kumar Kannan
kumar is on a distinguished road
I would suggest you to go for UBUNTU 8.... just the latest version. As I had installed Openfoam just a few days back on my machine. The reason why i say that is you can download a script from the OpenFOAM forum which you can just run to install OpenFOAM and I did the same .
It is working fine for me.
Other good thing about UBUNTU is the synaptics package manager which is quiet handy to install required packages when you want. If you cannot find the script on the forum just let me know, I will send it to you.
Regards
K.Suresh kumar
kumar is offline   Reply With Quote
Old   November 11, 2008, 11:28
Default I recommend openSUSE for the e
Alberto Passalacqua
I recommend openSUSE for the ease of use, the very powerful configuration tools (YaST), and the good hardware and community support: www.opensuse.org
Installing openFOAM on it means just downloading the packages from openCFD and follow their instructions. You won't need any additional package to use openFOAM on it.
With kind regards,
Alberto
Alberto Passalacqua
Old   November 12, 2008, 20:51
Default Dear K.Suresh kumar, I now
Su Xiaohui
sxhdhi is on a distinguished road
Send a message via Skype™ to sxhdhi
I now follow your idea to install UBUNTU8.10. I still could not fix paraFoam problem. Could you please let me know which version of Qt you installed and how to install it and make it work? Thanks in Advance.
Regards
Su Xiaohui
sxhdhi is offline   Reply With Quote
Old   November 12, 2008, 21:49
Default Please post the error message
Bao, Kai
paean is on a distinguished road
Please post the error message and tell us the Qt version u used.
Regards,
Bao Kai
paean is offline   Reply With Quote
Old   November 13, 2008, 05:12
Default Hello Su Xiaohui,
Suresh kumar Kannan
Hello Su Xiaohui,
I use Qt4 and I have no problem in opening ParaFoam or doing postprocessing.
I suggest you to go to the Synaptics package manager from the systems menu of UBUNTU and then try to search for qt4 and then install the qt4 config... files. I hope this helps you to install qt.
But i think if you had run the script correctly without any error, you shouldnt have any problem in using ParaFoam as it takes care of the qt installation and other libraries required for Qt installation.
bye
Regards
K.Suresh kumar
Old   November 28, 2008, 07:54
Default Hello, The issue of a "good
Rishi .
hellorishi is on a distinguished road
The issue of a "good" Linux system has been asked often and I have tried installing OpenFOAM atleast 11 times (on a 32bit machine). So based on my experience, I would recommend the following in brief (detailed instruction/messages in another post on the forum):
SHORT VERSION:
1. Install OpenSuSE 10.3
DVD version comes loaded with most of the required development packages,libraries, etc. Click everything during installation (maybe except GAMES).
Only 2 packages are missing.
2. Install following packages from the DVD using YaST:
mpfr-2.2.1-45.i586.rpm
mpfr-devel-2.2.1-45.i586.rpm
3. Clean the Paraview platforms and recompile as mentioned in README.
~/OpenFOAM/ThirdParty> rm -rf ParaView3.3-cvs/platforms
~/OpenFOAM/ThirdParty> buildParaView3.3-cvs
~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamRe ader> ./Allwclean
~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamRe ader>./Allwmake
4. Ready to run first example as mentioned in Section 6(Getting Started) !
ciao
hellorishi is offline   Reply With Quote
Old   November 28, 2008, 12:56
Default Hello, if you use openSUSE
Alberto Passalacqua
if you use openSUSE 10.3, you don't need to install "everything except games" (that's huge! :-)), especially if you use what provided by third party packages you can download from OpenCFD website.
I would say you need to install the default proposal + the "C/C++ development" and "Qt development" patterns.
Regards,
A.
Alberto Passalacqua
Old   December 5, 2008, 11:45
Default I have Fedora 9 and I am havin
James E Boone
jeboone is on a distinguished road
I have Fedora 9 and I am having trouble installing OpenFOAM - It looks like Fedora has QT3.3 - Has anyone installed OpenFOAM on Fedora
jeboone is offline   Reply With Quote
Old   December 5, 2008, 14:11
Default Hi James, In Fedora you nee
Gijsbert Wierink
gwierink is on a distinguished road
Hi James,
In Fedora you need to install Qt-4.3.5 (at least that worked for me) and rebuild ParaView. You can download the package qt-all-opensource-src-4.3.5.tar.gz from ftp://ftp.trolltech.com/qt/source. Put it in a temporary directory and unpack it by "tar xzf qt-all-opensource-src-4.3.5.tar.gz".
Then, go to the place it unpacked and configure for installation by "./configure". After that it will tell you that you can make Qt by typing "gmake" and after that "gmake install" (this may be "cmake" or just "make" for you).
Then, add this to your .profile file:
PATH=/usr/local/Trolltech/Qt-4.3.5/bin:$PATH
export PATH
In my case I also had to make a directory called "bin" in my home directory and copy the qmake executable there. After you have unpacked the OpenFOAM packages follow the recipe to rebuild ParaView from section 7 of the README:
A version of Qt 4.3.x must be installed to compile ParaView. The compilation is a fairly simple process using the supplied buildParaView3.3-cvs script that has worked is our tests with other packages supplied in the ThirdParty directory, namely cmake-2.4.6 and gcc-4.3.1. Execute the following:
* cd $FOAM_INST_DIR/ThirdParty
* rm -rf ParaView3.3-cvs/platforms
* buildParaView3.3-cvs
The PV3FoamReader module is an OpenFOAM utility that can be compiled in the usual manner as follows:
* cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
* ./Allwclean
* ./Allwmake
Hope this helps, cheers, Gijs
Regards, Gijs
gwierink is offline   Reply With Quote
Old   December 5, 2008, 18:25
Default It worked great - very good ex
  #11
James E Boone
It worked great - very good explanation of what I needed. I had searched the trolltech site for a Qt4.3 version but all the search turn up was Qt4.4 which the OpenFOAM instruction said was not compatible. I didn't need to create the bin directory and put the qmake file in it. I added PATH=$PATH:/usr/local/Trolltech/Qt-4.3.5/bin to my .bashrc file. After refreshing the path I checked
which qmake
and it was in my path so I went on with the instructions. It all is working now.
Thanks and Have a great weekend
Jim
Old   December 6, 2008, 05:22
Default Hi Jim, You're very welcome
  #12
Gijsbert Wierink
Hi Jim,
You're very welcome. I am happy you got it working. The right Qt package is not so easy to find, some digging is needed .
Great weekend for you too!
Cheers, Gijs
Regards, Gijs
Which Linux for es-ice? Nari Siemens 1 September 9, 2007 11:40
CFX on Linux Ioakimidis Konstantinos CFX 7 August 3, 2007 13:05
Can Starcd for linux run in Linux Debian? help deisler Siemens 1 February 28, 2007 05:27
CFX 5.5.1 on Linux Armin CFX 2 July 24, 2002 06:00
NT to Linux Joel Phoenics 3 May 1, 2002 13:37
