October 2, 2008, 09:03 |
I'm new to this commu
Benjamin Berger
Rep Power: 17 |
I'm new to this community and I'm a new OpenSuse user. I tried to install OpenFOAM on OpenSuse 11 and it just worked. The foamInstallationTest returned me 0 error. But, when I'm trying to build paraview, I got this message: "-- Application: default ParaView Client enabled Qt ASSISTANT library not found. Qt GUI library not found. CMake Error: Error in cmake code at /home/Gizmo/OpenFOAM/ThirdParty/ParaView3.3-cvs/Applications/Client/CMakeLists.t xt:533: FILE GLOB requires a glob expression after the directory Current CMake stack: /home/Gizmo/OpenFOAM/ThirdParty/ParaView3.3-cvs/Applications/Client/CMakeLists.t xt CMake Error: Error in cmake code at /home/Gizmo/OpenFOAM/ThirdParty/ParaView3.3-cvs/Applications/Client/CMakeLists.t xt:533: FILE GLOB requires a glob expression after the directory Current CMake stack: /home/Gizmo/OpenFOAM/ThirdParty/ParaView3.3-cvs/Applications/Client/CMakeLists.t xt -- Application: Custom Server enabled -- Application: DobranoViz enabled -- Plugin: Prism enabled -- Found Qt-Version 4.4.0 Qt GUI library not found. -- Configuring done make: *** Pas de cibles spécifiées et aucun makefile n'a été trouvé. Arrêt. done" I don't really understand what the problem is so it would be really great if someone could help me! ;-) I had the same kind problem with Ubuntu Hardly Heron... Thank you for your help. |
October 2, 2008, 09:46 |
Check that you have the qt dev
Mark Olesen
Rep Power: 40 |
Check that you have the qt devel packages installed. I have the following rpms installed:
libqt4-devel-doc libqt4-x11 libqt4-sql libqt4-devel libqt4-devel-doc-data libqt4 libqt4-qt3support libqt4-dbus |
October 2, 2008, 17:54 |
I checked then I typed the com
Benjamin Berger
Rep Power: 17 |
I checked then I typed the command: rpm -qa libqt* in the terminal to be sure that I have the good ones (I found this command in another subject in this forum) and I still have exactly the same message :-(
Thank you for your help ;-) Any other suggestion? |
October 5, 2008, 00:19 |
I have the same problem http:/
Danielle PRL
Rep Power: 17 |
what is the solution ????? thanks for help |
October 5, 2008, 05:18 |
I solved the problem by downlo
Benjamin Berger
Rep Power: 17 |
I solved the problem by downloading and re-installing libqt4 packages with yast and it worked!
Tell me if your problem is solved ;-) |
October 5, 2008, 23:53 |
Thanks Benjamin,
The problem
Danielle PRL
Rep Power: 17 |
Thanks Benjamin,
The problem still the same :-( and I need see my results. |
October 6, 2008, 06:42 |
I have the following packages
Benjamin Berger
Rep Power: 17 |
I have the following packages installed on my OpenSuse (maybe there are not all needed but this can help you):
gcc gcc-4.2 gcc-4.2-base libqt-4-core libqt-4-debug libqt-4-dev libqt-4-gui libqt-4-qt3support libqt-4-sql libqthreads-12 libmpfr-dev If Yast suggests you other packages while installing these, accept them. Good luck ;-) |
November 30, 2008, 22:19 |
Did you installed the cmake pa
Lee
Did you installed the cmake package?
December 8, 2008, 11:32 |
I've installed gcc-4.3.1 in ad
#9 |
Rishi .
Rep Power: 17 |
I've installed gcc-4.3.1 in addition to the gcc on my current system (avoid conflicts).
Now I am trying to build ParaView as mentioned in guide, however I am stuck at this issue and have no clue... please help. *********************************************** >buildParaView3.3-cvs *********************************************** Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -- Check for working C compiler: /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- Check for working C compiler: /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- works -- Check size of void* -- Check size of void* - done -- Check for working CXX compiler: /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++ -- Check for working CXX compiler: /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++ -- works -- Looking for Q_WS_X11 -- Looking for Q_WS_X11 - found ... ... ... Found Qt-Version 4.3.2 CMake Error: This project requires some variables to be set, and cmake can not find them. Please set the following variables: QT_X11_/home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/Appli cations/CMakeFiles/CMakeTmpQmake/tmp.pro _LIBRARY QT_X11_/home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/Qt/CM akeFiles/CMakeTmpQmake/tmp.pro _LIBRARY QT_X11_/home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/VTK/G UISupport/Qt/CMakeFiles/CMakeTmpQmake/tmp.pro _LIBRARY QT_X11_/usr/local/Trolltech/Qt-4.3.2/mkspecs/default/qmake.conf. Error_LIBRARY QT_X11_Failure_LIBRARY QT_X11_QMAKESPEC_LIBRARY QT_X11_conf_LIBRARY QT_X11_file:_LIBRARY QT_X11_file_LIBRARY QT_X11_processing_LIBRARY QT_X11_project_LIBRARY QT_X11_read_LIBRARY QT_X11_to_LIBRARY -- Configuring done make: *** No targets specified and no makefile found. Stop. done |
December 9, 2008, 09:51 |
Hi Rishi!
Have a look at Ma
#10 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Rishi!
Have a look at Mark's post above. Fastest way to check whether you have the packages described there would be rpm -qa | grep qt4 My guess would be that the qt4-x11-packages are not installed on your machine. Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
December 9, 2008, 18:01 |
HI Bernhard,
Well my situa
#11 |
Rishi .
Rep Power: 17 |
HI Bernhard,
Well my situation is pretty strange. I dont have direct internet access on this OF machine, so I cant install using rpm/YaST. To add to that, I cant generally install using rpm, since it tends to disturb settings/dependencies for other installed programs. Hence I can only install the autoconf way: ./configure make su make install I have already installed qt4.3.2-x11 packages. I have a different error message today, after playing around with qt-x11. > buildParaView3.3-cvs ************************************************** ******* .... .... -- Found Qt-Version 4.3.2 CMake Error: This project requires some variables to be set, and cmake can not find them. Please set the following variables: QT_X11_Feature_LIBRARY QT_X11_LOAD():_LIBRARY QT_X11_Project_LIBRARY QT_X11_be_LIBRARY QT_X11_cannot_LIBRARY QT_X11_found. _LIBRARY QT_X11_qt_config_LIBRARY -- Configuring done make: *** No targets specified and no makefile found. Stop. done ************************************************** ******* possible problem: /home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/Applications/CMakeCache.txt ************************************************** ******* ..... ..... //The location of the Qt mkspecs QT_MKSPECS_DIR:PATH=/usr/local/Trolltech/Qt-4.3.2/mkspecs //The moc executable QT_MOC_EXECUTABLE:FILEPATH=Project LOAD(); Feature qt_config cannot be found. ..... ..... ************************************************** ******* any further hints will be appreciated. Thanks |
December 10, 2008, 15:11 |
Hi Rishi,
Did you have a lo
#12 |
Gijsbert Wierink
Rep Power: 18 |
Hi Rishi,
Did you have a look at Alberto Passalacqua's site yet? http://albertopassalacqua.com/?p=112 There he describes to get OpenFOAM-1.5 working in OpenSUSE-11.0. Regards, Gijsbert
Regards, Gijs |
December 11, 2008, 12:49 |
Hello Gijsbert,
Thanks for
#13 |
Rishi .
Rep Power: 17 |
Hello Gijsbert,
Thanks for the reply. I looked at the post, but I cannot download from git, due to lack of internet access for Linux machines at my place and I cant install GIT software on XP, since its a univ library machine (from where I am writing this post). Only an http or ftp download is an option for me. Now OF-1.5 is working. I installed ParaView-3.4. Still missing paraFoam: same old QT errors... |
December 14, 2008, 04:09 |
Ok, that complicates the issue
#14 |
Gijsbert Wierink
Rep Power: 18 |
Ok, that complicates the issue a bit . I have had a similar problem in Fedora and there it work to copy the Qt executable that lives somewhere in /usr/bin/.. or something to /home/<username>/bin/ . Then it worked. I don't know whether this solves your problem or whether it is very elegant, but it worked for me ...
Regards, Gijs |
OpenFOAM 15 and openSUSE 111 paraview works OK | alberto | OpenFOAM | 10 | March 6, 2009 06:52 |
OpenFOAM 15 with ParaView 340 on OpenSuSE 110 | zairja | OpenFOAM Installation | 7 | February 10, 2009 09:31 |
[OpenFOAM] Paraview problem | nzy102 | ParaView | 7 | April 12, 2007 10:20 |
[OpenFOAM] ParaView problem with Regions | lr103476 | ParaView | 0 | September 14, 2006 08:12 |
[OpenFOAM] Some problem with paraview | thermo | ParaView | 10 | December 25, 2005 14:20 |
