Installation of OpenFoam 15 Compilation paraview
Old   July 16, 2008, 16:22
Default Dear all, i tried to instal
Soeren Brot
soeren_brot is on a distinguished road
Dear all,
i tried to install OpenFoam 1.5 today, everything looks fine until the compilation of paraview.
Additional information:
-Ubuntu 8.04
-"qmake --version
QMake version 2.01a
Using Qt version 4.3.4 in /usr/lib"
-OpenFoam 1.4.1 worked properly
As I am a more or less beginner in Linux, I used the the "installation guide" on the website and especially the README file.
Typing the commands:
* cd $FOAM_INST_DIR/ThirdParty
* rm -rf ParaView3.3-cvs/platforms
* buildParaView3.3-cvs
the last one produces following error message:
"soeren@soeren-laptop:~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs
Building ParaView3.3-cvs
MPI support : OFF
Python support : OFF
MESA support : OFF
Source : /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc
-- Check for working C compiler: /home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
-- Check for working C compiler: /home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- broken
CMake Error: The C compiler "/home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc" is not able to compile a simple test program.
It fails with the following output:
/usr/bin/make -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build
make[1]: Betrete Verzeichnis '/home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp'
/home/soeren/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o
/home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/testCCompiler.c
/home/soeren/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i6 86-pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
make[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Fehler 1
make[1]: Verlasse Verzeichnis '/home/soeren/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp'
make: *** [cmTryCompileExec/fast] Fehler 2
CMake will not be able to correctly generate this project.
-- Configuring done
make: *** Keine Targets angegeben und keine ğmakeĞ-Steuerdatei gefunden. Schluss.
Seems that the compiler does not work...
I would greatly appreciate any help on how to resolve this problem!
Thanks a lot in advance
Sören
soeren_brot is offline   Reply With Quote
Old   July 16, 2008, 17:25
Default I am having exactly the same p
Ning Yang
nzy102 is on a distinguished road
I am having exactly the same problem.
nzy102 is offline   Reply With Quote
Old   July 17, 2008, 03:31
Default The new gcc requires gmp and m
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The new gcc requires gmp and mpfr to be installed. The details and rationale can be found here: changes.html
They might not be installed by default on slightly older systems.
olesen is offline   Reply With Quote
Old   July 17, 2008, 04:06
Default i am having a problem with ins
mayank gupta
mgz1985 is on a distinguished road
i am having a problem with installing openfoam.....my connection to ssh and rsh is failing...i work in a network.,....then when i run blockMesh . cavity
i get the error no such file or directory.but i have sourced the file correctly........can ne1 help me..it has been 2 weeks with this problem....
mgz1985 is offline   Reply With Quote
Old   July 17, 2008, 04:42
Default From synaptic in Ubuntu 8.04 i
Javier Ros
jros is on a distinguished road
From synaptic in Ubuntu 8.04 it seems that the packages you need are
libmpfr-dev
libmpfr1|dbl
May be that the second one is enough. Do a search in synaptic with the string mpfr and they will arise.
Javier
jros is offline   Reply With Quote
Old   July 20, 2008, 11:38
Default hi, I have another problem
name
gitsnedbutzi is on a distinguished road
hi,
I have another problem with ParaView.
In my thirdparty folder there's no platforms directory and also no buildParaview3.3-cvs.
Why is that?
Thanks
gitsnedbutzi is offline   Reply With Quote
Old   July 22, 2008, 05:56
Default Thanks a lot! Including "libm
Soeren Brot
Thanks a lot!
Including "libmpfr-dev + libmpfr1|dbl" resolved my problem, everything fine now!
Sören
Old   July 23, 2008, 09:17
Default Hi, I have the exactly same
Hy Yu
ttdtud is on a distinguished road
I have the exactly same problem as Seoren.
However the configuration of my laptop a little different:
Debian
qmake --version
QMake version 2.01a
Using Qt version 4.3.1 in /usr/local/Trolltech/Qt-4.3.1/lib
And I got the entirely same error message as Seoren.
what should I do?
Thanks a lot!
Yu
ttdtud is offline   Reply With Quote
Old   July 23, 2008, 19:26
Default Hello ! I compiled Paraview
victor
torvic is on a distinguished road
Hello !
I compiled Paraview and it works. I have SLED SP1 and installed from scratch the following:
gmp (with ABI=64)
mpfr
gcc-4.3.1 (in the same path as stated in the README)
qt-X11-opensource-src-4.3.5
and then buildParaView3.3-cvs, which worked.
However, with Qt-4.3.1 it compiled as well, but, I had the problem regarding ".OpenFOAM" extension, and hence got to do the FoamToVTK procedure as Alberto suggest in a similar thread.
Hope it helps
best
V
torvic is offline   Reply With Quote
Old   July 24, 2008, 03:23
Default Hello, I have same problem
Djeghri Noureddine
noredine is on a distinguished road
I have same problem as Soeren had.
my question is that i dont find libmpfr1|dbl. I have ubuntu 8.04.
Thnks,
Noureddine
noredine is offline   Reply With Quote
Old   July 24, 2008, 03:36
Default hi while installing openFoam-1
  #11
mayank gupta
hi while installing openFoam-1.5, when i m trying to source the file, i am getting errors
bash:~/............./apps/bin/foamcleanpath:no such file or directory...
bash:~/.................../apps.paraview:no such file or directory
such a thing is coming for many apps.
can sum1 help?
Old   August 14, 2008, 11:38
Default I am trying to install openfoa
  #12
Nishant
nishant_hull is on a distinguished road
I am trying to install openfoam-1.5 and I can successfully run the case with bloclkmesh and solver commands (like icoFoam etc)
But paraFoam command is not working well.
I have qt-4.3.5 installed by default in my FEDORA-9. I checked the GMP and MPFR installation as well. The error it is reposting is:-
[343880@w191-210 channel395]$ paraFoam
paraview: error while loading shared libraries: libQtAssistantClient.so.4: cannot open shared object file: No such file or directory
can anybody help?
regards,
Nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   August 14, 2008, 18:07
Default Hi Nishant I guess compilat
  #13
jaswi is on a distinguished road
Hi Nishant
I guess compilation is the only way out as
the README document has explicity mentioned that
the binaries of installation version will work only with Qt-4.3.1 .
Please be kind to study the README and installation document provided . here is the link:
http://www.opencfd.co.uk/openfoam/doc/README.html
Please scroll down on this page and it details all the possible solutions.
Hope that might solve your problem.
With Best Regards
Jaswi
jaswi is offline   Reply With Quote
Old   August 14, 2008, 18:43
Default Hello,Nishant Singh I us
  #14
lin
Hua Zen
lin is on a distinguished road
Hello,Nishant Singh
I use fedora9,it works for me.For the missing file,libQtAssistantClient.so.4,you need to install the package qt-x11-4.3.5-2.fc9.i386.
Hope it helps
lin is offline   Reply With Quote
Old   August 14, 2008, 22:25
Default Nishant, I had to copy my Qt l
  #15
Gene
gbrother is on a distinguished road
Nishant, I had to copy my Qt libs and .so files over to /usr/libs; than re-ran through the paraview3.3 steps in the install documentation. That seemed to work for me.
If you got as far as you say, then you're probably just missing this last part.
gbrother is offline   Reply With Quote
Old   August 15, 2008, 00:07
Default hi jaswi I go thru the REA
  #16
Nishant
hi jaswi
I go thru the README file but I considered that the Qt version should be in between 4.3 and 4.4. Anyways, the problem at hand is that I have two installations of Qt - 1) qt 3.3 and 2) qt 4.3.5.
Linz, I installed the same package but 4.3.5 but in my case there is dual installation of qt 3.3 and 4.3.5.
Gene, I tried making a symbolic link through ln -s command for the lib folder b/w /usr/local/trolltech/qt-4.3.5/lib and /usr/lib/. but that didnt work. Will it be work, if i simply copy and recompile it? I will try this way.
Thanks all...
Nishant
Thanks and regards,
Nishant
Old   August 15, 2008, 00:25
Default Hello, Nishant Since I also
  #17
lin
Hua Zen
Hello, Nishant
Since I also use fedora 9,I could confirm that your problem is not related double qt version.For me,I also have two qt versions installed.
[root@phy-208 ~]# rpm -q qt
qt-4.3.5-2.fc9.i386
[root@phy-208 ~]# rpm -q qt3
qt3-3.3.8b-14.fc9.i386
The only answer I know is that you missing file libQtAssistantClient.so.4 is contained in the package qt-x11-4.3.5-2.fc9.i386.
Old   August 21, 2008, 11:40
Default Dear all! I have the same p
  #18
Aram Amouzandeh
mabinty is on a distinguished road
Dear all!
I have the same problem as Martin. when i have a look at the linuxGccDPOpt/ directory it is empty, when i want to generate a mesh for the cavity case, the bashrc doesn t know the blockMesh command:
[aa@lws16 icoFoam]$ blockMesh . cavity
bash: blockMesh: command not found
thx a lot in advance for any comments!
aram
mabinty is offline   Reply With Quote
Old   August 21, 2008, 12:31
Default I tried to install OpenFoam 1.
  #19
zhangting
xiaohezhu is on a distinguished road
I tried to install OpenFoam 1.5 today,I faced the problem just like Soeren described.
My OS is Mandriva2007,I have Qt version 4.3.2,
and today I have installed gmp4.2.1 and mpfr 2.3.1,I think these meet the install requirment .but I can't bulidparaview.
produces error message: like Soeren described
This is the first time for me to install OF.I feel so confused ,
could any one help me?Thanks a lot!
xiaohezhu is offline   Reply With Quote
Old   August 28, 2008, 23:01
Default Hi all, I am a new Linux us
  #20
Ying
then is on a distinguished road
Hi all,
I am a new Linux user and have Ubuntu 8.04 (64 bit) and OpenFOAM 1.5 (64 bit) on my laptop. The following is the error msg:
MPI support : OFF
MESA support : OFF
Source : /home/then/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/then/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc
/home/then/OpenFOAM/OpenFOAM-1.5/bin/buildParaView3.3-cvs: 64: cmake: not found
make: *** No targets specified and no makefile found. Stop.
done
I followed the instructions in this thread and installed 2 libmpfr files, but still have the same error.
Still trying to figure out why... Any comments? Thanks.
then is offline   Reply With Quote
[OpenFOAM] Paraview installation problem mcjicpm2 ParaView 0 March 9, 2009 08:15
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
Compilation error with paraview quartzian OpenFOAM Installation 0 September 21, 2008 09:32
Error building DICOMAppHelper during ParaView compilation geoffjay OpenFOAM Installation 1 May 7, 2008 14:07
Paraview installation problem please help bender OpenFOAM Installation 2 February 27, 2006 06:00
